Old Collingwood
  1. I have Two of their brushes - they are excellent. OC.
  2. Evening my fellow - very patient followers, some more progress on my build - I am working on the ground plan, this is taking some testing and shaping to get all the buildings and walls to lign up, i got the main section in supported by a sheet of paper underneath, then a bit of putty was put in a few of the gaps and painted over, i also put a couple of water puddles in the corners from the rain that ran down off the roofs, I will do the same - paper trick underneath the front sections before putty and paint - then there will be some washes and dust dry brushing. OC.
  3. I love dry brushing - it so makes a difference - my new "go to" dry brush product is AK's acrylic dust - can be splattered on / wet brushed or dry brushed. OC.
  4. Figures are coming on fine mate, shading is always difficult to get right and the bigger the scale - the more difficult. OC.
  5. Thats good progress Craig, with the paints as thin as you can is key, and as you say build the shades up in thin layers, a wash to shadow the eyes and recess details also helps. OC.
  6. Afternoon all, just a quick pic to show an overhead view of how I will be placing LHS on my display base. OC.
  7. She looks massive - so much detail can go into these builds. OC.
  8. Thank you kindly Mark, it has to be fairly busy as it was a key place for the infantry. OC.
  9. Looking good Craig - Isn't that just the norm with aircraft/vehicles getting figures to fit properly? same with a lot of replacement pilot figures for aircraft kits where they are too scale tall and the canopy wont close after they are fitted to the bang seat. OC.
  10. Evening all, some more progress this evening - remember those Three 2nd KGL? well I took them off their bases then put them to One side, I got the base section near the pond and worked out where I wanted to place my new figures - this required some planks making up and stacking together to give some height so they could fire through the holes in the wall, so my lolly sticks came into use - cut sanded glued then a Brown coat followed by a Black was - then my dark wash finished of with a dust dry brush. These were put to One side while - "Those bricks from the wall" were made into a little pile - glued in place then painted. Then the Three figures were glued in position - looking quite busy. OC.
  11. The finished ship should be displayed in a museum with a video tutorial of the build - its that good. OC.
  12. Evening all, I had quite a productive evening for a few hours - I decided to get my airbrush/spray booth out and started by Flat top coating the last Three finished KGL, I have a very good Acrylic Flat top coat called - Ammo by Mig Ultra Matt Lucky Varnish it is in a tall bottle and even has a ball bearing inside for shaking it, its been fab so far whaen brushed on - however I was realy supprised that it was even better when misted on using my airbrush. I was soon getting used to the dual action and the finish was Superb Dead Flat. So I thought why stop there - so I got my box out containg my 50 odd painted figures and set about spraying these with the Flat coat. I was finding I could do Three at a time with the metal pot on the airbrush about 3/4 full, as soon as it was empty I would wash it through with some cleaner and plain water - then continue again - took me about Three hours to finish all of them. Loving the airbrush. OC.
  13. That is Superb work carving that out of just a block of wood - seriously good mate. OC.
  14. Thank you Alan, I had to play around with the colours a bit because the pink on the cheeks was a bit too clown like, So I went over with a diluted face base colour I use first - this allowed just the right amount of pink to show through. And I added a couple of "Toshes" OC.
  15. Great seeing you back on Vic phil, I missed reading your updates - really great start back on her - like we all know its the small details that make all the difference. OC.
  16. Evening all, more painting on my Three KGL they are painted now and will be flat coated using my airbrush tomorrow. OC.
  17. Indeed Mark - I have a few that have mustache's - and will add a few more. OC.
  18. No problem mate - always good to have a secondary plan incase you need it. OC.
  19. Thank you kindly Alan, I know tell me about it. I am still picking up ways of improving the faces - sometimes I use more or less wash that settles in the groves and eye sockets, and also using a combination of colours to shadow/highlight the different parts of the face - same with the cheeks giving them a slight pink glow - its all about trying different shades to nail it. OC.
