Everything posted by MrBlueJacket
- 64 replies
- laughing whale
- trawler
- 64 replies
- laughing whale
- trawler
- 64 replies
- laughing whale
- trawler
In the meantime, built the propane tank, X-band radar, and muffler/exhaust as well as painting the pilot house.
- 64 replies
- laughing whale
- trawler
- 356 replies
- red jacket
- finished
- 356 replies
- red jacket
- finished
Yes, it was only one more round of primer/putty. Here's a shot of the rudder and sternpost, and the rudder hole drilled into the hull.
- 356 replies
- red jacket
- finished
- 64 replies
- laughing whale
- trawler
Filled in with auto glazing putty and sanded it down. Hopefully only one more round of primer and putty?
- 356 replies
- red jacket
- finished
Thank you! Next is masking off for the green paint on the hull.
- 64 replies
- laughing whale
- trawler
So now the bulwarks are in, a coat of bondo applied to the gaps in the joint and sanded, and a quick shot of primer to highlight the "discrepancies"
- 356 replies
- red jacket
- finished
- 64 replies
- laughing whale
- trawler
- 64 replies
- laughing whale
- trawler
Andy - I think you are doing a good job. Remember the old quote: "Putty and paint, makes it look like it ain't" TeeHee Nic
- 106 replies
- bowdoin
- BlueJacket Shipcrafters
I have been following this build and am amazed at the level of detailing you have done - GOOD JOB! Makes me proud to give you the platform to follow your goal. Nic
- 227 replies
- Stephen Hopkins
Hull sanded down. I always use a sanding block to get a smooth surface. Just using 80 grit for now, but after the next round of primer and putty, will switch to about 150 grit.
- 64 replies
- laughing whale
- trawler
Used the Dremel sanding drum to thin out the bulwarks. After I put in the plywood pieces, I will thin some more. Luckily, the Forecastle decking will hide most of that space.
- 356 replies
- red jacket
- finished
Nice job. As I promised, there is a note in your customer file for 10% off your next kit purchase.
- 75 replies
While at a Maine Made show in Bangor, I came across a guy who cuts trees into 1/2 inch slabs for cutting boards. I thought that one of them would make a great baseboard for the trawler. Here it is:
- 64 replies
- laughing whale
- trawler
A coat of primer, then an application of red oxide auto putty, then sand. After that, repeat at least once more.
- 64 replies
- laughing whale
- trawler
My first car was a white '62 Falcon sedan, 3 on the tree.
- 356 replies
- red jacket
- finished
- 356 replies
- red jacket
- finished
