Old Collingwood
  1. Thank you Ekis, I'm not sure how big the damage was as info on it is a bit sketchy - they just say the French attempted to set fire to the Barn Roof and it was only by the KGL using kettles from the pond - that rescued the roof before it could go to far. OC.
  2. Ekis can I ask for some advice please mate, when I start building my Waterloo La Haye Sainte farm buildings, part of the Barns roof was set on fire by canon fire (I understand) how can I best replicate this in my MDF roof - builing the damage and simulating the burned look? OC.
  3. Think it will look superb - wait till I have to paint the figures in that disruptive camo😲 OC.
  4. I brought this one Mark, it seems really good I just use a thin bit of wire - dab the wire end in the small puddle of glue in a saucer (like the garden pot type ones) then dab it on the place were I want to place the PE, keeps it controled taht way also give a little time to move the part around (not lots of time but just enough) OC.
  5. What I will probably do with the Abrams is limit the extra armour on the hull to just the reactive flat boxe's and not the (roof tile looking plates) just think they look silly but will give the turrets the Full Monty. OC.
  6. Thank you for finding that Edward, think I remember it - probably as a kid wishing I could paint Airfix figures like that. OC.
  7. You could try this photo downlaoding site - I use it quite a bit - https://postimages.org/ OC.
  8. Also I came across this little gem - Sharps very own discussing Warerloo, have yet to watch the whole thing. OC.
  9. That video looks excellent and that chap almost on the verge of reinactmant vs wargamer. OC.
  10. Evening all, more progress still on the top plate - firstly I had what seemed like Ten Million engine hatch hinges, then there was a few handles that were about 0000000.1mm wide (well not quite) but still minute, the savior was some larger fittings like fuel filler caps and engine exhausts, also a couple of side handles (not as small as the other tiny things). Next was some engine cover Bling that was a pleasure to fix down. I have taken a few pics ot show the massive size of the M1 kit (that I will be pinching the interior from) and also some super detail sets I boright to bring the M1 upto its most modern look, and the Chally tankers I will buid and paint. OC.
  11. Should see the size of the box its Huge and the parts count loads and loads. OC.
  12. Here's the plan over the next day or so - I will attach a few more of the fittings and PE on the top of the hull, then the exciting bit - I have had my other kit arrive including a few bits - modern British tank crew, the plan is I will pinch the internal bits for the turret and drivers cab, and start the process of trying to make them convert from a M1A2 into a Chally 2 interior. Here is the kit -
  13. I can relate to that - from Synth/Bass/Sax and now with VST's. OC.
  14. Evening all, more progress on the frontal armour - I added the two drive lights (fiddly little things) one of them forsted over from getting a bit of glue on it, I removed the glue after it had set with a sharp blade, it doesn't matter too much as I will paint them alum and when I add some dust dry brushing after painting - they will blend in and wont be seen that well. The bottom section of armour was cut off next I decided to glue the Two togther as they lign up better that way, then a tiny bit more bling was added, then it was on with the top section - this has a few fittings including Two PE pieces that needed bending Three times then a couple of lights where fixed in place with a small amount of CA. I then dry fitted the Two togther - a great fit of parts is shown straight out the box. OC.
  15. Amazing find you would need either one of those camera drones or a camera on a long stick to get close up pics of that. OC.
  16. I had a look on the net and found this - not sure if it helps my friend. OC.
  17. Just loooked on a battle plan and it shows the battle area as 3 miles across and 2 miles deep converting that into 28mm I think is something like - 565 Feet x 377 Feet For a Dio of the whole battlefield. that is Massive. OC.
  18. I was thinking about the scale of the battle (I thought my little dio is going to be big enough at 36 X 20Inches) imagine if I could have built the whole battle field in 28mm ............I would need about 100feet square I would think. OC.
  19. Indeed Edward, between the Two obstructions I think it decided the battle on the allies side - not foregetting the Brilliant squares aswel. OC.
