Posts posted by rvchima
Ship's Boats
The ship's boats comprise a 28' pinnace, a 24' launch, and a 22' yawl. Can someone out there please tell me the difference between the three? Is it the size, intended function, crew size, rigging, or something else? I finally acquired Lavery's excellent book, Arming and Fitting of English Ships of War, 1600 - 1815, and read the long section on ship's boats with great interest. But there was so much detail that I still don't understand the basic distinction. But that didn't stop me from barging ahead with construction.
The boats are built over MDF bulkheads.
They are single-planked with thin pear strips. This one has been sanded and filled with acrylic filler.
Here's what they look like off the base.
Then you twist the bulkheads off with pliers. VERY scary, but no damage. Sanding the inside is not fun.
The interior gets fitted with thin ribs. I used Tamiya tape to set the spacing between the ribs.
OK, full disclosure. The manual recommends using PVA wood glue for planking instead of CA, so of course I used CA on the first one. It went together OK, but after I filled the exterior and removed it from the bulkheads a lot of joints opened up. I got nervous and painted the interior with PVA. Big mistake - now the ribs would not stick to the interior with CA, so I had to use PVA on them, which increased construction time a lot. On the next two boats I used PVA on the edges of the planks and dots of CA on the bulkheads to act like pins. That's how I planked the main hull, and it worked very well on the boats as well.
Here are the three boats temporarily in their cradles on deck. Now I have to find a way to make the PE floor boards look like wood. That's a mystery to me, why Chris decided to make all these wood parts out of PE, when they could easily be laser cut from thin pear wood and stained to match.
It won't keep out water. I hope that it will keep out paint.
End of Hull Construction - For Now
The boomkins, seats of ease, and hammock cranes are all complete. Here are a few photos.
Boomkins and 2 seats of ease for 140 sailors.
The manual says to skip the aft hammock cranes for now because they will interfere with rigging the shrouds. The manual never gets back to them, and most other builders omitted them as well. I won't be rigging shrouds so I built them.
- mugje, DonSangria, wvdhee and 3 others
- 6
I had never heard of crows' feet rigging but saw it on a model of HMS Resolution in Anchorage, Alaska. I went on to build a model of HMS Endeavour just so I could rig crows' feet, and yes, I liked it a lot too. Beautiful work on yours!
Proxxon Sander (my favorite tool for removing laser char)
Ever wonder what's inside a Proxxon oscillating sander? Well mine started running erratically and making funny noises a few days ago, and it's only 7-8 years old! Can you believe it? So I took it apart (typical engineer). There's a switch, small permanent magnet motor, fan, eccentric, a big, heavy weight, and a plastic arm that oscillates the head back and forth. I cleaned everything out using my airbrush as a blower, added a drop of oil on each side of the motor and some graphite on the other parts. It should be good for another 8 years.
- mugje, DonSangria, chris watton and 1 other
- 4
Boat Beams
The manual says that if the rear beam hits the chain pump handle you can cut a little notch in the beam. Mine hit way too much for that so I gave it a good twist. It would never go around but no one will be able to tell. The handles definitely should be smaller.
5 hours ago, chris watton said:
You can give the wheel a few coats of spray primer, white or red oxide. This does help round off the edges. Wooden wheels are always way too thick and out of scale for 64th, metal ones almost as bad, and 3-d printed versions too fragile.
Thanks Chris. I tried to paint the wheel to look like wood and left the PE rims and hubs blackened. A better wood color would have helped.
Upper Decks, Railings, Cathead, Binnacle, and Drumhead Capstan
The fore and aft upper decks and railings are all complete. The aft deck took a little shaping but the forward deck dropped right into place. As before, I stained the decks with Minwax Golden Oak. The belfry, stove chimney, and some belaying pin racks are also done.
The stanchions for the quarterdeck railings are flat and need to be sanded round. I chucked them in a rotary tool and hit them with sandpaper wrapped around a dowel and taped to a stick.
Here's a view of that railing with the drum head capstan behind it and some more ladders nearby.
A lot of parts in this kit are PE brass that are typically cast metal or wood in other kits - eyebolts, belaying pins, etc. I had my doubts about them at first, but frankly they look just fine. However the ship's wheel is three pieces of PE glued up and it looks pretty flat. I considered buying a better wheel but would have had to resize the drum to make it fit, so I stuck with the PE. The binnacle is very nice.
Catheads - from the manual: "The holes in the bulwark are deliberately left smaller than required for alignment and part integrity when assembling. You will now need to open these up to fit the catheads. Use small files and a sharp blade to open these up to size." Easier said than done. I spent a couple of hours on each side filing those slots to within a hair of the railing and deck before those pieces would fit.
I agree with everyone - your planking is perfect, too nice to paint.
I used my electric plank bender the other day to fit one inner bulwark, and wouldn't you know it, I burned a finger pretty bad. I like to tease my son about all his football (soccer) injuries and now he's giving me grief about yet another model making injury.
