Posts posted by MrBlueJacket
you will notice that by splitting the false deck and having each side butt against the keel, you are assured of a straight hull.
Nic
- Keith Black, Roger Pellett, Canute and 2 others
- 5
So now I have added the two rear decks.
- ScottRC, Knocklouder, GrandpaPhil and 1 other
- 4
Next is to add the lower deadeyes, then I can put the afterdeck in place.
With overlapped plates, there's not much to protect the edges. Be careful handling the hull, and when the model is finished and in a case, then no-one will be able to touch or brush against it.
butt joining the plates reduces, but does not eliminate the problem.
Nic
- mtaylor and Ryland Craze
- 2
Cannons installed. plastic model cement works for plastic to wood bonding.
Note: The copyright date on the plans is not the manufacturing date of the kit, it only documents when the kit was designed.
Nic
- Ryland Craze and John Ruy
- 2
Assembled the cannons. The tie ropes was my idea
- Nirvana and GrandpaPhil
- 2
Yes, you can buy a carved hull, and the plans page with the templates. Call us up. 207-548-9970
Nic
The Forecastle deck in place. I also mounted it on a workboard with pedestals.
- Knocklouder, Baker, ccoyle and 2 others
- 5
Here's the windlass and anchor rope
- Louie da fly, GrandpaPhil, Nirvana and 1 other
- 4
The keel needed some putty to fill cracks between the two halves.
Marrying the other half was a bit more difficult, the deck AND the keel needed to line up. but in the end, it worked.
- Scottish Guy, GrandpaPhil and Nirvana
- 3
So I also had to warp the bow area. Some rubber band coaxing, and the deck is now married to the port half.
- GrandpaPhil and Nirvana
- 2
Thanks, everyone. When my customer picked it up, he was very happy. And I learned why he wanted this particular model. His older brother by 13 yrs built one as a young adult. His brother passed away, and the model was lost. So this has a lot of sentimental value. I'm so happy I could do this for him
- Ryland Craze, GrandpaPhil and GGibson
- 3
So, wood bending V.2
Again I wet the underside, but used a Monokote iron to steam out the wood while bending it over an old coffee can. Ended up working perfectly.
1 minute ago, ccoyle said:
What? No finish pics? 😢
Coming....be patient
- Keith Black, Ryland Craze and ccoyle
- 3
Working on a plastic Santa Maria for an IPMS show in the spring. Build thread here:
And with the addition of the anchors, the model is complete. Next step is to put it in its case.
- Keith Black, gak1965, ccoyle and 3 others
- 6
So all went well, outer jib is now furled.
- Keith Black and GrandpaPhil
- 2
Lightship #112 NANTUCKET 1936 by Jeff Preisler - FINISHED - BlueJacket Shipcrafters - Scale 1/8" = 1'
That's a really good start.
Nic
