Old Collingwood
  1. "Eye eye" glad to see someone else jumping into the same territory as moi - loverly job. OC.
  2. Thanks Mike, its paused for a bit ran out of spray paint. OC.
  3. Dont know why the kit makers have to split the heli deck like that 2/3rd along the heli pad - they could have made it all one deck (its the same with many modern warship kits like that in different scales). OC.
  4. Absolutley amazing considering it 1/350 scale thats the same scale as the moden warship builds in the forum - and we know how fiddly they are. OC.
  5. Really nice Job Denis, paints certainly do test us - but you pulled it off nicely. OC.
  6. Not much that doesn't go on here - if they make it - we will build it. OC.
  7. Murthy disguised as empty rattle can - it tricked me it said "Shake me shake me - I have enough inside" OC.
  8. Evening all, so back on these little fella's - painted the Red jackets on the first Three. OC.
  9. Very tidy work mate - you got those tree nails perfect not in your face just nice and accurate. OC.
  10. That is looking really nice - I too love the lines of the ship, we all panic over the first hull planking - thinking it looks rubbish - "boy I did with my Greyhound" but sanding is our friend. OC.
  11. Bit of progress (sort of) I took the wokka outside got the outdoor bench set up again with a box to put it on, got my rattle can RAF Green then after a warm up and thorough shake, I started spraying.................ups................splirt splirt got half the wokka done then it ran out😬 So as it stands its put away de gasing in the cupboard keeping the smell locked away, will have to wait now till the new year before I can finish it. Oh well I have my Waterloo figures to keep me out of trouble. OC.
  12. Thanks mate, they say the primer is the "Tell tail" as it shows up everything. OC.
  13. Every day you are making her look all the more sub like so wish @Kevin would say hi, he has a unique perspective on the subject and was not affraid of having several hundread feet of water above him.😉 OC
  14. Evening all, right Primer day - it was a bit fiddly as it had be done outside, the idea was to sit it on a box ontop of our covered deck bench, then spray what I could while walking around the wokka, then left it a few minutes to dry till I could pick it up and place it down so I could spray the underside, only issue I had was a bit of a run near the winch - I left it to dry for a few moments then rushed it inside still on the box and straight into our cupbaord. This evening I was able to check it out and give the run a light wet and dry - problem solved. OC.
  15. Great work Kevin, do the bricks strengthen the assemblies up much - give them some rigidity? OC.
  16. Evening to my band of following dudes and all who look over my little workflow - so I have started and completed the maksing ready for the primer/paint layers, the main entrance door was straight forward just Two doors joined together with tape then pushed inplace and held behind with blue tack, the other side window was covered with card and tape - the rear ramp area was covered with paper and tape and the upper ramp door secured with blue tack and tape and finaly the gearbox cutout has had some sponge pushed inside - so alreadfy now. OC.
  17. Thanks Ken, much appreciated mate, was you able to fly an F4 on one engine if you had to shut down the other re - bird strike? OC.
  18. Thats a fine looking ship - you did a fine job on here, looking forward to your next. OC.
  19. I remember the dust boxes that were fitted to S - 61 Sea Kings - I think related to when they went out to the Kuwait/ Iraq areas, I think they were not just screens but actual filters - they looked powerd as they were a physical box. OC.
  20. So - next to be done (1 paint/weather and attach the rear ramp, (2 temporary fit the upper rear ramp door using blue tack (3 temporary blank the open window on the other side (4 temporary fit the side entrance / Two stage doors with blue tack (5 temporary blank the rear ramp opening with paper/blue tack/tape (6 when all openings are secure - do a couple of primer rattle can pases (7 check the finish (8 If all is ok with the primer finish - start the Green colour coats again using rattle cans. OC.
