Everything posted by Nirvana
- 335 replies
- 18th century longboat
- Finished
Before I red paint the inners, I wanted to create the Risers, (I scribed them, accordingly to instructions) my scribing wasn't as close to the edge as Chucks' but I am happy with the outcome. I used the metal ruler and my extreme fine teeth saw to create the line, I was able to go over it three times, then I cleaned it out with a light touch of blade #11. It's amazing how the picture still reveal wood in the grooves. Scribing comes first, then after the soaking I placed the riser to shape it along the inside of the frames.
- 335 replies
- Finished
I am satisfied with the installation of the floorboards, using model needles for spacing got them tighter but still with a visible gap. The distance is the same on both side. Minimal sanding was needed as the floor boards had been adjusted before.
- 335 replies
- Finished
Jim, We will never get tired of questions, even repeated ones...... Dremel is good as stated before me, but hand tools is in many ways better, as you will have a feeling of how much you are reducing. As you will reduce so much less. I am using a combo of both, but not for keel. However, the latest Dremel Micro can do real low rpm's which makes it more controllable. If you are not used to such a power tool you can create more harm than greatness. Good luck
Oh, I forgot to mention that the boards should be sanded down in thickness at both ends. This will create an even end along with the keelson. It's not mention in the instructions but visible on the plans.
- 335 replies
- Finished
- 335 replies
- Finished
All this paint available
Nirvana replied to Nirvana's topic in Painting, finishing and weathering products and techniques
Spaceman Spiff, Found another update, The quality of the paint is the same, still manufactured in Japan but runs under the name of GSI Creos - Gunze Sangyo. There are some companies in the US selling their products today. The former company stopped the shipment of their product due to decrease of sale. (read Tamiya's) aggressive marketing along with Testor. Somehow the production was directed to the European/Australian and Japanese market for a long time, but are now back in the USA. The hobbystore chain I am referring to is HobbyTown, I don't know if it is up to each owner to decide what brands to carry but I doubt it. HobbyTown is big and has probably pulled some strings. -
I had the interior wiped with poly. This one comes from General finishes, While waiting for drying I did a test with the Valejo Red RLM23 see the strip to the left. I like the color as it has both a bright but also a little dirty tone to it. This is the color I chosen for the cap rail and the 12mm paint job on the inside. The first starboard floorboard has been shaped (slightly tapered) then soaked for 20 minutes. Using clamps with rubber head (no marking) I clamped the board down using pins for spacing. This way I got the shape of the bent until it is time for gluing. Realized that doing this before adding the cap rail has it's advantages.
- 335 replies
- Finished
Mark, Seems like it is the top-notch when it comes to paint. There are two versions of the paint, one acrylic and one lacquer based. This is what I found so far. Gunze Sangyo Aqueous Japan was early to adopt acrylic paints in modelling, and Gunze Sangyo has been in the forefront of the development. Gunze Sangyo Aqueous colours are still some of the finest flowing acrylic airbrush paints available. Thinning may be accomplished with either isopropyl alcohol or Gunze thinner, both producing super-thin, smooth coats. The solvent based is called Mr Color. -
Since last year I have been using and purchasing Valejo paint from my local hobby store. I like the paint as it has a high pigment. Now the store has decided to go with a new brand by the name of Mr. Color This after many request from other shoppers. When searching the web I haven't been able to find any link to the manufacturer themselves. The store is to drop the Valejo line in favor of Mr Color, so my question is: Does anyone have any experience of this paint? Does it hold the quality of Valejo?
Burnside, Here is the link to the real one, she is still steaming strong in Lake Mälaren.
- 50 replies
- mariefred
- nordic class boats
Jack, you certainly did a nice save and not giving up. You should be proud of the result.
- 41 replies
- model shipways
Keelson in place. After previous shaping I used CA to glue it down. At the end I didn't have any air gap between the keel and keelson, so all the tedious sanding had its great final result.
- 335 replies
- Finished
With the boxwood replacement from Jeff at HobbyMill I cut the keelson, soaked it for 20 minutes and thereafter pinned it down to the keel. It's not glued into place, this is only for shaping. The darker shade at the starboard aft side is poly-wipe-on. So easy to remove when not wanted, or painted over if needed. When removed the wood gets a natural luster.
- 335 replies
- Finished
Matti, I beginn wishing you Gott Nytt Ar. Wasa turned out amazing. A true masterpiece. I understand the mixed feelings. How are you keep her protected while building the case?
John, From the East side of the same state, a very warm I am about to enter the journey of building the MS Bluenose, I am awaiting deck planking from HobbyMill. As far as hull planking I am sticking with the basswood coming with the kit. Deck will get a combo of boxwood and maple. So I am looking forward to see what you are coming up with. :)
- 18 replies
- bluenose
- model shipways
Shaping the frames towards the end I have used a tool that I found at HobbyTown store, I found them (three in one set, #220 #400 and #800) useful specially with its curved edges. This way I won't get stuck on any of the frames and dislocating any. I have also used one of them on the inside of the planks to get a smoother finish. I was also thinking of painting the red part of inner hull before adding the cap rail.
- 335 replies
- Finished
Steve, Being a former drummer I understand the collection of "odd" things we can have laying around. That's a nice use of the grommets. Are you going to do some fills where the small grooves are in the grommets? Ha, , fills and grooves two terms used in music as well...... :)
- 308 replies
- finished
- model shipways
I bought a sample pack of veneer from Woodcraft (in store), over 20 assorted domestic and exotic species, altogether 20 sq.ft. Each sheet 12" long various width 5.5" to 7.5". Price USD 31.50. The sample pack will be part of a wood reference binder. The best with the sample, I can definitely tell what wood is useful (fine grain) and not. Thickness is 0.5mm
Number five was the correct size for me. Guessing printers varies a lot, as the supposed black for me didn't come out black even at the highest and best settings. It got a dark green/greyish tone. However, the pdf version is much much better than the provided in the kit. Both with the resolution and pigments. Chuck, thank you very much for providing a much better solution for us.
- 162 replies
- model shipways
There is a very nice review of Jim and Donna Byrnes machines available at this site
George, First of all, a very warm to A forum where all questions old as new will be answered. There is an on-going discussion regarding this in the following topic, Please read this topic, which I think you will find very rewarding. Personally, still not an owner, the Byrnes table saw is the way to go, yes you will spend more money but the tolerance and accuracy, along with future value of machine speaks for itself. Buy cheap and repeat it, buy Expensive and keep it!
Can i live without a BYRNES TABLE SAW
Nirvana replied to shihawk's topic in Modeling tools and Workshop Equipment
Shop vac I like to get, price wise not bad at all...... the little bigger brother only 50 dollars more. And much quieter than regular vacuum machine.
