AON
Everything posted by AON
  1. Done recovering from yet another eye injection, so having rested I've taken another critical look at the frames. Adjusted (lowered) the set mentioned by Paul and it made a big difference. I realized I had been focusing on the breadth placement as the top of the frames were cut a little bit longer than necessary. After measuring from the keel up to the chock split line (top of the lower futtock) it proved the frame should be dropped! So I learnt something else! Then I took this new knowledge and decided to lower two other frames a wee bit.... popped off more frames than I intended! Hope to have this back together properly with spacers by Friday for our next local club meeting.
  2. some updates! I purchased a 3D printer with the capability to print my cannon in one piece. I resized the insignia on my CAD model to the original proper size, converted the file to .stl, loaded it into the slicer program, loaded this "gcode" file into the printer and pushed print. (Don't I seem smart... it is all smoke and mirrors) 14 hours and 35 minutes later I had a cannon. I took it to our last club meeting and John, a fellow with years of painting model experience (with 1st place ribbons to prove it) suggested if I gave it two or three light spray paint coats of Beauty Tone Flat Black Enamel Acrylic paint it would eliminate the shininess, bring out the insignia and all my concerns would disappear. Here it is below with three light coats! 12 hour minimum drying time between coats as he recommended. I'll be taking it to our club meeting this Friday and then switching it out on by build. I've tried printing the cannon multiple times (tweaking slicer settings) at 1:64 scale for my other build (HMS Bellerophon) with no success. So I've ordered smaller extrusion nozzles (0.2 and 0.3 mm versus the 0.4 mm nominal size provided with the machine) in the hopes one will do the job at the reduced scale. They have been shipped from China. Now I wait.
  3. Regarding safer, easier methods of blackening metals... This is a link to the blog page of our local club website. scroll down to our 13th of January meeting and Ray describes what and how. https://modelshipwrightsofniagara.weebly.com/blog Regarding fishing line for faux bolts. I do this also, using black monofilament. It comes in different diameters so you find one closest to your scale. It comes in a spool that will likely do your whole build. I did not invent this but learnt about it here on the forums. I cut off a length (about a foot), rough it up with sand paper so my yellow wood glue will hold (something to grip to), wipe the end and sides in the glue and insert the filament in the predrilled hole. Then I cut it off with scissors and let it dry. I go back and cut it flush with a scalpel. I've tried to remove a couple and it was impossible!
  4. LOS = Liver of Sulphur. What I have comes in small "rocks". You mix a very small amount in hot water. The water turns a shade of yellow. You drop your copper part into it and mix it around for a few seconds, take it out, rinse it off to stop the reaction and your done. The part must be cleaned in soapy water, and rinsed off, and then washed off in (rubbing) alcohol to remove all dirt, grim, oil (finger marks) first. After the cleaning you handle the part with cleaned tweezers so as not to recontaminate it. There are safer, easier, liquid products that will oxidize the copper. But the item must still be cleaned.
  5. I've seen some sketches showing hooks on the ends of two breech ropes engaged in the rings of eye bolts on the cheeks of the carriage. I imagine this was followed by the single line wrapped around the cascable because in my mind the thrust and impact would eventually distort and tear the ring apart. If you chose to use the hook method I would mouse the hook so it doesn't jump off.
  6. Mark Regarding your thought of perhaps no seizing at all.... I can tell you from my experience that seizing a line or whipping was common practice and would not be given a second thought. The thought of the sight of an unkempt ragged cut line drove my kind nuts. In my full time job as a mechanical designer I once stood at our company display booth at a technical show in Chicago and backspliced a barrier rope because the sight of it drove me nuts. I would put good money down on it. They would want everything tiddley and squared away.
  7. Any other books I have are too early ( breech rope threaded through a hole in the side of the carriage cheek) or later (with the breech rope threaded through a ring cast above the button) and so they were rigged differently. Most do not show any seizing but seizing makes sense as I imagine with the thrust backwards a spring back forwards might likely occur and the breech rope might be thrown off. Was the breech rope turned over or under the cascable and then seized? I envision the large line (breech rope) would lay better (downwards) if turned over and seized under as Druxey recommended, otherwise it could be one more safety hazard.
