Posts posted by Ulises Victoria
Thanks Ulises,
And thanks Nigel.
I understand all of it.
And I must say...I love the idea what Nigel is telling you.
So let me see the final result
Sjors
Thanks Sjors. I just placed the vertical supports behind the planks I already have. Photos to follow pro'lly tomorrow.
One of the things you might try is filling in around the ports. Using balsa or another soft wood as a filler. I might take awhile but would probably be worth it down road.
David B
Thanks David. My problem will be to fill the gap that certainly will be between the top and next plank. I'll post some photos later.
Hello Ulises
If I remember right I think I first filed the metal frames down to the level of the bulkheads - then laid the planking on top of the edges of the metal frames. It seemed easier to me to "fair" the metal frames first.
regards,Mark
Thank you Mark. I think I will have more trouble with your approach. It may be more work, but I think that filing the metal frames after the first planking is laid, will allow me for a smoother finish.
I sincerely thank all and every response.
Ulises
- Sjors and FrankWouts
2
Nigel. Indeed. What you say about the vertical planks is something mentioned in the instructions. I did not do it because I felt the frames were epoxied and very firmly placed that I though there was no need to reinforce them, BUT... you are quite right regarding the support for the in-between planks. I may not be too late to start doing that.
Thanks for your comment.
- NMBROOK, FrankWouts and Sjors
3
Sjors:
I just don't understand the instructions, so I'm working just following my gut. I had to tear apart a few planks of my first attempt.
In my second try, I placed the plank that goes over the frames (painted red), then the one that goes under, and then 6 frames that go in-between those, which you can see in the second photo and are unpainted. Then I started cutting pieces of wood to the precise length to fit between frames. A snug fit to make the frames more stable, and glued side to side of the bottom plank . The metal frames will have to be sanded/filed down later to make them flush with the first planking. The problem I am seeing now is that the vertical distance between the top and bottom planks is not exactly the width of 2 of the planks, so a gap is going to happen between the upper plank and the next. I foresee a lot of wood filler to be used here. (sigh)
I hope this makes sense!!!
Update Sept 12 2014
On Tuesday 9th started with the first planking. You will see not much progress in 4 days, but this has been a real challenge for me. I definitely don't like this system of the metallic gun port frames. It makes things harder instead of easier, *in my opinion*. You are forced to plank the hull in segments between frames, and it's harder to do an even planking job. I prefer the method of "cut your own".
Anyway, I thought before starting that this was going to be a nice challenge, and I wasn't wrong. However, if I manage to do it right, the sense of accomplishment will be equally big.
I keep telling myself that first planking is some sort of "training field", so things are easily patched and fixed.
Thanks for visiting.
I thank you for your words Duff, but where did you see my carvings? I haven't carved a thing in my life, unless there is another meaning to the word "carving" that I don´t know?
Might try emailing the manufacturer.
Thank you all.
I may be too skeptic, but I have never heard of somebody receiving an answer from any manufacturer of ship kits.
Hello. If it's like the one I'm using, it accepts a wide variety of nails. The inner rod, the part that pushes the nail is magnetic, so that you can insert a nail and drive it vertically without it falling out of the tool. Obviously, nails made of non ferrous materials will not be attracted to the magnet.
Hope this helps
What??? I cleaned it before taking the photos!!!!
- CaptainSteve, dgbot, Bindy and 2 others
5
Mark. Here are some closer photos.
Also, comparing the piece of wood with the sheet of paper included in the kit with different colors, the wood looks close to what they call "Beach wood" which I think they mean beech wood.
Unfortunately my photographic skills are not top notch and the color in the photos may not be very accurate.
I'm still confused.
Thanks all for your input.
Hola linda.
Excellent work. Every new photo is a discovery of your ingenuity.
My congratulations, linda.
Why are ships of the same size and configuration rigged different?
If two ships have 3 masts with 3 yards on each, why they are rigged different?
Let's say I want to use Victory rigging plans to rig my Royal Louis, just because I like Vic's rigging better: Is it possible? What problems could I encounter? How many people could tell? Would that be a Capital Sin? Is this a dumb question?
Wow. Thanks guys. I have a few walnut blanks I use to turn pens, and that wood is a lot darker.
Will keep checking. Thanks again.
Hello Testazyk. I will be following this build really close. I have this kit in my stash and will most likely be my next project, as I love this ship.
Still a long way to go, though, as I am in the beginning stages of the Mamoli Royal Louis.
Please keep adding photos and advice to your log.
Best of lucks.
Ulises
I will really appreciate someone tell me what wood this is.
It is used in my Mamoli Royal Louis to second plank the hull in the area below the main whales. Previous builders of this kit may have a clue???
Information in the kit is very confusing. In some places it says it is walnut and another some strange names. I'm sure walnut it is not!
If not certain, at least tell me please a close match. I am a bit worried that the material included in my kit will not be enough to finish the intended plank job, as some other people has said already. So I want to buy if not exactly, at least a batch of a close match. I'm sure a few planks scattered in a different shade will not look bad. It may be the opposite.
Thanks in advance for any input .
Ulises
Make sure the ends are perfectly glued and try to use only downward movement with the sand paper, preferably mounted on a wooden block for support.
Hola linda!
Haven't visited your log in a while.
Your build is truly an inspiration. Hard to believe it is your first.You are doing a job that I'm sure some of the experts here admire and envy!
I know I do although I'm not one of the "experts"
Felicidades linda!
Thank you for all the replies. So... those wooden balls I posted in my first post would seem to be to scale to fit as the truck. So how would I attach them to the top of the masts? Just glue them on? Also how would I attach one to the "top" on the main mast?
The "balls" usually have a hole on them, so you have to file the upper part of the mast to a diameter such that it would insert into the ball hole. A drop of glue is all that's needed, and there is only one "ball" per mast at the very top. Not sure if the parts in the last photo are the 116 parts in your diagram, but in my opinion, not likely. 116 parts are more like... well... balls.
Hope this helps
The planking in the Soleil Royale photo is top notch. I would expect to do something like that after a few ( 4-5) easier kits under my belt, not before. As said before, planking is an art that you master by doing.
Best of lucks.
Hope this helps
I will wait for the Victory, whenever it comes out!!!
San Felipe by testazyk - FINISHED - Panart - Scale 1:75 1690
I definitely see this one as my next project. Good thing is, I already have it, and I got it really cheap.
