 The rigging of the bowsprit is now pretty much complete - quite the mess of ropes! Most of the sail handling lines were installed with the lines running through the blocks with a toggle on the ends to keep them from pulling through the blocks001.JPG.aa355c451c24dcb57615143ef3201c7d.JPG
current build - HMS Vanguard - Model Shipways
Thanks Pete . As you know,it was quite a challenge to figure out the drawings - thanks for the help.
Mark,
Yes indeed very impressive work! A pleasure to follow along.
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
super job on the rigging!   very neatly done  :)
Edited by popeye the sailor
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Another small update - the topgallant & topsail yards are now mounted after fastening all those tiny blocks to the yards. The lifts are only done on the topgallant yards - the rest will be done after all the yards are mounted. The braces will be about the last thing done - with them in place it`s really hard to get my hands in to do other rigging. The topgallant halliards are belayed to deadeyes at the mast tops & the topmast yard halliards for the fore & main are belayed to the chain wales. For the ribs & parrels,I had some ribs left over from a previous build & the parrels are from the bead store(I never throw away leftover parts & wood). Thanks for looking in.
very nice rigging :)  neatly done.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
A little more progress - the foremast yards are all fully rigged(except for the braces which will be added later). I added 2 braces to the spritsail yard which were not shown on the plans - I don`t know how else they would keep it from swinging around without them. Also added the sheet lines to the spritsail yard & the tack lines to the fore yard. The foresail sheet lines will be added later also. That`s a lot of ropes coming down to the deck!
Mark,
The following figure is from R.C. Anderson where he suggests that the form of spritsail yard bracing  (only the starboard shown to keep things 'simple') was typical in English ships around 1690. Just another piece of the jigsaw.
Pete
Edited by piratepete007
word omitted
Well,silly me for not reading Pete`s notes carefully:default_wallbash:. Re-did the spritsail yard braces. I did simplify them slightly as I could not get the aft block under the top installed - just not enough room to get my hands in there.
Edited by marktiedens
yep...and then you ask the admiral what's for supper...........she says,  spaghetti!  :stunned:   awesome rigging there.......and that's just the bow and the foremast!   wait till you get to the stern........your gonna look back......."did I do that?!?!?!?!    amazed with your rigging....looks so nice!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Pete - I tend to get in a hurry - That`s when I forget to read your well researched notes & have to do things over!
Thanks Popeye - I`m already wondering how I got this far without totally messing up.  No admiral here,but I like spaghetti anyway:P.
Mark,
Lower main yard under the platform = brilliant work!
PS: are you using whom I think for blocks and ropes? Don't remember if you mentioned your source.
Under the table:
Completed:
Vasa-Corel -
