Old Collingwood
  1. I see where you are coming from - and meet you, My brain box is searching many questions and ideas - but I will stop short of instaling a bar or refereshments stand - I know who would raid it ......Come on own up lol. OC.
  2. Thank you Mark, will give it a go - can always fall back on my hairy friends to touch up the more delicate areas. OC.
  3. Thank you kindly Mark - my understanding is the ground inside the farrm complex was stones/cobbles with a kind of cemented loose gravel spread ontop, my base shows the stones/cobbles in areas where the top mix has worn away, I know the over all appearnece would have been very random and and routh - so perhaps my airbrush would not be the best tool. OC.
  4. How come you are doing 1/32 planes now mate? lovely job as well. OC.
  5. Evening/morning all, I had the day off from building on my dio - but it hasn't stopped the old grey matter from turning round in my head - thinking ahead for latter today (its 3 am here) when I lat down some dark earth washes using my pre mixed bottle - would I be better off spraying it over the whole floor surface of my dio's courtyard or brushing it - yes the airbrush would give a more even flow but would that strictly look right ground surfaces especailly after heavy rain are never even or consistant. What do you think my friends??? OC.
  6. This is Looking So Superb - but frankly you set yourself a Very high target for quality after your Amazing Sub build. OC.
  7. Excelent work Yves, I have a question for you for way down the line - are you tempted to man her with a crew? OC.
  8. Excellent work with those (hand made) lanterns Phil - its a different level when you can do stuff like that - she is coming on a treat mate. OC.
  9. Thank you kindly Mark, I am deffo going to make use of my "Magic Water gel" I love the stuff and guess after I have brushed a few layers of my wash over it (it tends to settle in gaps etc) it will start to come together. OC.
  10. Thank you kindly Denis, I also have a few more rain pools to scatter in some of the corners, possibly a drain that will cleverly hide one of the joins in the boards where I put in my putty but has sunk slightly - might look quite good? OC.
  11. Thank you Alan, yep got lots of troops to go in there yet - and outside the walls and all around at a guess over 100 possibly closer to 150 - or I might just keep adding them as I go. OC.
  12. Evening all, some good progress - the complex (apart from the garden shed) is now fitted together and the joins in the floor filled with putty and painted, I had to put a slither in a gap close to the main gate - this was then painted and dry brushed, it still needs a couple of washes over the floor and dry dusting. The grass area received some attaention also - the grass blades were coming out so I brushed over s watery PVA mix then weathered it a bit using some datk wash to simulate a dirt grass from lots of rain. I have included some arty pics to show some different views. OC.
  13. Looking mighty fine Denis - going to be really colourful. OC.
  14. Looking so nice Mark - so good seeing you getting stuck into this. OC.
  15. I've got 2 hammocks me old mucker - you can pinch on eof those. OC.
  16. I do exactly that with my brushes and Masters - first wipe most of the paint of your brush till it looks paint free, then soak the brush in clean water (I use pre boiled thats gone cold) then rub the brush around in the masters tub lathering it up - you will probably see some paint residue come off into the lather, wipe most of the soap on the lip of the master tub the into the water again removing any soap on the brush - I tend do it a couple of times to make sure all the paint has completley gone from the hairs and ferule, then just cloth dry and put the cover over the end of the brush - thats it. OC.
  17. Thank you Alan, the whole area will have a couple of washes to darken it then some light dust dry brushing. OC.
  18. Really nice work Alan - Well done finishing her - onwards and upwards with your next build. OC.
  19. Excellent work Craig - those figures turn a model into a living thing - looking forward to more progress when you are back on it. OC.
  20. Evening all, a tiny bit of progress - I decided to add some colour details to the stones in the courtyard, these will be blended when I do a wash or Two and dry brush dusting, I also fitted a tiny rough lawn that was in the courtyard - its one of those scenery mats that you just cut to size and glue down using PVA - think it looks OK. OC.
  21. I brought a size 0 and a 3 and they are brillaint - soft hairs but lovely swing back and a nice load to the hairs - so worth cleaning well so I clean using Masters cleaner and brush preserver after every use - its like soap. OC.
