Evening all, a good days work on the turret, I made a base and added the commanders adjustable seat, next was to create similar for the gunners seat/position, last was the loaders seat. To gauge the correct hight I made up one of the tanker figures I have brought, I tested it by dry fitting the turret roof and placing the figure through the commanders hatch. OC.
Best thing I found - soak the flag in watery PVA then crunch it to get it to fold in the position you want, then let it dry/set before attaching the cord/rope/fine thread. OC.
- 211 replies
- prince of wales
- tamiya
Well done my friend you have done a truly splendid job - everything about her looks spot on perfect - a real credit to your hardwork and commitment - just needs a home now. OC.
- 436 replies
- vanguard models
- alert
Evening all, more progress, next stage in the internal detail (battle) I mean build, is to compare the Chally turret ring with the M1 - yep quite a difference (the M1 quite a bit wider) the M1 ring also has all the detail on it - so I wanted to try to transfer the ring (part of it) over onto my Chally, this was not going to be easy as the only thing I could do was to follow a ridge on the bottom that is the right width I need, and to score through it with my scalpel blade till it went all the way through the plastic. Messy and nearly a dangerous job as the blade did slip a few times, but after about an hour of blade work it eventualy broke through, just a bit of clean up and a test fit - it needed to be slit then shaped a bit at the front thenglued in place while pushing against the rim, after I added a Two part edge under there the Breech will be. Think it will work.......... OC.
