Posts posted by Old Collingwood
On 4/13/2024 at 6:52 PM, Johngr said:
Too many very small items to be placed on the deck. The process will take some time but I have to say that the wooden deck is very nice even though in many places I had loosened it and had to re-glue it with super glue. It seems that the first gluing I did with the PVA glue did not have the result I expected. Maybe they needed more.
Stupid question I know - did you peel the decking off the plastic backing before placing it?
OC.
Just as a little teaser - I have placed my Two British Cavalry figures on the roadway just in front of the Two 95th rifles, I will take pics of them later.......
So this side of my dio is getting close to being finished - I will also add some loose left items like - muskets - backpacks - hats perhaps even a shoe or Two, then I will be turning the dio around and starting to work on the scenery on the other side.
OC.
- mcb, Baker, Darius359au and 11 others
- 14
Or........perhaps I could ease out the set gel water, and re do it but using coloured water gel - with me adding a few drops of wash to the mix before brushing it back in.
I could still do the dry brushing using the dust - sand in areas I can reach.
OC.
- FriedClams, Jack12477, mtaylor and 4 others
- 7
Morning all, more pondering s - I decided to play around with my water gel product that I made my pond with, the idea was that the wheel ruts in the road way would probably still had small pools of water sitting in them, - so (not thinking about colour) I brushed in a bit into a few of the wheel ruts, its thick and White at first but after about Ten hours it hardens clear. The problem is it just looks like a clear line not a slightly coloured water like it should have been.
Its got me thinking if I could do a very thinned dark wash all over the base - roadway etc (Yep includes trying to get in with a brush around all the figures) - then if I could go over the top later when the wash has dried thoroughly with my dry brushed sand dust colour as a high light.
Yep would certainly be a job and a half - but it might work to blend it all in together.
What do you think?
OC.
- Haliburton, FriedClams, Canute and 3 others
- 6
Hi there all, a bit more progress, I have re done the wall extension (well turned it over and added a small piece at the bottom) its been painted White and waiting to dry.
I also added some of my resin water in puddles in the ruts on the road way and against the wall (waiting for these to harden and go transparent)
I have also placed a few more figures in the shape of Four 2nd KGL casualties in the orchard.
OC.
57 minutes ago, king derelict said:
The photos really capture the feeling of the moment
alan
Thank you Alan, I had Two options due to the depth of field - focus on the 95th rifles or the French 3 feet away, and the house window view that was just a bit different.
OC.
Right then - I am not too happy with the size of the bricks or the height of the wall - so I may change things - watch this space....
OC.
- robert952, Darius359au, Canute and 5 others
- 8
2 hours ago, Darius359au said:
OC have you see "Napoleon's army 1807 - 1814 as depicted in the prints of Aaron Martinet" by Guy C. Dempsey jr? ,(the titles a mouthful😄)
It's the prints done by Aaron Martinet ,the prints were hand painted and show's pretty much every unit in the French army from Napoleon down through the Marshall's ,the guards ,line units, Cavalry etc, up to Waterloo!
Probably too late to help now😎😄 ,but depending how deep down the Napoleonic rabbit hole you are it's a great reference And it's pretty cool just to browse through it!
Richard
Hi Richard many thanks for the link, I have been using this aswel as Google search and other Napoleonic figure builders for research - http://centjours.mont-saint-jean.com/detail_uniformes_uniteBR.php?rubrique=U&uniformes=112&drapeau=
OC.
Incidently that section of wall is using larger size bricks, well that's my excuse and im sticking to it.
OC.
- robert952, FriedClams, Canute and 4 others
- 7
Evening all, so work has started on my little section of wall - I cleaned the edges then scraped and cut out an area of exposed bricks, and profiled a section of bricks that where just painted over at the bottom, then I painted in the mortar and then the bricks then the first coat of white to replicate the thick white paint.
OC.
- FriedClams, robert952, mtaylor and 6 others
- 9
Battle of Waterloo Attack on La Haye Sainte Farm 1/56 28mm
in Non-ship/categorised builds
Cavalry "Charge........"
OC.
