Old Collingwood
  1. Thank you kindly Lou, they so nearly didn't get made - but it wouln't have looked the same without them. OC.
  2. Lou stays in the rafters as he gets the best view looking over our heads - plus he is closest to the "Heads" OC.
  3. Evening all - next on my build was a stage that I thought was going to be difficult - the engine covers, these little beauties have little mesh screens fitted into them - this is done (in principle) by using a paper template and cutting the mash to fit then glueing them into the gaps - "No Way" was this going to happen - as we know mesh is akward when trying to cut through the threads, so my idea and plan was to fit them each in Two sections inside the covers using the glue to hold them in place. So about Two hours later I have created Two engine covers - and glued in place. OC.
  4. Tom If that was me I think I would use different gradients of sand paper to shape the hull/tower - starting with a medium/coarse and going through to a very fine one - as you need to keep that wood as smooth and splinter free as possible, after that you could lock in the wood grain with a presever before detailing and painting. I suggest sandpapers as tools like rasps/coarse files can be a bit to rough and tear at the wood. Hope that helps a bit mate. OC.
  5. A bit more progress please find the winch, needs a bit of tidy up. fiddly thing to fit without guide holes etc. OC.
  6. Evening all, I managed to get the bottom of the wokka finished today - this consisted of plenty of blade aerials and the Three cargo hooks, the center one that can carry the most weight is folded up when on the ground (on mine) need to be careful not to knock any of these off while handling her. OC.
  7. Excellent I used to see a few of these (her sister ships) quite often infact they bacame quite a regular sighting - Here is a close up showing procedure Alpha. Top one HMS Monmouth, Bottom HMS Argyl. OC.
  8. Between you and Lou - "Blimy" can imagine a Full on play mayhem Nerfs and potato/tennis balls going everywere.😁 OC.
  9. Blimy Lou - can imagine you lot playing - play battle in your house with Nerf guns and mortars - bet your admiral would be pleased walking into the house - Full on battle of Lou's Land.😊 OC.
  10. All of us? wonder who the cheeky one is?😃☺️ OC.
  11. Certainly is Tom, I would imagine quite effective aswel - sat n the hover with fire in Three consecutive directions. OC.
  12. Was the same for me as a Ten year old with Scalextric slot cars on those tracks with the 12Volt connections from a transformer running through those male/female conectors that were a pain to keep in good order. OC.
  13. Thank you Mark,, I was reading a small article the other day about ACH47s Wow they looked the business almost like AC130 Spooky's in heli form. Yep our little princess is doing better - still on the couch "Feed me dady - I'm too poorly to move" think she is milking it a bit now though. OC.
  14. How you gonna moderate from all the way up there - hope you have one of those long pointing sticks. OC.
  15. I should have worded that better - I meant the 70s style boots with big heals - good for extra hight. OC.
  16. Evening all, a bit more progress this evening - I have made and fitted the Two Flare defence systems and the other Two outer devices, a few more bits and bobs to fit before it can be primed. OC.
  17. Very nice work mate - with the shrouds I made mine the same colour for all, and with the spacing of the deadeyes I used some thick wire with a 90deg bend at each end - I used this to attach at both ends to try to get an even gap between the "Eyes" OC.
  18. And building paper mache tunnels hills etc - tried it as a kid (not very good though) OC.
  19. Fabulous work mate - looks so real. OC.
