I'm the same with flying - ok if I dont look down out the window and have been ok when going through clouds as the obscure the ground - have flown in a C172 (4 seats) then a B707 (180) then a B737 (130) and last a DH Dove about 10 seats I think, the dove didn't help at the pilot said one of the engines had a slight miss-firing problem at the time (my face then)😵😨 OC.
Evening all, more progress - not much content but some good improvement, I painted the inside cover of the rear fuselage rotor area, then it was glued inplace and then a few gaps were filled and sanded, then on the same general area - the kit makers decided to make an acess cover panel lines be engraved - but in true life the gap would be about 2-3 Inches wide, so I had a go at filling the gap with my vallejo filler - hopefuly this will look ok when primed and painted. OC.
Enzo Ferrari by CDW - FINISHED - Tamiya 1:24 Scale
Old Collingwood replied to CDW's topic in Non-ship/categorised builds
Dont want to derail this thred but No Esprit 2.2 Turbos models have ever been made for some strange reason, you can get the Mk1's and Bonds Esprit - Sub and the later version with the GM motor, just No mk2's - S2.2, S2.2 Turbo. OC. -
Some nice masts there mate - and very tidy serving. OC.
- 436 replies
- vanguard models
- alert
I will be watching this with interest - I had been looking for a Lotus Esprit Turbo for years - but they just dont do one - this will be good. OC. -
Evening all, I got some really good progress on this today - Including a pic I promised from yesterday, after completing the bottom I then worked on the rear tail rotor panel that is at the extreme rear and goes from above the ramp roof upto the rotor head, its a One piece molding but had to be sanded to get it to fit, then a couple of gaps was created these needed filling with my filler and smoothing after, also the area where this piece joined needed some quite drastic sanding - this wiped out some of the panel lines, so I got my little flex straight edge and sriber - and set about re-scribing the lost panel lines. I then turned my attention to the front of the rear rotor area where there is some kind of machinery that is enclosed save for a small opening in the front - this was assembled painted/weathered and glued in place - then the cover was assembled and dry fitted (as in the pic). So here is the current situation - OC.
That is Brilliant with the figures. OC.
- 211 replies
- prince of wales
- tamiya
Evening all, I have the bottom piece in place now "Boy" did it take some positioning - its kind of cross shape long and narrow-ish tucks under where the nose section touches the frame and goes back as far as the tail gate, it sits on a few lugs but requires gluing the whole length along the edges, but first I had to do dry fitting and sanding to get it to drop in place - then the glue, while setting I had to manipulate it into shape correcting its hight - it had a few dips and highs, but after leaving it over night I was today able to sand the high spots and use filler on a few gaps and dips - then more controled sanding and wet sanding. I think it will be ok after primer and paint layer/s from my rattle can. Tell you what - the whole thing is quite sturdy now with some weight to it. Pictures tomorrow. OC.
Denis with the props (Lou / Mark help me with this) I would imagine are set up to only go into the fully flat 90deg position when in flight off the ground, I wouldn't be supprised if there is some kind of auto safety device where on the ground the props can only be set at certain limits of movement. OC.
When they brought out these kits I wouldn't imagine for one minute they would imagine them being super detailed to the level you have - you have transformed these kits into a thing of beauty. OC.
- 49 replies
- Lusitania
- Gunze Sangyo
Evening all, More progress with the Wokka - I masked up the front unit then glued it in place, when set I ran some filler into a few tiny gaps then I scraped the edges to get a smooth join, also there was a glearing gap above the canopy - I was able to find a strip and glue it there and fill behind it, after priming and painting it should look ok. So here is the current stage. OC.
