Everything posted by Nirvana
Risers in place and moving forward. Took the following two pictures outside, at the temp of 95°F / 35°C and rising.
- 335 replies
- 18th century longboat
- Finished
Very nice job on those cap rails.
- 100 replies
- model shipways
Janet, there is an issue with second hand Byrnes table saw. Extremely hard to find, and I am trying several sources, the one I found long time ago were even more expensive than buying directly from Donna and Jim.
- 335 replies
- Finished
Augie,as usual beautiful job with the command post. Now get the other salmon with my name as well,heard they are "lining" up to be caught. Enjoy your fishing, once you are back I will be gone for my three weeks of vacation.
- 2,191 replies
- confederacy
- Model Shipways
Still using my phone for documentation. The stem platform is re-done and I am much happier with the outcome than the first one. I would recommend everyone to add support underneath to avoid breakage.
- 335 replies
- Finished
Mike, there is a lot of sanding to do. The cap rail is 3/16" wide and that rail is to have a little lip over the planking. So each frame is to be less than 3/16". With other words a lot of sanding. A micro-meter is a good tool. Oh, btw nice progress looking very nice.
- 100 replies
- model shipways
Don't know what happened, but either the boat got bigger or the risers has shrunk. I am back to square one regarding them, another dry test show them shorter than before, even the width has changed. Thanks to the extra material from Chuck there won't be any problems only more work.
- 335 replies
- Finished
David, even with a small boat like this I am amazed what can be done. Thanks for the compliment.
- 335 replies
- Finished
- 335 replies
- Finished
For those of you not recognizing the items, these are the risers. Both were scribed and varnished to get the detail to stand out. Then I have drilled small holes that I enhanced with regular 6H pencil. Sanding is next and another layer of varnish.
- 335 replies
- Finished
Joss, Looking good. The stain (varnish) will not affect painted areas, oil or waterbased. Look at my build log, the paint even worked as a mask. As for the frieze, have the cap rail painted first, then attach the frieze and finally the rub rail (make sure you have it painted first), just like the instructions says. Painting or staining various areas is up to each builder of this amazing little boat.
- 33 replies
- model shipways
Augie, Thank you for the kind words. The inspiration for this idea is from several of you, including you Augie.
- 335 replies
- Finished
Thank you Steve. It is the first time I am trying trennelling. Forgot to mention the floorboards has gotten varnish. It's a visible difference between them and hull.
- 335 replies
- Finished
Treenails enhanced by using 6H pencil, then each nail varnished with 25/75 golden oak/natural
- 335 replies
- Finished
- 335 replies
- Finished
Kurt and all,to me that looks like scratch, the detailing is outstanding.
- 308 replies
- finished
- model shipways
- 335 replies
- Finished
- 335 replies
- Finished
The instructions doesn't mention anything about this details, however I thought it would be a nice touch.
- 335 replies
- Finished
Floor boards getting false tree nails. Will be enhanced before the 50/50 varnish mix is applied. Uploaded via my Samsung 5s.
- 335 replies
- Finished
I used regular printer paper as base. Titebond II doesn't have a high water content makes it perfect to glue wood to paper. The strips are boxwood and I used a carpenter pencil to darken the edges. The completed square will be varnished before shaping.
- 335 replies
- Finished
Mike, it looks good. Keep it up, the long boat is a fun little kit.
- 100 replies
- model shipways