  8. Mark, Do you have a copy of Anatomy of the Ship - The 74 gun Ship Bellona by Conway. Section J contains sketches on the armament. Below are two of the many. I am told there are some inaccuracies but I haven't the knowledge or expertise to say what is what. I will look look in a couple other books I have.
  9. Welcome Robert. I've been retired two and a half months, laid off (mutual agreement) seven months prior to that. I am more busy now than ever, chasing all the things that interested me and I hadn't the time before... and finding new interests. I find the days are too short and the nights too long. Back in 1990 I was off due to medical reasons and when well enough ... and thoroughly bored... I turned to model making too. I do know how you feel. My whaler build got me through the worst of it, gave me a focus. You will find no better support group (for modelling) than here... second to the "little boss" of course!
  10. Thank you Paul. I had seen that in the photo before posting it and went to have a look. It seems more likely a high angle thing... but having said that I hope I don't find you were correct after all. I guess I'll know for sure soon enough.
  11. I have gone down to the dungeon half a dozen times today trying to figure out why the width aligns perfectly with the plan below but the contour of the aft frames don't "flow" naturally into this square frame. Now that you've asked the question the answer to my concern is obvious! I need to check if it should have been tapered. Also, I was reading in TFFM yesterday about the addition of a cross support and was once agained amazed at the authors foresight... or possibly it was a lesson he learned the hard way. I will be removing the frame in a couple minutes. Thank you.
  12. First full square frame installed. #22Fwd. First time I used the square frame support. Clamped the frame to it with an elastic band. Now I start installing the spacer blocks near the top side to lock them all together.
  13. Fantastic idea. I have been worried about them popping off prematurely while fairing. I know exactly who to talk to about this.
  14. At 6:10 AM today I reached a milestone. I spot glued my last aft cant frame. Her sister (the mirror image frame on the starboard side) gave me all kinds of trouble because of the steep radius on the outside of the lower futtock that mates to the aft deadwood. I had been clamping the frames to the deadwood with a spring clamp (similar to a clothes pin) at this point, but the slope of this one caused the force of the clamp to push the futtock upwards, climbing out of position. I tried a bulldog clip above to stop the migration but it just climbed over that. I then tried other clamps but nothing worked. Finally I used the nose of a mini clamp to simply push the frame against the one behind and this worked. There will be two more frames ahead. They are made up and need some sanding, drilling and installation of the faux bolts through the chocks first. The second last frame is another half frame whereas the last frame to install will be the first full square frame, first to wrap over the keel and not be setting onto the stepping line. It's lower futtock joint was a real treat as a new challenge... I had to do the one half twice to get it correct. Once I have this in place I will install temporary spacer blocks near the top of the frames to stiffen it up for sanding.
  15. Our next meeting is presently scheduled to be on Feb 10th. I will miss this meeting due to a scheduled injection in my eye. The meeting falls in my recovery time. They are discussing rescheduling this meeting (no, not for me) and if so I can ask then, but I feel they (David and Greg?) simply haven't decided as yet. I am sure I will have an opportunity to ask David, but I imagine it takes a bit of effort before they can make a commitment.
  16. At this point I am still roughing out. Started by cutting a small block of boxwood (Linden) and marked off the center line, then traced the outline of the image on all four sides. Presently removing down to near proper depths to reveal a block 3D image. Then will come shaping. Likely I will do the heads first, then the arms and wings and work down.... but today I have to glue another frame on my build and then cut more slats, plane to thickness, trace and scroll out yet more frames.... one quadrillion to go!
