Everything posted by Nirvana
David, even with a small boat like this I am amazed what can be done. Thanks for the compliment.
- 335 replies
- 18th century longboat
- Finished
- 335 replies
- Finished
For those of you not recognizing the items, these are the risers. Both were scribed and varnished to get the detail to stand out. Then I have drilled small holes that I enhanced with regular 6H pencil. Sanding is next and another layer of varnish.
- 335 replies
- Finished
Joss, Looking good. The stain (varnish) will not affect painted areas, oil or waterbased. Look at my build log, the paint even worked as a mask. As for the frieze, have the cap rail painted first, then attach the frieze and finally the rub rail (make sure you have it painted first), just like the instructions says. Painting or staining various areas is up to each builder of this amazing little boat.
- 33 replies
- model shipways
Augie, Thank you for the kind words. The inspiration for this idea is from several of you, including you Augie.
- 335 replies
- Finished
Thank you Steve. It is the first time I am trying trennelling. Forgot to mention the floorboards has gotten varnish. It's a visible difference between them and hull.
- 335 replies
- Finished
Treenails enhanced by using 6H pencil, then each nail varnished with 25/75 golden oak/natural
- 335 replies
- Finished
- 335 replies
- Finished
Kurt and all,to me that looks like scratch, the detailing is outstanding.
- 308 replies
- finished
- model shipways
- 335 replies
- Finished
- 335 replies
- Finished
The instructions doesn't mention anything about this details, however I thought it would be a nice touch.
- 335 replies
- Finished
Floor boards getting false tree nails. Will be enhanced before the 50/50 varnish mix is applied. Uploaded via my Samsung 5s.
- 335 replies
- Finished
I used regular printer paper as base. Titebond II doesn't have a high water content makes it perfect to glue wood to paper. The strips are boxwood and I used a carpenter pencil to darken the edges. The completed square will be varnished before shaping.
- 335 replies
- Finished
Mike, it looks good. Keep it up, the long boat is a fun little kit.
- 100 replies
- model shipways
- 335 replies
- Finished
My laptop died with poof and smoke yesterday with all the pictures on the hdd. This is the build of flooring for the aft.
- 335 replies
- Finished
Augie, I am pouring me a glass of milk to drink in order to celebrate this magnificent milestone and event. Beautiful done. Are you keeping a seperate time log for the build? Like the log provided in the instructions?
- 2,191 replies
- confederacy
- Model Shipways
Mark, thank you The extra boxwood from Jeff (HobbyMill) has been a good source for the testing.
- 335 replies
- Finished
However, Many of the bandsaws I have going through during past night, this are the ones in the range of 9" and 100-150 USD I found that all had the same type of motor - 120/240V, 2.5AMP comes with a 6TPI blade. Mostly what differs is the outer shell design, some has less volume (less resonance and vibrations) while other has a bulkier/squarer shape volumes. No matter when it comes to buy a saw in this size, replace the blade to better grade and screw down the unit (using water levelers) through a 1/8" rubber mat to a solid bench to eliminate vibrations and noise. Attach noses for vacuum extraction. Start sawing and hopefully you will have good outcome!
Looking at the picture uploaded verses the physical, this time the true one has a better shine. In the picture the coating has a rather flat finish. Once the friezes are added along with the molding strip I think this will shape up rather nicely.
- 335 replies
- Finished
I have added another layer of varnish had it dried - and removed the tape. In this picture you will find the difference on the planking. The top plank is regular boxwood untreated while the rest has the 75/25 ratio of my varnish. I like this as it gives the longboat some weight feeling. I could be wrong, but as Chuck mentions in the manual, this kit is based on one of so many thousands made. And I think no matter how we will do ours, in one or another way - all are right.
- 335 replies
- Finished
Essex - Process and corrections to the new Model Expo Kit
Nirvana replied to samueljr's topic in Wood ship model kits
Stu and all that are building Essex, There is an amazing book available, I have this one in my library. The book belongs to the series of "Anatomy of the Ship - The 32 Gun Frigate Essex" Author is Portia Takakjian. I found this book at Amazon at a price of 12 dollars plus 4 dollar for shipping and handling. Maybe a book to solve a lot of the mysteries around the kit or even better - to do from scratch. Some of the drawings are in scale - some in perspective (no scale) I.e explaining spar plan, oversized scaled plan of the capstan - 1:24 scale with all details. Even a line plan and structural arrangement along with frames is provided for the 30' barge she carried. I am not considering buying the Essex kit, as I have the Confederacy waiting.
