MrBlueJacket
Everything posted by MrBlueJacket
  1. And, of course, what modeler cannot resist putting the sub-assemblies together to see what it will look like?
  2. Legodude, when you finish this build, I will give you (or your designated buyer) 10% off your next BlueJacket kit. Thanks for posting! Nic
  3. At the bow, the figurehead of "Red Jacket" (Sagoyewatha, Seneca Indian chief) was painted and mounted. His nickname is because a British soldier gave him a coat during the revolutionary war.
  4. Today I put on the photo etched scrollwork at the stern. It took an hour of aligning and re-positioning and gluing to get it done. I am happy with the result!
  5. It's time to do the figurehead and stern carving. They are of Sagoyewatha, the Seneca chief of the Wolf clan. His nickname Red Jacket is because of the red coat a British army officer gave him during the American Revolution. One of the problems in painting is to mix the flesh color of an American Indian. A google search yielded plenty of advice from miniature figure painters, but they involved colors in acrylic and/or oil that I never head of. What I finally settled on is a mix of Burnt Sienna and cream. I think it came out OK.
  6. Last night I made one of the two hatches for the deck. I used eyebolts bent over for the hatch lifting rings.
  7. Meanwhile, back at the pointy end............... We have installed the knightheads, catheads, hawse lips, spray rail, and some eyebolts.
  8. And here's two of the 3 pieces glued down into their many little holes. There will be puttying to do to get a smooth railing at the transition point.
  9. Over the w/e I started the poop deck railings. The kit provides several lengths of cast stanchions/railings. These have to be bent to fit the curvature of the stern I decided to bend them upside down, to get a more accurate curve. Then they will get painted and installed.
  10. Pinrails - as promised. Now it occurs to me that I didn't have to be so precise about fitting the stanchions - the tops can't be seen!
  11. To get each stanchion the correct height, the best way is to mark it in place. I use the Xacto blade to make a cut in the edge. Sometimes it needs a touch of sandpaper to fit, but mostly it goes right in. Then hold it with tweezers while you apply a drop of thin CA glue.
  12. Last night I measured, trimmed and installed 34 stanchions on the port side. Each one is a slightly different length. It was a couple of hours of great fun.
  13. Nice job finishing this, Jon. 10% off your next kit from BlueJacket has been added to your customer file. Thanks for the build thread. Nic
  14. Take a deep breath, cross those fingers, and spray! OK it looks good, now the real test - pull off the masking tape........ HOORAY! Just a little touch-up needed on the inside of the bulwarks from the first spray job.
  15. Further thought - where the stem separates from the hull, cut it at that point, then glue to the hull. The remaining wedge-shaped gap will be easier to fill, and the stem won't look elongated.
