Old Collingwood
  1. Evening all, Black roof done and the first bit of washes with the dusting of dry brushing still to do. OC.
  2. This is XV-666 in here prev role shot by myself some years ago. OC.
  3. I have also been measuring and cutting out a piece of ground works - in the shape of a small section of cobbled stone path, its only small no more than Four feet wide (In scale size) Im making it from my MDF type wood, the idea is that I will mark the cobbles then scribe them using my knife, then paint and weather them as required. OC.
  4. Are the Carlings sloted or just but fitted Tim? as I was wondering if you could just cut them back and re place them. OC.
  5. This looks so good - a very interesting kit. OC.
  6. Superb job alll round, I have seen this frame in the flesh when she was in RN use. OC.
  7. Evening all, - Pictures - base down - White applied and Black band and gate. Sorry about the pic quality - light and hand shake)))) OC.
  8. Tim are you saying that the Two rectangular cut outs (indicated by the Two Large Arrows) should be moved inwards to line up with larger cut out further forward in yoy picture? OC.
  9. Amazing work - so hard to find out the 100% facts as proof is burried - but damn good attempt is all we can do (like my own build) OC.
  10. Evening all, a bit more progress on the porch, I put a few coats of White on it - inside and out, and I have also made the stone base for it thats also been painted and weathered, the base was then glued in place on my dio. Next stage will be to paint the Black bottom same width as on the farmhouse, then the Grey on the slate tiles followed by some weathering. No pics as my batt was dead but will take some later. OC.
  11. Some of the scenery I need to tackle - stone paths - a wall and a sloping grass that I estimate will go from zero to about Four Feet at the edge of my dio. Some head scratching me thinks. Oh also the porch has been taken down in these modern pics of the net - even the original door has been bricked up and moved to the side. OC.
  12. Excellent painting - weathering Greg - they are not the easiest to get right - you have done a really good job mate. OC.
  13. Evening all, Roof tiles - Tick, Flashing - Tick, and dry fitted to check it fits. OC.
  14. Excellent work brother. OC.
  15. Eveening all, some more progress - I built the Two Trusses and a support rail, then I cut out the roof linings using some card, and have started to tile it using single strips of paper that over lap each other, I then pencil the gap in between each til where I will cut down to simulate individual tiles, also the top and edges will have some paper flashing over the top of the tiles. OC.
  16. Warm welcome to the family, thats a Super start, I also had this kit - it was gifted to me from an old neighbour after I tried to save his life with chest compressions after his heart failed, anyway as a thank you his wife gifted me this kit. OC.
  17. So next off I will make a couple of roof trusses before I make some mock roof tile panels (probably wont be individual tiles) OC.
  18. Not sure what its for Chris - but checking my airshow pics I can see its just on the one side. OC.
