Very very nice - fidly but Sooooo.........delicate, got to be so careful how you handle that thing. OC.
Hello from Plymouth, Devon
Old Collingwood replied to FlyingFish's topic in New member Introductions
We are all equal here - just different levels of it - one thing we share (well about Twenty actually) Humour, whit, love of food, humour, more whit, oh and cant foreget food, mixed in with that some building.😉☺️ OC. -
Warm welcome to our little piece of paradise, you have chosen the right place to share your work. OC. -
1/48 Italeri Hawk T.1A (On Hold)
Old Collingwood replied to Old Collingwood's topic in Non-ship/categorised builds
Evening all, so it begins - starting with the cockpit/instrument panels, with the kit are some pe panels and not bad looking either, I did however order the pe update set from Airwaves, but to be fair I had not looked at it for a good while - well years to be honest, and I found they were some considerable size Way too big to fit, I had to look at the packaging to make sure they hadn't sent out the 1/32 scale ones, nope 1/48 but for a different kit not the Italeri - but I was able to do a bit of "Cut and fit" using a mixture of both. The front panel I will sand slightly around the edges. I started with the panels as I said these fit perfect, thay have the cut outs for the dials - so I thought paint black behind all over and stick the pe panels down to this, so I decided to use the Vallejo Primer (Black) and instead of trying to glue them down after - I stuck them down onto wet paint then forced dried them - "Yep they stuck" but I will dab some gloss clear coat into the dials after painting the face of the panel, this should help secure them, I then started fixing down the side panels - I have no ca glue at the moment but "No worries" as I used my revell pro plastic glue, I have found if I get it warm it melts the pe down onto the plastic and it does stay there ok. So its a start. OC. -
Most welcome Denis. should be enough Hot Dogs to go round I think there is a crate load coming☺️ OC. -
With me its just plain bockwurst in a soft long roll and fried onions - no sause or mustard ..........yummy. OC. -
Now were talking.........Yum scrum. OC. -
Got any Hot Dogs and Onions ? love them. OC. -
Thanks Jack. OC. -
Welcome EG. OC. -
Hiya Ken, it will be the Gloss Black Royal Navy one as in the photo above, as this is the exact type we saw together. OC. -
More than welcome Mike. OC. -
Lou, taken from someone elses description I quote - It was used from 1938 up until June 1940, half white half black, for observation of friendly aircraft from the ground. Remember that there was no country-wide ground control radar. Radar only worked looking out to sea, or at higher altitudes, initially only being placed on coastal sites . Tracking over the land, friendly or enemy, was down to the Observer Air Corps. It was replaced by Sky undersides, but in November 1940 the black wing was reinstated. I'm not sure when it finally disappeared, possibly not until the introduction of the Day Fighter Scheme, with undersides of Medium Sea Grey. OC.
Giving my figures a small break and changing subjects I have decided to drag this out of my old stock, its been sat in the cupboard for a couple of years - but I decided it would make a nice pre christmas build. The history behind this build is - where the admiral and myself used to live , we were on one of our first walks through the countryside when all of a sudden a low fast jet blasted over our heads just a couple of hundread feet above our heads, it really impressed the admiral and was the first fast jet she had seen. So on with the pics of the kit and an internet photo of the actual Jet. OC.
