Excellent work Kevin, that is looking so nice. OC.
- 322 replies
- enterprise
- caf
I have been thinking about doing her as ex falkland vet XZ-439/2, the reason behind this particular frame is - in 1982 just after the falklands war my late farther saw an add in the paper talking about an airshow at Farnborough where some ex falklands harriers were due to be there, anyway after soom pleading by me, my farther took me to the show and I got to see the Sea Harriers display there, one of them there was indeed XZ-439/2. Here are a couple of pics showing her at the show (the lighter grey one) Pics not mine they are off the net. OC.
Welcome back to the pack, right straight in with the canopy - the glass unit needed fixing down to the frame after both had thier edges cleaning, then using a tooth pic ultra fine tip - I dipped the end in some revell pro glue and ran it along the frame and pressed the glass down, then I sat it in place just dry fitting - its a start. OC.
Requires abit of adjusting to get the fit right no doubt - just apply the notion "test fit three times - cut once" just keep checking things before cutting material away - saves many tears latter (We have all been there) OC.
Hi all "Are you stil there", I am getting back on this very soon and giving my Waterloo figs a little break, I have sent off for some more Tamiya Surface Primer - waiting for it to arrive, in the mean time I will prep her ready for the primer, I will have to mask up the main sliding canopy then temp attach it down possilbly with some blue tack inside the glazing onto the top of the Bang Seat, then it will be a case of checking all over her before laying down the primer. OC.
Found these for you - http://pontosmodel.com/html/23009f1.html https://www.modelhobbies.co.uk/mk1-design-1200-hms-hood-armament-set--ms-20015-236712-p.asp https://www.modelhobbies.co.uk/mk1-design-1200-hms-hood-value-detailing-pack--md-20016-235424-p.asp OC.
Yep its brilliant for info, check sites like Ebay or direct for makes like Lion Roar, Pontos, White Ensign, there are quite a few companies who do detail sets. OC.
No problem at all - glad to help if I can.🙂 OC.
- 436 replies
- vanguard models
- alert
Excellent work - really taking shape with all those frames, should be built in no time with that giant building her😉 OC.
- 322 replies
- enterprise
- caf
I think they push them right against the bulkhead for maximum recoil so the cannon works at it best, if you wanted to show some life on her, you could also display a few recoiled back with tight ropes. Spledid work you are doing everything looks the part. OC.
- 436 replies
- vanguard models
- alert
Thought you might find this useful as it shows different mods to improve the kit - gonna be an epic build. http://www.hmshood.com/hoodtoday/models/trumpeter/trumpeter200.htm OC.
