Nice save on that first piece, Kevin! However, if you had used PVA, rubbing alcohol would have made removal of the part easy. Was there a particular reason you decided to use epoxy?
Great video, Kevin. Two suggestions to improve my version. Replace those bolts with threaded knurled thumb screws and place brass washers where the bolts enter the jig as the constant tightening and loosening of the screws can deform the wood. It'll speed up the process considerably.
Edited by dvm27
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Great idea about the knurled screws but they will be almost impossible to find here in Trinidad. I do have washers on the screws. The wood is an extreamly hard wood which i threaded then put  CA so it should last a while. I am in New York next month and will try to find the screws.
I love your videos,  I have been building early U S naval ships off and on for almost 50 years, but I always find something of interest in your work.  I have a question,  in one of your videos you were making thin dowels.  The tool you were using,  did you make it or did you buy it somewhere?  You are doing an excellent job on your ship.  I greatly enjoy watching your work.  Thank you for posting it. - Hal
I have decided to reduce the end at the stern on strake 7 to 5” instead of 10.5” so that i end below the top of stern keelson. I have noticed in one of the builds that the end was also reduced to two strakes treated similarly to the front of the stemson. Maybe i should have curved #6 more at the stern end!
