I am currently buidling the TITANIC, Mantua scale 1:200. This model will be completed with PE-parts, such as windows, railings, ladders and more little stuff. Much information comes from the Titanic Research and Modelling Association,the book " RMS Titanic, a modelmaker's manual" by Peter Davies-Garner and CAD-drawings by Robert Hahn.
Here some pictures of what has been done so far :
fixing the frames and start with planking the hull :
funnels with the rivet-pattern :
lifeboats with PE-davits
Eric
finished builds : Nordkap 476 (Billing Boats 1:50), Marina II (Artesania Latina 1:50), Calypso (Billing Boats 1:45)
on the slipway : Titanic 1:200 (Mantua)
very nice Eric.............and you use legos as well  :)     is this a new offering from Mantua?    this must be a double plank model......or is it to be covered with P.E. plating?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
it will be a single planking model.
i'm hesitating about the external plating with plastic card, including the famous rivet-pattern, but i'm affraid about the amount of work.
eric
some more pictures
cranes : the first one is with the cranemast as it comes  with the kit, second pic with PE-mast; don't know yet wich one to choose
funnel n° 3, with the piping, not accuratly but i can live with that
the inside of the hull will be lighted with a LED-strip, brightness can be adjusted trough a remote control
deckplanking
Eric
looks very good Eric
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Looks li a great start. I'm helping my 9 year old son build the classic Revell model of her. He's enjoying it and so am I. I built a couple of them when I was a kid and it brings back memories. Looking forward to seeing her progress. Odd we don't see more models of her on this site, she's such a famous ship.
Update 12/01/2017
Planking of the hull is finally finished; especially the stern caused me a lot of problems.
Started with the first round of sanding the hull
Before :
After :
Next stage will be filling, sanding, filling, sanding, filling, sanding .............and then primer.
Learned a lesson : next build of such a length (1.300mm) i will use larger strips for planking the hull; i did it this time with the strips provided by the kit, only 2mm large; over such a length these strips twist and bend too much :cheers:
Eric
Update 24/01/2017
filling and sanding of the hull is done
before
after
the stern
before
after
vieuw from the bow
vieuw from the stern
and the prop-shaft
this is ready for primer and sanding
Eric
looks awesome Eric  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Nice progress Eric. I will follow along.
Michael
Eric,
Nice start. It will be interesting following along.
FYI Really wonderful 12 part series that ran a couple of years ago on American Television. It is about the actual construction from drawings to - of course - it sailing off at the end of the series.
https://www.amazon.com/Titanic-Blood-Steel-Jocobi/dp/B009AVCAE4
PS: You may need to purchase an EU formatted disc if you are interested..
Cheers
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Watched the new program about Titanic regarding the charcoal fire that had been burning in two starboard holders for three weeks. This while she still was in the yard, creating a weakness in one of the bulkheads and hull where temperature reached something between 500 and 1000°C!
The fire continued during her maiden voyage, using more coal than necessary.
This along with natural phenomena created confusion on the bridge and collision with the iceberg was inevitable.
Edited by Nirvana
Respectfully
Starting to look great. The hull plating might be a lot of work but just be patient. Good job
Regards, Scott
Completed builds:
Awaiting construction:
I wondered how the Mantua kit would looj like being build. I have the Billing kit to do. It is a larger scale model and has tons of photo-etch parts. Will watch as you build this one.
The kit looks good, although the building instructions could be better. I will use PE-parts by Tom's Modelworks and Minibrass.
I regret now not having choosen de Billing kit, 1:200 is so small :(.
busy now with the deckchairs and benches in PE-parts, OMG, will post some pictures later on
Eric
nice planking Eric  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I like the planking as well, 1:200 scale must be a challenge.
Respectfully
Here is a link to tom's PE parts Torro are mentioning, http://www.tomsmodelworks.com
Respectfully
I am using the PE-parts by Minibrass as well and I must say, these are easier to work with and have, in my opinion, a better finish.
Eric
Eric,
I would like to apologize for the error,
I found the website, so for anyone else to be building Titanic the link is as follow
http://www.minibrass.com/index.php
Respectfully
Eric,
No problem, since I use both Minibrass and Tom's Modelworks. Tom's Modelworks are only 0,15mm thick while the Minibrass' parts have a thickness of 0,45mm. So you can imagine the difference while bending the parts. I am already affraid starting with the railings from TMM.
Eric
Wow, never would have thought that...I steel ship that starts out with wooden planking.  Neat!  Doing a great job!  How big is that boat?
length is about 1.300mm !
Eric
