HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
exactly Tim..........everything has it's moment.   never heard of un-cure,  but if you just stripped the paint.......then that's no big deal.   just paint her back up and you'll be back to square one in no time  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye,
Here is the link for Model Expo's CA un-cure.  http://www.modelexpo-online.com/product.asp?ITEMNO=MT161
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
so....the plot thickens.......I'm thinking that it did a bit more than remove paint.......am I right?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Yes, 'The plot Thickens', photos to follow shortly!   :huh:
Tim
Tim
Future Build:
Completed Builds:
Member:
The first part I glued to the chart house was the Dead Light, no problem with this even though they are extremely small and a real very to work with.
My next step was to assemble the side window frames.
I was successful attaching the starboard window at the correct height, the port window set up to quick and it was attached too low on the chart house.
The same error happened while attaching the forward chart house windows.
As you can see the port window is out of line and needs to be reattached.
Cheers,
Tim
Edited by Timothy Wood
Tim
Future Build:
Completed Builds:
Member:
so,  you need to remove that one as well.    would it help you,  {repaint and make your marks}  if you were to make a jig for the height that the windows should be at.  just a small piece of flat stock cut to the height that the frame should be.  make the marks for the centering and with the structure flat on the table,  lay the jig against the front of it.   locate the part using the centering marks and the jig.   there is also slow setting CA out there on the market.   what were you going to put in the frames?  darkened cello?   you could also use the same jig on all the windows,  so they will all be at the same height.
Edited by popeye the sailor
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
This is th first I hve heard of the CA remover striiping paint.  Hopefully it did not eat into anything else.
David B
After some sanding and a quick coat of primer it looks much better.  I admit I still have work to do on the paint to smooth out many rough spots but it isn't anything that can't be overcome!
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
For the color for the inside of the frames, I believe you hit the nail on the head.  Darkened cello sounds like a good choice!
Tim
Tim
Future Build:
Completed Builds:
Member:
Tim,
The detail on that little structure looks fantastic. I've never worked with photo etched brass, but think it must be difficult to work with, it being so thin and fragile (appearing). You've clearly got a good technique going with it. Those details all look quite realistic and to scale. Very nice update!
Cheers,
Elia
Elia
Rose Valley, PA
Arethusa: 1907 Gloucester Knockabout
Glad to see the ELCO back, even if you are having problems.
Bob
Current build:  SS_ Mariefred
you came through your problem quite well!  the structure looks awesome  ;)   if you have any floppy discs lying around, the disc filament would be perfect...........look at Peter Visser's build of the Zeechouw.  it works quite well  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye,
Sorry to say, I havn't even seen a floppy discs in 'Years'......  :o
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Tim,
Cheers,
El
Ela,
Thanks for the nice words, I'm not so sure about the technique though.  Its more like trial and error!
Tim
Tim
Future Build:
Completed Builds:
Member:
Alfons,
I have to agree with you, it gratifying to see the pieces come together at each step!
Tim
Tim
Future Build:
Completed Builds:
Member:
Tim I was reading through your log.  Starting about page 8 you are missing quite a few pictures.  The depth charges your friend helped you with were the first missing I believe.  I thought you might like to know.
Walt Biles
  • 2 months later...
Tim,
I have some floppys if you need one
John
John
Member: Hampton Roads Ship Model Society
Current Builds: Tugboat Dorothy  Newport News Shipbuilding Hull #1 (complete)
                           Iron Clad Monitor (complete)
                           Sardine Carrier which I will Name Mary Ann (complete)
                           Pilot Boat John H. Estill Newport News Shipbuilding Hull #12 (my avatar)
                    Harbor tug Susan Moran
                    Coast Guard 100' patrol boat
                           Light House Tende Beech (complete)
It's been quite some time since I've made a post, so I figured I better make a quick update!
  • I did manage to get most of the 20mm complete, still have to attach the shoulder rest to the main unit.
  • Completed building the helmsman's enclosure and searchlight platform, (It still needs smoothing with sandpaper before the final coat of primer).
  • Constructed the machine gun mounts, (They still need some cleanup work and a coat of primer).
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Dave,
The are made from Britannia metal, the sights are photoetched.
Tim
Tim
Future Build:
Completed Builds:
Member:
Thanks John,
Sometimes the "Real World" gets in the way of fun!
Tim
Future Build:
Completed Builds:
Member:
I hear you on that! looks good though.....also glad to see your still working on her. :) nice detail work!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Greetings,
A couple of quick shots to show the progress on the Chart House and Cockpit, I finally installed the depression cage around the forward 50 Cal.  It wasn't an easy gob and I didn't do a very good job of it
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Why do we always criticize ourselves so much?  I think your work is great but mine is . . . oh well.
Bob
Building the frame around the windshield with .002 plastic strips.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
I quite agree with Bob.  Looks great from here.
