Being new, not sure this has been mentioned before, I searched and didn't see it.
This is a luthier's tool for doing inlay, which ship modelers don't do much. However, any router base that precisely controls depth can be flipped over and turned into a router table. I haven't gone so far as to make a real table, but I have used it on small pieces while clamped upside down in a vise, and it works great. It operates very smoothly and the depth can be adjusted with really minute accuracy.
Precision router base for Dremel
I built my own router table for my proxxon mini router, but that looks like a great addition. I will investigate
Thanks
Steve
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
Thanks for the Heads Up - This looks to me to be a very attractive alternative for finishing frames to size using it mounted upside down with either a router or sanding drum. I note its made by a Guitar builder and the video appears to show some pretty fine adjustment for the cut. Included a screen shot from the video just need to counter sink the attachment screws for what I need.
As I'm setting up a workshop from scratch being a long time plastic modeller the up front cost is pretty steep but this at US$55 looks pretty attractive. I've been lucky enough to buy a used Byrnes Table saw from a member in Canada but the freight was 50% of the purchase price so for the time being I've decided to buy a VandaLay Mill which uses a dremmel as well which I hope will take me through till I can afford something better.
Don’t want to hijack your post so I'll post a separate one for the VendaLay – thanks again for the Heads Up very much appreciated– Cheers Pete
Edited by PeteB
Hi PeteB
I found this one on the Bunnings website. Not as good as the one above but once you add shipping to the $55 US price tag of the Stewart MacDonald version I think it would be about 1/3 the price.
https://www.bunnings.com.au/dremel-plunge-router-attachment_p6373700
I found a YouTube clip as well
https://m.youtube.com/watch?v=oqu-Ni12oic
Cheers
Steve
Edited by hornet
Hornet
The StewMac Router base is a pretty versatile item.  I have a friend of mine that is a guitar maker and does a lot of beautiful inlay work using this.  It is also adaptable to the Foredom, using their handpiece, which is threaded to fit the router guide.  There are a lot of router guides available out there that are superior to these but much more costly.  You just need to determine how much you will use it to justify the cost.
Bill
Kate Cory Scratch Built
Previous Builds:
Benjamin W. Latham Scratch Built
H A Parks Skipjack Scratch Built
Charles W. Morgan Model Shipways Kit
Rattlesnake Model Shipways Kit
Diligence Model Shipways Kit
Hi PeteB
Cheers
Steve
Thanks Steve - The construction of the StewMac one looks pretty sturdy and adjustment more precise and easier but will certainly give the Bunnings one the Mark 1 eyeball test - Thanks again - cheers Pete
Have the Dremel Plunge Router attachment and it works well within its limitations. It will not handle close tolerance. I tired to run a rabbit on a keel and it would not consistenly hold aline. However I do use it on Doll House furniture where tolerance is not so critical. With the router (Dremel 4000) in place and the base on a flat surface you can "wiggle" the drill .010 -.020 laterally and .010 front to back. I've tried to order the Stewart McDonald tool but it seems to be out of stock everywhere. Sent an availability request to maker and waiting for response.
Dupree
"A slow steady hand conquers a fast shaky mind" - me
HMS Triton 1:32 Cross Section
Dupree
I have found one advertised on eBay if that is any help to you.
Cheers
Steve
http://www.ebay.com.au/itm/Precision-Router-Base-For-Dremel-Tool-Freehand-Routing-Inlaying-Luthier-Tool-/111179440399
Edited by hornet
Hornet
Welcome to you and everyone else :) I'm a guitarist also, I started doing my own work when a so-called luthier ruined the neck on my 40th anniversary Strat by stripping the truss rod.
Luthier supply houses are an excellent place to find ship modeling tools. I'm going to post another thread with a few other things I have that people might find of use. You know those $20k custom guitars with inlay up and down the neck? Chances are it was done with this tool. It really does work extremely well for minute adjustments, and with a little time invested in designing and building a table for it, you should have a very flexible precision tool. I need to do the same, I've had it for a while but except for some pretty thorough tests, I haven't used it in a project yet. I have all the supplies and materials and hardware for a really sweet Strat-type guitar with my own body design, it just hasn't made it to the top of the queue yet. Mostly because ship models are interfering.
More places you should spend some time checking out what they have:
LMI
Philadelphia Luthier
Also, if you have the Byrnes table saw or another capable of small scale work, you can get some good prices on wood of most domestic and exotic species by buying fingerboard blanks. They're typically 5/16" x 2.5" - 3" x 21"-25". LMI has good ebony fingerboards in this size for $20-$25, a single one could be resawn (with a nice .03 slittling blade) into quite a lot of ship scale timber.
Response from StewMac;
Thank you for contacting us.  We are waiting on some machine parts from our production facility, before we can list this item as "in stock".  We hope to have all items available later this week. You can always sign up to receive an email when this item is ready, by clicking the "email when in stock" link under the item number.
If you have any other questions or comments, please contact us.
Best regards,
Jayme Arnett
Customer Service Manager
Stewart-MacDonald
Dupree
Hi Vossiwulf
Thanks for your heads up I just ordered mine today - Anyone else that was interested they are in stock and shipping now.
Cheers Pete
Great! Really shouldn't need too much other than a plate it could be screwed to with a 9/64" bur shaft hole and you have a very good mini router table, but I'm sure the members here can come up with something cool and unnecessarily complicated and precise. One of my favorite reads was of a guy who spent I don't even know how long, weeks of work at least, turning a standard good quality 7x12 mini-lathe into an insanely precise device over its entire operating range so he was pushing out past .0001" in accuracy for no other reason than he could. I love that guy, I laughed the whole time I read it. I can't quite be him, but I understand the mindset.
