Great detailing.  Watching builders like you helps us all.
Bob
Current build:  SS_ Mariefred
druxei, captainbob   thanks .
Work continues with the construction frames and windows on the upper deck.
I made brass frames 2mm square profile that I worked a little.
I used the windows tinted ABS 1 mm thick.
A beautiful evening still will want.
Adrian .
Good evening for everyone.
The work continues with the exhaust pipes, the construction we made from brass tin everything was tinned and for the hinges we used M1 screws. Finally, the exhausts will be painted in chrome.
A beautiful evening still I want you.
Adrian
Good evening for everyone. Today we finished the railngs on the command deck.
It worked harder because at first I used a 20 watt soldering hammer, then I called heavy artillery and used a 100 watt soldering hammer.
All the best and a beautiful evening I wish you.
Adrian
Adrian .
Hi Adrian
I'm definitely enjoying watching you put all of those details on your ship.  You're definitely a master craftsman, that's for sure.
Nicely done!
Cheers
Patrick
21 hours ago, Omega1234 said:
Hi Adrian
Nicely done!
Cheers
Patrick
Thanks for appreciating Patrick , on the scale I'm working on , I'm forced to do all the details, even the money in the captain's pocket.
All the best .
Adrian
Good evening for everyone, for today we've worked the ship's antennae.
The whole construction was made of brass pipes and brass profiles, which is difficult because of the small size of a few pieces but in the end we finished well.
A beautiful evening still.
Adrian
Good morning to everyone, the work continues with a few tracks from the ship's bonding facility mooring bollard and quarter bollard , And one piece at the ventilation installation extractor vent . Everything worked in brass and copper wire.
Have a nice day .
Adrian.
Good evening for everyone, because I'm working on a generous scale today I've built the welding cord on the side. For this we used styrene profiles, plastruct 90879. The size of the semi-round profiles is 0.8 mm.
Adrian .
Hello everybody, today we've finished two more parts on my model and I'm called boat hook . I also worked with metal, my favorite brass with copper wire. Because I am in the end of building I will make a list of what I have to do.
Have a beautiful night.
Adrian.
Very nice work on the details Adrian.
Michael
