She is looking Superb - so mutch work my friend. OC.
- 436 replies
- vanguard models
- alert
Here's the plan (hope your sitting comfortably) - When I have finished the bottom hull (tub) and weather permitting - I will be able to venture into the garden (how you can call a 8ft x 12ft a garden) anyway I will be able to hold tub from the inside and using my Tamiya Surface primer rattle can, I will be able to give it a coat, it will then be put in my storage box and locked away to de-gass. I will then start on the details on the main top plate - this should give me some time working on this stage before in a few days I can take the tub out (examine it) then if all is ok - and if the weather gods play ball - back outside for a coat or Two of Nato Green (again Tamiya rattle can). This will be my process for most of the build - building then painting in stages. Right - here's my thinking for the inside , bare with me on this - take a deep breath - Both the Challenger 2 and M1A2 Abrams would surely share some similar (kind of) electronics and instruments inside each interior, also both share a 120mm breech, and the rear ammo locker can be made to look very similar - difference in the Chally its open with no blast doors, I think with some careful adjutments by going over my interior Chally pics, I should (might) be able to come up with something quite close (well it will be locked away and when Two figures are standing through the hatches you wont be able to see a thing (I will know its in there though. OC.
Hey Mike, I have found a solution to your miniscule modeling - I have zoomed in with my browser, wont help you out though.😁 at least this way I can see your glorious (but mad) workmanship keep it up mate. OC.
- 179 replies
- hatsuzakura
- pit road
Dont worry - where all still here, may need to stock up on the rations though some hungry folks here............. OC.
Hi All, some more progress on the tub - firstly I fitted the rest of the iddlers/got them level and let them set, next was the skirt armour plate supports - same principle with these glued and ligned up. I put it aside for an hour or so then I turned my attention to the Gas strut units - Six on each side these needed dressing before gluing in place, after Two units were glued inplace towards the front. OC.
