3d printing crew figures
Old Collingwood replied to highlanderburial's topic in 3D-Printing and Laser-Cutting.
I couldn't agree more, but heck Im baised/biased even 😉 OC. -
Non-glossy CA??
Old Collingwood replied to rtropp's topic in Building, Framing, Planking and plating a ships hull and deck
I agree with Mike, a flat top coat will kill off any shiny areas from the CA glue, or you could gently scrape the area with a sharp blade or light sanding, this often does the job on my projects. OC. -
New member from Monterrey, Mexico.
Old Collingwood replied to Eugenio Treviño's topic in New member Introductions
Welcome indeed, you will love it here. OC. -
Evening all, thank you for all the likes and comments as always it really makes a difference. So on with the build - After checking the primer it was nice and dry with a fairly nice finish so I dug out my top coat (Tamiya Medium Sea Grey) - same as the primer outdoors and a couple of light coats waiting about a minute between coats, then back in the box. While the shar was drying I rigged up a way of holding both drop tanks - then outdoors again and a couple of blasts of primer, then about an hour later on went the medium sea grey. Then this evening I checked the main paintwork and it had dryed nice and solid - so I decided to do a bit of panel lining using my fine draughtsman pencil (same as I did on both my spit and mossy) then I de masked the canopy (its just dry fitted as it will be displayed open). Not looking too bad I think. OC.
Well spotted mate, its amazing how a few mill here or there adding up to 7mm can make so much difference, if I remember with my Greyhound build I had to do something similar, she is coming along just fine. OC.
- 322 replies
- enterprise
- caf
Evening all, a bit more progress today - First I took the Shar outside and gave it a couple of shots of primer, then I put it inside my tub closed the cover and took it indoors, then the eve I attacked a few fittings starting with the drop tanks and the sidewinders - so here we have Two 190gal D.Ts and Two 9Lima's. OC.
Not bad thanks Kevin, no probs it aint going anywhere.👍 OC.
- 322 replies
- enterprise
- caf
