Posts posted by MrBlueJacket
Next step is to attach the lifts. They start of course at the yardarm, go through a block in the cap, and terminate to a single becket block.There were two difficult steps which took about 2 hrs. One, getting a line through the little blocks under the fife rail. (see post#22) Second was to align the lifts so the yard would be perpendicular to the mast.
- Keith Black and GrandpaPhil
- 2
First, the vacuformed sails will be discarded. also, the plastic decking will be replace with wood. I took some glued-up decking, and painted it wood, then wiped it off with thinner. SInce the main deck was a little wider than the wood, I had to butt splice 2 sheets together. A scrap strip of 1/32 basswood added strength to the joint.
When flipped over, you can't see the joinery.
- Scottish Guy, Ryland Craze, Nirvana and 2 others
- 5
A bit of a departure, but I was at an IPMS show in Sanford ME this spring, and decided to build a model to enter next year. Not anything too complex, like Cutty Sark of Constitution. This kit seemed perfect, and with just a little kit-bashing should produce a good model.
- Scottish Guy, Nirvana, Knocklouder and 3 others
- 6
Mounted the yard this weekend. roughly placed all 10 sail lines and attached the chain sling, complete with leather chafing guard.
- ccoyle, Keith Black, GrandpaPhil and 2 others
- 5
Furling the sail to my satisfaction took about 1/2 hour. I'm happy with the way it looks. Now to do 4 more, then the jibs.
Starting to furl the sail. You have to dampen (not soak) the silkspan to get it to co-operate.
Getting ready to furl the sail. You can see the leech and bunt lines going up through the bullseyes on the top of the yard. Hard to see, but the reef line goes through a block at the end of the yard.
- GrandpaPhil and Keith Black
- 2
Yes, the plans are done to the proper perspective.
Nic
- Ryland Craze and East Ender
- 2
All the lines and blocks attached. now it is time to glue the sail to the yard. I'm using Aleen's Tacky glue, which is like Elmer's on steroids. I lay a thin bead at the top of the sail.
Next I place it on the yard, which is held up with an alligator clip stand (3rd hand)
At this scale, jackstays would be parctically invisible.
- gak1965, GrandpaPhil, Keith Black and 2 others
- 5
15 hours ago, Rick310 said:
Really like the foot ropes. They look really good!! How did you secure the stirrups to the yard?
Rick
drilled a hole and glued them.
- Rick310 and Keith Black
- 2
- BobG, GrandpaPhil, gak1965 and 1 other
- 4
- 2
In the Northeast we hold an annual joint clubs meeting at the same place and time every year, and it draws 100 modelers. Always the last Saturday in April, at the Port & Starboard convention center in New London CT. Here is a video of this year's conference:
So the idea of a rotating but repeat location is very attractive.
- Knocklouder, Jack12477, chris watton and 8 others
- 10
- 1
- BobG, Keith Black and GrandpaPhil
- 3
- GrandpaPhil, Keith Black, gak1965 and 1 other
- 4
- Ghost029, GrandpaPhil and Keith Black
- 3
Nice to see you stepping up to the task!
Newsboy by MrBlueJacket - FINISHED - Model Shipways - scale 1/8"=1'
in - Kit build logs for subjects built from 1851 - 1900
Then attach all the rest of the sail lines, except for the tack line, which would interfere with other stuff. The tack lines will get attached when doing the braces.
