Old Collingwood
  1. Evening all, right Primer day - it was a bit fiddly as it had be done outside, the idea was to sit it on a box ontop of our covered deck bench, then spray what I could while walking around the wokka, then left it a few minutes to dry till I could pick it up and place it down so I could spray the underside, only issue I had was a bit of a run near the winch - I left it to dry for a few moments then rushed it inside still on the box and straight into our cupbaord. This evening I was able to check it out and give the run a light wet and dry - problem solved. OC.
  2. Great work Kevin, do the bricks strengthen the assemblies up much - give them some rigidity? OC.
  3. Evening to my band of following dudes and all who look over my little workflow - so I have started and completed the maksing ready for the primer/paint layers, the main entrance door was straight forward just Two doors joined together with tape then pushed inplace and held behind with blue tack, the other side window was covered with card and tape - the rear ramp area was covered with paper and tape and the upper ramp door secured with blue tack and tape and finaly the gearbox cutout has had some sponge pushed inside - so alreadfy now. OC.
  4. Thanks Ken, much appreciated mate, was you able to fly an F4 on one engine if you had to shut down the other re - bird strike? OC.
  5. Thats a fine looking ship - you did a fine job on here, looking forward to your next. OC.
  6. I remember the dust boxes that were fitted to S - 61 Sea Kings - I think related to when they went out to the Kuwait/ Iraq areas, I think they were not just screens but actual filters - they looked powerd as they were a physical box. OC.
  7. So - next to be done (1 paint/weather and attach the rear ramp, (2 temporary fit the upper rear ramp door using blue tack (3 temporary blank the open window on the other side (4 temporary fit the side entrance / Two stage doors with blue tack (5 temporary blank the rear ramp opening with paper/blue tack/tape (6 when all openings are secure - do a couple of primer rattle can pases (7 check the finish (8 If all is ok with the primer finish - start the Green colour coats again using rattle cans. OC.
  8. Thank you kindly Lou, they so nearly didn't get made - but it wouln't have looked the same without them. OC.
  9. Lou stays in the rafters as he gets the best view looking over our heads - plus he is closest to the "Heads" OC.
  10. Evening all - next on my build was a stage that I thought was going to be difficult - the engine covers, these little beauties have little mesh screens fitted into them - this is done (in principle) by using a paper template and cutting the mash to fit then glueing them into the gaps - "No Way" was this going to happen - as we know mesh is akward when trying to cut through the threads, so my idea and plan was to fit them each in Two sections inside the covers using the glue to hold them in place. So about Two hours later I have created Two engine covers - and glued in place. OC.
  11. Tom If that was me I think I would use different gradients of sand paper to shape the hull/tower - starting with a medium/coarse and going through to a very fine one - as you need to keep that wood as smooth and splinter free as possible, after that you could lock in the wood grain with a presever before detailing and painting. I suggest sandpapers as tools like rasps/coarse files can be a bit to rough and tear at the wood. Hope that helps a bit mate. OC.
  12. A bit more progress please find the winch, needs a bit of tidy up. fiddly thing to fit without guide holes etc. OC.
  13. Evening all, I managed to get the bottom of the wokka finished today - this consisted of plenty of blade aerials and the Three cargo hooks, the center one that can carry the most weight is folded up when on the ground (on mine) need to be careful not to knock any of these off while handling her. OC.
  14. Excellent I used to see a few of these (her sister ships) quite often infact they bacame quite a regular sighting - Here is a close up showing procedure Alpha. Top one HMS Monmouth, Bottom HMS Argyl. OC.
  15. Between you and Lou - "Blimy" can imagine a Full on play mayhem Nerfs and potato/tennis balls going everywere.😁 OC.
  16. Blimy Lou - can imagine you lot playing - play battle in your house with Nerf guns and mortars - bet your admiral would be pleased walking into the house - Full on battle of Lou's Land.😊 OC.
  17. All of us? wonder who the cheeky one is?😃☺️ OC.
  18. Certainly is Tom, I would imagine quite effective aswel - sat n the hover with fire in Three consecutive directions. OC.
  19. Was the same for me as a Ten year old with Scalextric slot cars on those tracks with the 12Volt connections from a transformer running through those male/female conectors that were a pain to keep in good order. OC.