  17. Regarding progress on the figurehead... I am leaving the larger version for the summer but did start the smaller version. The big one is a nice project for the outside patio. The small one is my first stab (spear pun intended) at such a tiny carving. Nothing to brag about as yet. It will likely become kindling and be replaced by a second and third try. I started with my dremel but do not like dealing with the "fur" it creates so I've reverted to my miniture chisels and knives. It is a part time project... forcing myself to walk away and think about the next slice before I screw it up too early in the game. If this one becomes a keeper it will be a fluke. I noticed Admiralty Models is considering having a carving seminar in the future. Not sure if it would be held south or north of the longest ungaurded border... but it got my attention and I am waiting for more news.
  18. Good morning all. The mention of a "pool" type water collection area over the quarter gallery to provide flush toilets for the officers caught my attention. In my research on "pissdales", there size, shape, locations onboard ships of the line, I found the following... In Joe John Simmons III thesis entitled The Development of External Sanitary Facilities Aboard Ships of the Fifteenth to Nineteenth Centuries for his MA in Anthropology at the Graduate College of Texas A&M University dated Dec 1985 he states the following (see screen capture from thesis below)... As the Bellerophon was completed in 1787, she therefore did have this "pool"! Very interesting.
  19. Short update and more. If you're visiting you are probably wonder where had I gone and what have I been up to? Well I am back on my build, have been for weeks. I can proudly say it no longer bothers me to remove frames. It used to tear at my heart and soul. Lord knows how many times I've put them on and taken them off in the last few weeks. I do not give it a second thought anymore. I have gotten frames installed past the location where I last stopped before summer. To recap, I had taken them all off back to the Forward Fashion Pieces, and then I swung my hand over the model and snapped off one of the two forward fashion pieces. It has been remade and installed and it is all now looking good with good alignment. After too many removals and re-installations my CDO (OCD for others) is satisfied. The plan is that I will be putting all frames in (sanding to shape when the aft cant and fore cant frames are installed and then again when those between are in) then marking off the gun ports, then removing frames individually, cutting the gun ports and notches for the cills, and finally replacing them as I go along. It will be a long process as I have many interests and diversions and so do not seem to advance as quickly as other modellers. I will only post when I've something substantial or worthy to look at (or am stumped and need advise) so do not think I've gone for good if you don't see a progress report for awhile. Building and installing frames is repetitive work. Meanwhile I have been lucky enough to have had an opportunity to review all but ten of the 150 issues of the Model Shipwright Magazine (1972 - 2008) and have scanned numerous articles, tips and tricks, etc. that caught my fancy. I will be getting a few more next month. From these I got the idea of a hardwood cutting (sawing/chiselling board). So Yesterday I made one. This inspired me to make a holding setup block for my protractor to free up my hand when setting the adjustable bed on my sander. I had tried numerous methods from clamps to different style protractors but the one in the photo below is my favourite and now I can have one hand on the Allen Key and the other holding the bed. I also attached one photo of my build table as of this morning. Before Christmas I had built a 1:12 scale 9 pound naval cannon (posted on the forum). The cannon and balls were 3D printed for free at the local library. After several attempts they got something I could use but it was in two halves (Breech/Muzzle) and I had to 2 part epoxy glue it together. I found the insignia difficult to see through the Plexiglas case so I had increased the size and finally coloured (painted) it to highlight so it would stand out. I have since purchased a 3D printer and have printed a one piece cannon (1:12) with the insignia at the proper size. One fellow at our club at our meeting earlier this month told me how to clean up the plastic a bit and paint the cannon with an acrylic flat black spray paint. He says the insignia will likely be more noticeable if flat black versus the shiny plastic. So I will be attempting this. Meanwhile I've been trying to print it at 1:64 scale. My first few attempts were a disaster. Today's attempt was better but not quite there yet. Too many adjustments to get it right for the small scale and specific type of PLA plastic... the learning curve. The picture below shows my one piece 1:12 print along with the printer attempting the 1:64 in the background. I apologise for the long story but you may not see another post for awhile.
  20. She's white up here also. Guess your getting our left overs! 😂 Edit😆 My mistake is coming from the southwest We (Niagara Region in southern Ontario Canada) are getting your (USA) left overs 😥
