Evening all, so we started the day of by insisting that the "spoiled pooch" must come out on a dog walk, we decided to go a slightly longer route that takes us along an old canal then we normaly take a short cut under a train bridge and into our local park, but we were stopped in our tracks (excuse the pun) by a flooded underpass under the train line - we had no choice but to turn back. This added quite a distance to our dog walk we found a bench rersted up than went home - got in knackered. After dinner I decided I must do abit on the Chally - first off I decided to touch in using my acrylic Nato Green tin and brush - "upsss - very flat out of the tin" it stands out against the slight satin from the tamiya rattle can, so I made the drastic step of hand painting the whole thing (hull and turret) using the flat acrylic with a brush slightly watered down. It went on not too bad but I was having to mess witgh it a lot between the coats drying as I was getting brush marks on the larger flat areas, I decided in the end that these will probably polish out when the paint is hard using a soft cloth. No pics again as I am not happy to show it yet. OC.
Old Speckled Hen for me - its an Ale. OC.
- 1,090 replies
- showcase models
- vendetta
Munching on Marks Popcorn last time I saw them😁 OC.
- 1,090 replies
- showcase models
- vendetta
Evening all, right - paintwork rectified, I made a bridge support that was stuck spanning under the turret ring from a lolly stick, I then attached Two of my large plastic clemps and this afternoon went out onto our patio and did the first of Two layers, they both went on without incident and no dust this time as I wore a new glove, I then put them aside to dry outside while we went for our dog walk, when we got back I gave them a check over and still fine and was dry enough/de gased to bring them inside. I will be doing some detail painting and building/painting the small sections tomorrow (I hope)? OC.
Looking really good mate - thats a neat looking pic on your monitor 😉😊 Absolute pleasure to be able to help. OC.
Superb work Chris - really top notch workmanship. OC.
- 55 replies
- Blue Ridge Models
- Normandie
Apperntly nice - but they do have smelly feet........😁 OC.
- 1,090 replies
- showcase models
- vendetta
Or spending most of the time on the carpet looking for those tiny parts that went "ping" OC.
- 1,090 replies
- showcase models
- vendetta
Same as Edward - sincerley sorry I missed your build log on this - atleast I have caught it now - loverly work indeed mate. OC.
- 90 replies
- finished
- Midwest Products
Hi all, a wee bit of an update - I have managed to tidy up the hull, I used some small pieces of fine wet and dry - and gently rubbed over the areas where the dust specks were, did quite a good job, I have made a temp holding device in the shape of a lolly stick that spans under both edges of the turret ring its wedged one end and secured by a small clip the other - I will be able to hold it now without fear of it falling. So tomorrow I should be able to give it a bit more paint in a couple of light layers - same with the turret. I also decided to make the Chrome Dome on the commander a wee bit darker so I used a darker shade of Green. OC.
Looking good, good move on filling in the lower ports at the stern, as they would have been a wee bit close to the sea from her extra weight, I see you are doing her with the 6in barbetts on her waist, cool if oyu have the brass barrels they will super nice. OC.
Thanks Ken, all One persons fault - Mine, I rushed - didn't prepair and didn't consider that the old glove (the cheap throw away surgical type) would be no good to re-use after priming, also I did not have a propper hold of the Hull (yes foreget to mention it fell away from a plastc clip I was using - and fell to the floor onto slabs) nothing broke or fell off (told you those Challies were tough. I was cursing and got one of those looks off the admiral as I am creating a history off the same disasters when it comes to me Rattle can painting, nothing I can do though - I have to use them if I want a smooth paint finish. Planning for when I tidy up the hull and go out and re-spray - I need to rig up something I can trap between the turret opening in the hull that would allow me a way to hold it and rotate in my hand to spray all over it side to side - top to bottom, without dropping it this time. OC.
I brought both sections in the house after the smell had gone off and surveyed the damage - it looks like it is deffinatly fixable, do you know what would be perfect to fix (Isolated fine sanding) like a pointed q -tip but made from fine grade wet and dry, so I could just sand the specks away in hard to reach areas where there are lots of fittings like the top of the engine covers. OC.
Good day all, bit of an update - another nice day here so without delay I decided to take the Two sections out into the yard with the intention of putting on the Nato Green with my rattle can - first I put my disposible glove on - shook the can for sevaerl minutes then trying to hold the turret first using a tube I had a mde from a pringles tub, this was tack taped underneath with tamiya tape - first coat went on not too bad, I put it down on my chair and picked up the main hull - Im used a gorrila clip to try to hold as by holding it before with my fingers inside the turret ring - was before causing me to catch my glove on the painted surface, anyway spraying away then I noticed bits started falling on the wet paintwork as I was spraying - it was dry dust fragments falling off my glove, it fell on the wet paintwork like embers from a fire. Yep wrecked paintwork - I will try to sand off the damage latter. Always fun and games with my painting technique - but frankly its inevatable with how I have to work.😬 OC.
