Posts posted by MrBlueJacket
All seems OK. Remember, no-one will take a ruler to your hull and tell you it's 1/32" off !
Just a guess, but I've seen numerous examples of lines going to blocks on the deck, then up to a belaying point. I think it is because you can pull up with more force than you can pull down, being limited by your weight.
On 4/11/2023 at 2:09 PM, Roger Pellett said:
Nic, A handsome model beautifully built as usual by the two of you. A clipper brig might be appealing to customers without the display room or desire to build a Clipper Ship. If MS no longer offers, perhaps add it to your line.
Roger
We already have the USS Perry, similar in size and complexity.
https://www.bluejacketinc.com/shop/model-ships/kits-model-ships/naval-vessels/uss-perry/
- Rick310, GrandpaPhil, Keith Black and 2 others
- 5
Good start, Tim. Look for a PM from me.
Nic
Eric, we have listened to your comments. Since you finished the model, your customer file now shows a 10% discount on the next kit you buy from us.
We have plans to build the Cairo in 3/16" = 1' scale (3x the size of this one) and it will be a longitudinal cut-away to show interior details.
Nic
- GrandpaPhil, mbp521, mtaylor and 4 others
- 7
The hulls "should" be a little oversized to allow the modeler to bring it down to the final dimensions.
Nic
Try auto glazing putty or bondo or wall spackle. All 3 are relatively soft, stay away from carpenter's putties - they dry way too hard.
Nic
A little putty and sandpaper will make that hull nice and smooth. Stay away from the hard carpenter's fillers, use softer ones like auto glazing putty, bondo, or even wall spackle.
Nic
I would suggest against the Durham's putty - it dries VERY hard and it will be difficult to get a nice feathered edge with the basswood. Instead, try auto glazing putty, bondo, or wall spackle. that's what we use.
Nic
Congratulations! Under Daniels name, it now shows a 10% discount on the next kit you buy from us! Well done!
- Keith Black and GrandpaPhil
- 2
- Rick310, GrandpaPhil, Ryland Craze and 2 others
- 5
1 hour ago, gak1965 said:
BlueJacket makes photoetch safety nets for the USS Arleigh Burke, which I think is the same scale. I thought that @MrBlueJacket mentioned elsewhere that it is possible to get parts that are in their kits (but not something that they routinely sell separately) by calling their office.
You might check this.
You are correct. We sell parts all t he time.
Nic
- mtaylor, mtdoramike and Canute
- 3
Keith, thanks for the tip. I wet the last inch of thread in CA glue, which makes it stiff, like a needle threader. Works great.
- Keith Black and Ryland Craze
- 2
Bowdoin by Mjohn - FINISHED - BlueJacket Shipcrafters - 1:48
If the parts are clean, no need to prime them. And for "considering not priming...." I call that inspired laziness, I do it all the time.
Nic
