Everything posted by KenW
I've always wondered about tree nails. I'm sure they were used when most of the 18th century and earlier ships were built. But once the planks were installed, the hull was painted. So, the tree nails would be hidden under the paint. Same for nails, probably. So why go through all that trouble? I like tree nails on the decks. The decks were constantly scraped and I think the tree nails would be seen. Of course, when I was in England and took a day trip down to Portsmouth, I couldn't see any on the deck of the HMS Victory. I did see the tree nails on the USS Constitution in Boston.
The hull is faired; and the frame’s tick marks redone. So I started planking the hull. So far, I’ve completed 5 strakes. The strakes have been sanded and have had their first coat of Wipe On Poly. I should point out that there is a water-based version of Wipe On Poly, as well as a oil based version. And I feel that the oil based version is far superior. I probably will sand more and add more Wipe On Poly once the remaining 4 strakes are completed.
What is the title of May's book? Your model is outstanding as usual.
- 421 replies
- medway longboat
- Syren Ship Model Company
Excellent Mike. Your workmanship is stunning to behold. Cheers.
- 607 replies
- winchelsea
I haven’t posted in awhile because I’ve been working on my club’s group build of the Medway Longboat. But I’ve managed to finish rigging the guns. Not much to discuss. Everything went straight forward. I added eye bolts for the in-haul tackles which are stowed away.
- 122 replies
- independence
- privateer
Your model looks excellent! Very fine workmanship. And you log is a pleasure to read. Cheers.
- 152 replies
- medway longboat
Your model looks really good Ryland. I also used Doug McKenzie's spacing jig (and forgot to give him credit in my log). Cheers.
- 263 replies
- Medway Longboat
After fairing the hull, I lined off the hull using the paper strips and tape as per the instructions. However, today I went to a workshop at Chuck’s house for members of the my club that are participating in the group build. Chuck pointed out that my fairing of the hull was insufficient. Where the upper and lower pieces of the frames were glued together, one of the pieces still has char on it. This means that that piece with the char is actually ever so slightly ‘shorter’ than to other. This means that the piece with the char will not be glued to the planking - it’s to short. The problem is that if both pieces aren’t glued to the planks, there will be real problems when the center of each frame is removed. Either the upper or lower piece could split. So fairing must continue. So I removed the tapes and continued fairing both sides of the hull. The method I was using was OK, I had just stopped too soon. After a awhile, I could see that the fairing looked better. Of course, I must re-do marking each frame with the ticks from the paper strips, etc. and adding the tapes. But that is a small price to pay; a possible disaster was averted.
The keel has been glued to the frames on the building board. It worked just as the directions said with no problems. At our club meeting last Tuesday, Chuck said that care must be taken to insure that the keel is straight with no bend. He said he just eyeballs it. I’m sure my eyes aren’t as good as his, but it looks good to me.
Thanks Frank. I didn't notice this post until just now. Sorry I missed it.
- 481 replies
- rattlesnake
- model shipways
The stand looks great. What are the dimensions of the base, and what kind of wood? Thanks
- 421 replies
- medway longboat
Thanks Jeff, Dave and Chuck, as well as the 'likes'. Jim: Thanks as well - The instructions say it isn't necessary as the holes are only for a small piece of filiment. The size of my holes (a #78 drill) made for a tight fit. I don't think I could get the filiment all the way through and I didn't want a bigger hole. Cheers.
I’m taking part in the group build of Chuck Passaro’s kit of the HMS Medway Longboat. The kit looks to be well made in a way that most experienced modelers will be able to successfully build the model. The directions provided by Chuck are explicit and easy to understand. I’ve started the kit and have completed the keel. I followed Chuck’s instructions and everything went according to plan. I followed the ‘more advanced’ instructions for making the keel. One thing I did that was sort of unusual was the way I determined where to place the bolts at the bow and stern. I made a photocopy of the two areas of the keel with the bolts. I cut out the two places on the photocopy where the bolts were so the cutout fit the thicker keel part. I drilled the holes (using a #78 drill) on the port side since the plans show the port side of the boat. Then I just turned the small photocopy over and used the small holes in the paper to drill the starboard side. I hope I’m being clear in my descriptions. I don’t think my rabbits were 1/32 inches because the 4 thinner pieces were a little thicker that 3/32 inches. But the difference is so small I don't think it will be a problem. The kit is really well designed and I think it will turn into a great build.
The guns have been mounted on the boat. They look good; the only problem was attaching those hooks on the breaching line onto the little eye bolts. I also glued some deck furniture to the boat. I don't think these pieces will interfere with the task of rigging. I cheated and used diluted glue to keep the lines where I wanted them.
- 122 replies
- independence
- privateer
Thanks Mike. I’ll look into those Wolfcraft clamps. I enjoy watching your outstanding work. Cheers.
- 607 replies
- winchelsea
Thanks EJ. I’m watching you latest build with interest as well. Your work is excellent. Cheers
- 122 replies
- independence
- privateer
Mike. I'm always impressed with the quality of your work. What type of clamps do you use and how do you set them up? Too many clamps will leave indentations in the wood. Thanks.
- 607 replies
- winchelsea
Great build Bob. It’s really coming along nicely. Cheers.
- 359 replies
- prince de neufchatel
- model shipways
The gun carriages were already assembled and stained. Today I blackened the gun themselves. I used the process described by Dave (DocBlake) in his blog. The first step is to soak the barrels in Acetone for 15 minutes. Then soak for another 15 minutes in Muriatic Acid. Finally, soak each barrel for about 1 minute in JAX Black for Brass, Bronze and Copper Darkener. The result is a very metal looking gun barrel. The photo doesn’t due the color of the guns justice. It’s much blacker in tone and all the details can easily be seen.
- 122 replies
- independence
- privateer
