Posts posted by MrBlueJacket
attached the outer jib. Next tying it onto the stay, then furling it.
- GrandpaPhil, ccoyle and Keith Black
- 3
Had a busy week, but managed to make the outer jib sail and get the lines and sheet blocks attached. the end is near!
I agree the copper may have been coated. Try a light sanding with 400 grit wet paper and blacken again?
And the anchor chain is removed to be replaced with blackened chain.
- ESF, ERS Rich, GrandpaPhil and 1 other
- 4
So the jib sail got attached without issue. Now let's see if it can be furled without disintegrating.
And yes, success! Adding the drop of glue to the thread/silkspan attachment worked!
- Keith Black and GrandpaPhil
- 2
So here's jib sail V.3 Lines attached, sheet blocks on, thread tied and reinforced with glue. Should work out fine.
- Keith Black, GrandpaPhil and gak1965
- 3
23 hours ago, Roger Pellett said:
Nic, Is the brass anchor chain your customer’s choice or do you intend to blacken it later. A beautiful model!
Roger
Probably leave it brass
- Keith Black and Roger Pellett
- 1
- 1
So the sad saga of the jib sails......
First attempt to use 2mm split rings was a disaster, they ripped out of the sails trying to put them on the stays.
Second attempt to tie them to the stays also ripped out.
Now I just made a third set of sails, I'm going to tie them BEFORE putting them on the stays, and to make the attachment stronger, I will put just a tiny drop of CA on the knot. Wish me luck!
- ERS Rich, GrandpaPhil and Keith Black
- 2
- 1
Did you actually fit out all 8, only to cover up 6 of them? Awesome!
Nic
- Glen McGuire and John Ruy
- 1
- 1
All the braces are done, here are the 2 jib sails I will have furled on the bowsprit.
- Rick310, GrandpaPhil and Keith Black
- 3
Here we have the three lower braces attached. Two more to go, then the running rigging on the bowsprit, attach 2 jib sails, and she's done.
- ccoyle, Knocklouder, Keith Black and 5 others
- 8
The decision to make them limited edition was made by the previous owners. When I took over, they were already well into development. The idea was to honor the 150th anniversary of their battle off Cherburg, France.
- Ryland Craze, mtaylor, Roger Pellett and 1 other
- 4
I believe the smokestack, like funnels, could rotate depending on the relative wind.
Nic
Attaching the martingale bobstays (chain) The back end goes to bullseyes.
- GrandpaPhil, Keith Black, Rick310 and 1 other
- 4
- ccoyle, BobG, Roger Pellett and 3 others
- 6
Prepping bullseyes for the bowsprit rigging. the mat has 1" spaced lines
I agree - very good work!
Nic
Santa Maria by MrBlueJacket - FINISHED - Aurora/Heller scale - 1:90
in - Kit subjects built Up to and including 1500 AD
So after a few months, painted the outside, and trial fitted the deck. big problem - the deck has a lot of shear, so I have to pre-bend the deck to get it to fit. Here's the first attempt, but it didn't bend as much as needed.