Forecastle Beams Installed
My quarterdeck beams all ended up about 2mm too long and had to be trimmed on each end to fit. I did build the hull with the recommended jigs in place so I don't know why the parts were off. The forecastle beams dropped into place perfectly. I really hate to cover this all up.
- wvdhee, BrochBoating, chris watton and 6 others
- 9
Quarterdeck Beams Installed - 308 Hours, 122 Days
This was another satisfying task. I added the optional hanging knee braces below the beams, sanded most of the laser char, and finished all the pear wood with Watco oil stain. Yes, I know most of this won't be seen, but the pear wood is just so pretty that I can't resist.
- chris watton, Freebird, Erdict and 7 others
- 10
Breech Ropes
On 4/10/2024 at 6:16 PM, Thukydides said:You should still do them off model. Just you are limited by the fact that you have to run the ropes through the rings on the guns. I did some posta on my method in my alert log.
As suggested, I am rigging the breech ropes to the cannons off the model. I just use a single knot under the barrel with a spot of CA.
Then I glue the cannon to the deck.
The ends of the breech ropes must go through the eyebolts and get tied with much thinner thread using a single clove hitch. It is quite difficult to tie a clove hitch in that tight space, but it is MUCH easier to tie a clove hitch in your hands by overlapping two simple loops. There is an excellent animation of the procedure here. I hold the clove hitch with an electronics test hook clip, then put the breech line through the clove hitch, through the eyebolt, and back through the clove hitch. I grab both ends of the breech line with another test clip (red.)
So now I have a clove hitch around the breech line as desired. I release the yellow clip, snug up the clove hitch, add another single knot and a spot of CA for safety, release the red hook, and trim the ends. Fairly painless.
- Mr Whippy, Scottish Guy, schooner and 6 others
- 9
A New Base
The outrageous patina on my copper hull needed an equally outrageous base. I made one out of a light cherry with a Bubinga veneer, finished with Watco natural oil and several coats of Minwax wipe-on polyurethane. I have been ordering brass name plates for all my models from a vendor on Amazon. The temporary base will go back on while I am working.
I have just started to rig the breech ropes for the cannons. @Thukydides posted a brilliant description of a jig for rigging the cannons off the model here. However, the instructions for the Sphinx had me install the eyebolts around the gunports about 20 pages ago, so I will have to do that rigging in place.
- chris watton, Freebird, mugje and 9 others
- 12
Cannons
Not as painful as I thought - it took about 15 hours to build 20 cannons.
- Kenneth Powell, wvdhee, CiscoH and 1 other
- 4
- wvdhee, DavidG, DonSangria and 2 others
- 5
Cannons
In my last post I wrote how much I was enjoying this build but I'm not looking forward to this next part. At least she's not a first rate.
- mtaylor, Scottish Guy, mugje and 2 others
- 5
Chain Pumps, Hand Pumps, Grates and Finally the Stove
This part of the build is quite enjoyable. Each little component adds something interesting to the model. I built the stove almost two months ago and finally got to install it, and to jump ahead three pages in the manual past those instructions.
Interview with Chris Watton in Nautical Research Journal
If you haven't seen it already, there is a fascinating interview with @chris watton, designer of the Sphinx kit, in the latest issue of Nautical Research Journal. When I was looking for a new project I was debating between the Diana by Caldercraft and the HMS Fly by Amati. Moderator @ccoyle told me that I had a good eye because both models were designed by Chris Watton, and suggested that I consider the Sphinx. After reading the article I realize that I could have chosen any number of kits and that Chris would probably have designed most of them.
The only thing missing from the article is a photo of Chris' private collection. My house is getting crowded. Chris' house must be a museum.
- mtaylor, ccoyle and chris watton
- 3
8 hours ago, Thukydides said:
She is looking good, I like the patina, very visually striking.
Thank you Thukydides. The patina is more intense than I ever imagined but I like it. I was hoping for a visually striking model (even if not quite historically accurate) and it is certainly turning out that way.
By the way, do you have another name besides Thukydides?
Two Ladders - Never to Be Seen Again
Chain Pumps and Supports
- schooner, mugje, KARAVOKIRIS and 6 others
- 9
4 Hatch Coamings and 88 Cannon Balls
I figured it would be easier to place the cannon balls before the coamings were installed.
- KARAVOKIRIS, Mr Whippy, schooner and 8 others
- 11
The Flirt is attacked by a giant mythical beast!
- DB789, Doreltomin and wvdhee
- 1
- 2
HMS Sphinx 1775 by rvchima - Vanguard Models - 1:64 - 20 Gun Sixth Rate Frigate
The Boats Don't Quite Fit
The fit of the ship's boats has always been a bit "iffy," but after I added the wales to the their sides they were just too close for comfort.
And so, deconstruction.
I moved the two outer boat racks each about 2 mm outwards, and now everything fits comfortably.
