Those sacks do look great!
I have just accepted that gluing myself to things with CA glue is just a part of the process. It is a step located somewhere between sanding and installation. Hahaha!
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Hi Don thanks :)  Not far to go now. Still have some wooden bowls to make and hammocks that are suspended between the overhead beams and some Cannon tools and the cannon ball racks to fit to the decks then i can do the upper deck, but not too much to do on that as show in the box picture in post #1
Better late than never. I just picked up this kit, but it might be a while before I dive in. Lead on Bob.
Hi Bob.
I like the sacks.
Very nice work. Nice details that sets the gundeck for realism.
Keep up the good work.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
 Hi Mike
            Once you start it double check all measurement as the book and the plans give different ones for the same parts, and on some parts no measurements at all, the table and benches for example no measurements at all :huh:
Edited by Cobr@
Nice work Bob. nearly there
The rest apart from the bowls ( which are the hardest due to size) is really easy.
I found that gluing the 4 edges of hammocks with PVA glue and then soaking them with a 50-50 pva solution stiffens them up nicely to work with.
The size for the hammocks as specified in the plans are correct in this instance.
Thanks Paul
           Not having too much trouble with the tubs and bowls, mainly because i didn't use the Balsa as the main support pillar i changed to a more rigid wood made it a lot easier.
Thanks for the heads up on the hammock sizes. Don't want mine stiff i want them to hang naturally with a slight curve in them. Also i am going to fit them lower than recommended as the recommended place would have the poor sailor trying to sleep with the gun port lid rigging across his chest and a massive block smacking him in the head :D
And as this kit is only a representation and nowhere near accurate i have also altered the size and placement of the cannon ball racks, this allowed me to center the Bits with the gratings and fit regular sized planks not small filler ones as the instructions say
Edited by Cobr@
Hi Bob.
I like the sacks.
Regards Antony.
Thanks Antony
                       The sacks are one of the easier thing to make once you get your head around what the drawings are meant to be depicting :)
After looking at them for a while i didn't like the knots in the outer sacks so i removed and retied them, they look a lot better now :)
Made up some of the tools and the baskets. The parts in the instructions to make the 4th tool were not in either kit which makes me think the instructions are not correct again substituted some walnut dowel for one tool instead of cloth :huh:
Made the 4th tool from other parts and fitted all tools to the racks, and placed the baskets on the table to fill it a bit.
Nice, very nice!
Respectfully
Makes me want to dust the box off and get started!
Great work! Those tools look fantastic. Bowls look great too. How hard were they to put together?
-E.J.
Thanks EJ :)
                       They got harder as the sizes of the tubs, buckets and baskets decreased, until i substituted the Balsa main support in the middle for a more sturdy wood, then it was more repetitive than hard, but that's because i was making 2 sets of everything :D
I have just read your build and I am sure this kit will be on my wish list.
I watched some time ago already this kit in my Modelshop, but at that time I did not buy this, but reading your build triggered this again.
thanks for giving me the last hint to start with this kit also
Jan V.
current build: Vasa-1628 Corel / Battle Station Mantua/Panart,
previous: Statenjacht / Cross section HMS Victory / diorama shipyard
Hi Jan :)
                  It's a nice kit, pretty easy to build because of the large scale, you just need to sort out the differences between the plans and the instruction book because they contradict each other in places  :huh:
Thanks Paul :)
                           Yep they do get a bit fiddly at that size so i reduced the size of the cord around them to 0.5mm which worked much better with the smaller bowls. Colour is just natural Tanganyika, didn't want any more Red Ochre  :huh:
Go for it, you can't have too many builds, it's impossible :P
many builds = many workbenches
I have one of those but not the other.
But seriously, my dad has been laid up for over a month now with no end in sight. I have considered taking a kit to his place and doing it with him. This might be a good candidate, especially because of the larger sized parts. Of course that means hauling my tools over there.  Has the build required any odd tools or supplies? Just the usual stuff - cutting, gluing sanding? Any need for power tools or soldering?
Thanks Bob - I think this one will do nicely.
I'll agree with all others about the kit being a nice one, but your workmanship is ultra fine. Very cool Bob
Not trying to steal your show Bob, but your fine work and great log have been enough of a push to get me started on this one.
Thanks.......
