Posts posted by Ulises Victoria
Ah... I see your point and what JP meant.
Thank you my friend.
Thank you JP. (I guess you did mean Vasa, not Victory?)
In fact, I wonder if back then, using only hand tools, planks were even cut perfectly straight or masts perfectly round. My guess is that a bit of imperfection would render a model of ships of those years more realistic?
Cheers
Arthur! How nice to see you my friend.
Thank you for your kind words. Yes, size will be an issue once the bowsprit is fitted, but I will find a way around.
About the planking... the main problem was that because of the large central opening in the deck, I was not able to lay a continuous central plank line all the way from end to end. I thought that wouldn't matter, but in the end it did. No big deal here as most of those decks will be covered later.
I just saw your Vanguard build, and it's truly impressive!
Cheers!
I try to avoid CA as much as possible.
For wood to wood I use Titebond Wood Glue and can not be any happier with it.
For gluing dissimilar materials, like metal to wood, I use a glue called Repair Extreme, but I would use without hesitation, 5 min. epoxy if that was unavailable.
I use a minidrop of full strength white glue for my knots.
Thank you Anja!
That is precisely the site where I downloaded those photos.
I will contact them. Thanks again.
I don't think so. I have 25 photos of the same model that I downloaded from some site, but no mention of the modeler whatsoever.
The Mamoli photo is in my Avatar.
A few more photos.
I must say and confess that I am not 100% happy with my results so far. I just realized I am rushing things and I'm making some mistakes. So starting today I will slow down and do things more carefully.
First mistake: I placed those horizontal beams before sanding the deck. Huuuuge mistake. Nothing really bad happened, only more a more difficult and time consuming job.
Fitting of a piece of wood to form the curvature of the beams that later will make the deck curve.
Once the columns are glued, the piece of wood is removed and the curve remains.
Fitting of false deck slots against bulkheads is awful.
- CaptainSteve, Sjors, dgbot and 8 others
11
CA is Cyanoacrilate. Also known as superglue, crazy glue and some other names. It's a general use glue, which I don't like, but that's only my opinion. Not sure what brands would be available in your country.
Wood glue is a specifically designed glue to bond wood to wood. Known brands are Titebond (my favorite), Elmer's and others .This is called a PVA glue. Is thicker than CA, more like cream consistency and generally yellowish in color.
I have heard is more like a toy.
Raj: I am sorry I can not answer your question properly, since I am not familiar with either kit.
I advise you on the Phantom based on what I see in the web page.
Hopefully someone who knows the kits better can send you a better advise.
Hell Raj, and
See if this can help you.
http://www.modelexpo-online.com/Begin_Modeling.asp
The Phantom kit is a good one to start, and you can download a practicum for it. A practicum is a step by step instruction that takes you by the hand and guides you through completion.
Besides it's designed by Chuck Passaro, who is admin here.
El Arte del Modelismo Naval----B. Frolich
Ship Building simplified----- F.Mastini
Modelos de Arsenal del Museo Naval. A collection of the models in the Naval Museum of Madrid, Spain.
There is a Gorilla Wood Glue that does not expand and is just like Titebond or similar glues.
I would like to hear some one who has an opinion about Titebond vs. Gorilla Wood glue.
Retaking the initial thread...why bother with hot pots and odors and mixing other stuff when Titebond does a so good job? Our ships are not subject to the tensions of say a chair, a bed frame or other heavy furniture. My opinion is that using furniture glues in a model ship is overkill and extra unnecessary work.
BTW, I had to remove a couple of planks glued with Titebond. I had to scrape them with a chisel, and brought with them some of the wood underneath.
Just my 2 cents.
demonborger: You seem to know a lot about this build.
Instructions say, or that's what I understand, that after placing the lowermost false decks to plank from frame 2 to frame 6 and then from frame 12 to the end, leaving the area between frame 6 to 12 unplanked.
The way I see it it is exactly the opposite, as it's the area between frame 6 and 12 what is left uncovered by the upper decks, so this is the area that should be planked.
What are your thoughts?
Thank you very much in advance.
demonborger. I finally understood what they mean. They say do not plank the area between frames 6 to 12, but they fail to specify that this area will be planked later once you plank the hull and use the tips of those frames to build the bulwarks. Those tips will be cut then and then you proceed with the planking of this area, covering the broken frames. This however seems like it will be harder later to do an even planking job. You need to match two opposing ends. What I am doing is planking the whole false deck, and leave to later just the area near the edges of the frames that will be cut. I feel this will make a better and easier planking job.
- Jack Panzeca, Bindy, CaptainSteve and 6 others
9
She looks just swell, I must congratulate you on such an undertaking!
I hope I didn't bite more than I can chew!
I found this design. Looks pretty neat.
http://www.cornwallmodelboats.co.uk/acatalog/occre-workstation.html
Hello. I remember one if my first trials at wooden ship building was a solid hull one.A friend told me to lay the template on the hull and draw a mark with a pencil on the hull on the spots that I saw the template touching the hull. Sand until the line disappears and repeat. Long process but I think this is the most accurate. In all honesty, I have to say I have never built a solid hull kit, but this was what my "teacher" instructed me to do.
Hope this helps.
Thank you Dimitris.
Thank you demonborger... so it wasn't me...
Bindy: I won't call it a mistake... it's just a glitch.
Thanks for your comment.
I'm including a couple of photos of how far I am with the planking. I know I don't have to plank the whole deck, but I just want to do it.
I am skipping for now the planking of the edges of the deck between frames 6 and 12. Since I will have to break the tip of those frames after the first hull planking is done, to help form the bulwarks, I will plank that area after that operation to cover the broken parts.
Also I want to show you this notebook I had made by a friend here. This will be my written log of the Royal Louis. I will write here every step I do and when. Also to more accurately keep track of the time invested.
Cheers to all!!!
- edmay, CaptainSteve, ronald305 and 8 others
11
Buen jale, Karl. You are doing a tremendous job with a hopeless kit.
BTW, I met your daughter today at the fair.
Really fine lady she is.
Saludos amigo.
Who built this ship?
in Wood ship model kits
Posted · Edited by Ulises Victoria
I'm asking who built the ship.![:)](https://modelshipworld.com/uploads/emoticons/default_smile.png)
I'm pretty sure the kit is Mamoli's, as that is my present build, so I was trying to contact whoever built the ship in a very dim hope that he may be a member of this forum.