I have the Stew Mac Dremel base.  I bought it for routing out inlays in guitar necks.  I used it for a while but in the end it found its way to the dust shelf.  I didn't like the depth adjustment feature.  And the dust blower didn't work too well either.  I ended up buying the Micro Fence plunge base.  Expensive but a world of difference from the Stew Mac base.
With the LED lights and dust extraction, I was able to clearly see where I was routing to some very fine points.
A few months ago I got a flyer from Lee Valley.  They now have a plunge base that looks very similar to Micro Fence and a lot cheaper.
The base alone is $85.  Had their base and attachments been available a couple of years ago, I would have gladly gone that route.
Julie
First and only build: Endeavour - 1934 American's Cup, UK Challenger, J-Class - Amati 1:35
Looks good too thanks for the heads up on that for the future - I bought the StewMac specifically to be a poor mans mini Router Table for frames and that sort of work that won't take up a lot of bench space and I don't see me having to alter the depth during use so think it should do the job for a while - Cheers Pete
Hi Julie - Just had a look at the Lee Valley site and downloaded their catalogue - some very nice goodies there - thanks for the mention. cheers Pete
Here's just a quick note about using Dremel bits.  For depth of cut, don't exceed 1/2 of the bit diameter in a single pass, because chip clearance problems and breakage are much more likely to occur.
Other than that, I've always thought that Dremels were pretty weak.  But for fashioning very small parts they may be acceptable.  I've always wanted to try a Foredom shaft-driven tool or a pencil/micro air grinder.  However, a quality 1/8" pencil air grinder is not inexpensive ($100s), and the cheap $27 grinder at Harbor Freight gets poor reviews from experienced persons.
Pete, I should have added that for what I was doing at the time, the Micro Fence base was far better than the Stew Mac base, for me.  But I know many luthiers are completely happy with the Stew Mac base.  It was simply a personal choice rather than a hands down overall better choice.  I wanted the plunge feature to the point I convinced myself I needed the plunge feature.  That kind of convincing oneself can be costly.   :rolleyes:
FWIW, before I got the Micro Fence base, I removed the Stew Mac base plate and made a larger plate out of lexan so I could see what I was doing better and to span the side rails I made for the inlay routing.  That helped a lot but I had already sold myself on the plunge base as a "necessity".
Julie
for any Brits that are watching this thread then the StewMac router base is available from Woodworks Craft Supplies for £46.40
http://www.woodworkscraftsupplies.co.uk/stewmac-precision-router-base-p-1336.html
They say they're having a closing down sale so might be worth a look to see what else is available.
If I'd known I was going to live this long, I'd have taken better care of myself.
Got this tool today: http://www.ebay.co.uk/itm/132022884833?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Do not buy it. The height adjustment is crap, it floats by itself due to the vibration, so you need to carefully hold the height adjustment knobs. That makes the depth not very accurate, if that is important.
Thanks  Mike
Mine is already on the way :-(  I am only going to use it as a fixed router table so it should still fit the bill for what I want - but a good heads up for others with more ambitious uses in mind - cheers pete
Hi Mike
Had a look at the one you bought off Ebay and it looks a bit different from the StewMac base. The first thing that struck me was in the appearance the StewMac item is polished Al with Decals etc. which made me look a bit further and if you compare the two photos below you can see that the beam that holds the Dremmel is a different shape  - StewMacs is an oval shape at either end and the Ebay one is more square -  It could be its a knockoff and not machined to the same spec as the reviews of the StewMac base are all very good.
First the StewMac base
Next the Ebay photo
also just noticed the milling on the Ebay adjusting screws is pretty basic as well.
So your warning is still timely don't buy the Ebay one .- for what its worth - cheers Pete
Edited by PeteB
Yes, it is not StewMac, that is why I was giving a link to avoid confusion. But should have been more clear.
Well, for all the good purchases I did recently, there should be a bad one as well! :)
That was my experience, Mike, and with the Stew Mac base.  The height adjustment is fiddly.  The springs are applying pressure and as you try to make adjustments, racking occurs.  So you have to go back and forth, from one side to the other and then lock it in place tightly, then run a test cut.  If it's not right, you have to repeat the process.  I found it frustrating.
Julie
I only adjust it inverted, usually with the dremel in a vise so I have both hands, and lubed the main posts, and I really don't have much difficulty getting it to do what I want. I tried adjusting it while on its base with the weight of the dremel on it, but found that it was wracking more than I wanted. Try adjusting it as I do, see if that works better for you.
I wish Stew Mac was here to answer the comments.  It's kind of crazy to have to spend a lot of time or create quicker methods (like putting it in a vice) to make depth adjustments in a tool that is sold for being adjustable.  The Stew Mac base was designed for instrument work where depth adjustment is critical.  If you're doing inlay and you are even .01" too deep, it could ruin the piece.
For anyone wanting a simpler and more accurate way to adjust the depth, the Micro Plunge base by Micro Fence will give you pin-point accuracy but for a price.  It's beautifully engineered though.  You get what you pay for.  Lee Valley's new Dremel plunge base looks like a good alternative but I have yet to hear any reviews on it.  At about 1/4 the price of the Micro Plunge base, it would have been my choice if it was on the market when I needed better depth adjustment accuracy.
Julie
