US Brig Syren by Hipexec - FINISHED - Model Shipways - 1:64 - building as USS Argus
Another pre-bent plank easily glues on with no clamping. The picture shows the plank 1 minute after gluing on.
Link to comment
Share on other sites
Pre-bending two more soaked planks. Only 9 more to go on each side, then it's planking the stern inside and out, then planking inside the gunwales.
Link to comment
Sam,
I never have been able to do that before! I don't know why. With my Connie...I struggled, breaking plank after plank.
Link to comment
 The pre-bending system is not perfect. This one took one clamp to get it tight at the stern
Link to comment
another day another plank being pre-bent. The open gap is shrinking, though. Slow but sure
Link to comment
Anxious to see how you line off your hull for the second planking with your vaneer strips. It'll be interesting to see this ship finished without copper plates as it usually is.
Steve
Link to comment
Steve
Steve,
I have never put the copper on since I like looking at all the wood working. My  first and last ship were veneered and I didn't have any trouble lining off the first veneer strip. Never gave it much thought.
Below is a pic of my last veneer job.
Link to comment
I will try your technique with my Syren.
Looks so clean and easy.
Very nice job.
Respectfully
Link to comment
Well, into each ship model build a little rain must fall. While pinning some planks for pre-bending, that very fragile stern proved to be too fragile....snap!  I'll repair it tomorrow after the planks dry.
Link to comment
Aargh!  I had this idea that I would cut the stern shapers from some hardwood on the hope they'd be stronger as I've gather from several Syren build logs how fragile they are - probably wouldn't actually be any better would it???
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
Link to comment
Perhaps if I pinned all the stern pieces it would be stronger. In this case I got careless and didn't protect the stern with foam pads that I usually use. It can not take any stress. Planking it will do the trick.
Link to comment
CAUTION! For those pre-bending soaked planks like I am....make sure you clean off all glue from the previous gluing. If you don't, the wet plank will stick to the old glue and you will probably break it to remove it so I can be glued properly
Link to comment
Well...it took all day, but I finally put Humpty Dumpty together again. Then I fixed the pads near the stern to prevent that from happening again. I usually put those in place, but got lazy this time. Haste makes waste.
Link to comment
So close to close!  I'll bet you can taste that sweet success!
Nicely done!
Doug
Link to comment
4 hours ago, bbrockel said:
Nice repair job.  I know you were not a happy camper when it happened.  :(
Well, it was a good lesson....to slow down and plan ahead better. I sometimes get on a roll and hate to slow down. Bad habit it ship building.
Link to comment
Nicely done!
Yes. It will feel good to enclose the sides. Then I have to finish the stern with very poor plans and photos in their book. I'll figure it out ,though.
After that there's my veneer planks, then inside the gunwales, then the deck. So...a long way to go. But I will be happy with the sides closed in.
Link to comment
Down to two short planks on this side. I'm using the Philistine method of making stealers. I just use sharp points shaped to fit. I'll leave the correct method of making stealers to real ship builders and the purists.
Link to comment
The last main piece on this side. Two very small pieces at the rudder post then I'll finish the other side.
Link to comment
Down to two pieces on this side. I'll probably finish the sides today if I'm not distracted by life.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
