Javlin
Everything posted by Javlin
  1. I hear ya Craig I tried 3X on this one over the years and said this time it gets finished.The kit it not very exciting it's to have an example of the plane in the cabinet.I still need/forgot to apply the lens cover on the wing edge and under the wing found them doing the 110
  2. I have always used MM enamels all my life now they no longer exist there's was a little more grey. She will be Craig I think the WS=40cm/16" if memory serves me right..
  3. That's it guys done for the day good progress happened.
  4. Makes it easier still hard to believe that's about 17hrs of work but well worth EG.I have two Revell MkIXc each with a Quintas when the time is ready.I will be Spitfired out when I build 3x Tamys MkVIII,MkIX,MkXVIe and the two Revells.
  5. The IP and cannons are in getting time to close the fuse later tonight.
  6. Thanks EG cannons are just about to slide in.....
  7. I have been working this one over since I finished the Tigercat .The copit has taken some time paint is Mrhobby lacquer(seems a bit green for RLM02) and the dressing is Quintas liking these guys more and more.I am not far from buttoning up the fuse all in all probably 20hrs in this area when said and done.I still need to finish the cannons underneath the radio area.The fit looks good thus far right were it should be got to get some lunch 1:30 now been at it since 8AM.
  8. This is not one of my better efforts painting wise but she now rest in the cabinet after 3X attempts over the last 10/15 years.The LG installment was a PIA for one I usually refrain from using liquid mask but I digress just made me want to finish it and put it Away!!The fit of the kit was really great till you get to the gear it went downhill after that to were I really started losing interest...It is what it is! The Ki-9=1/48
  9. It adds Dan pulls everything into play.I am doing more displays/bases it seems I did one here for the S-100.
  10. The better/best way to fill a seam You mean they fired the A-Team That would be saasweeet I almost traveled that road with the Tigercat on the table now just because I have never seen one before and the excuse would be "it has hit the paint booth yet".Nice work all around Dan I have the Revell/SpecialHobby 1/32 in the stash.
  11. Good to see you around Mike I haven't seen you much on our sister forum either.This build and display was alot of fun in the wall cabinet now.
  12. Looking good Dan these crates look like the English version of the P-47 ...Brutes!!
  13. Thks Mark the kit is a little gem would work well in NMF. This is another quickie AMT's F7-7 2/2N most likely yellow development stage but boy silver is screaming at me like before she hit the paint booth for the yellow??
  14. This was really a quick build I did for a GB on another site it took me maybe a couple weeks while working the S-100 at the same time.The wood ids Birch for the base would of liked to redo it but it was my last piece.
  15. Gary it just blows the mind! @62 and still do not own one.........cellphone
  16. That's probably one reason Andy but also being 1/72 hence the reasons as you move up the scale things change if the modeler want's more PE and in your case Yahu.
  17. Dullcoated working out the final touches looks better in person will try some shots outside.The weathering of the hull to which only one side id complete ATTM has been quite enjoyable.
  18. I say maybe 2/4hrs left on this one.I have added angle braces to the starboard side to three stanchions,added chain to the stern and added chain to port.I still have three angle braces for port,flat coat,glass for Kalotte,anchor and rigging.The final stage will be the hull weathering and another flat it will be light.
  19. Like walking into that LHS just for supplies and I walked with the old Hase 1/32 Hellcat....futile.
  20. Some Nice lines abound on this Airframe Dan will be looking in from time to time.
