The Lower Transom Counter
To finish the planking the lower transom counter, the practicum states:
Quote
“Now, simply transfer the pattern [from the plans] to the counter planks and trim with the Exacto as shown in photos…”
If one takes that statement at its face value, you will run into a problem. The plans show an elevation view. The lower counter is angled away from the viewer and thus is foreshortened. I had to stretch the image vertically so that its height matched the true length of the counter as seen from the side. I ran into this identical problem with the transom when I built the Rattlesnake. I’ve traced out the trim line onto the lower planks but am reluctant to do the trim until I have completed the wale, which it butts up against. Note, there are still two windows which need to be constructed below the gun deck gun port.
The Wale
The wale is the next band in the hull planking process. The wale is made of seven 3/23” wide x 1/8” thick planks. According to the practicum, these planks have no variation in width from the bow up until bulkhead N where they begin to narrow.
I had anticipated the plank width variations and had ordered from ebay proportional dividers for this purpose at a price below what Micro-Mark was selling theirs. What I didn't realize was that the supplier was in India. After waiting almost 4-5 months for delivery, I chalked it up as a bad buy and ordered the one from Micro-Mark, which arrived promptly. It looked and operated the way I expected, and I put it back in the box almost two years ago until I was ready to plank. Nine months after my original ebay order, the India dividers arrived! I suspect it got tied up in Customs. I had tried to contact the Seller but all they would state was that it shipped. Now I had two of these dividers. The Indian one was a little bit larger and not as finely finished.
When I went to use Micro-Marks', I could not get it to divide as marked on the scales. When I set it to divide by four for example and placed one pointer on the 1' mark and the other on the 5" of a ruler (4" of measure), I'd flip it over and measured with the other end. It should have shown 1" of measure on the ruler. It actually read about 1/32" to 1/16" short. Part of the problem may lie in the fact that I could not lock the legs so they wouldn’t move as I handle the instrument. Where the legs cross there is a tightening screw, but that is for locking fulcrum point not the legs. It was even worst for the Indian made dividers which has cruder increments and the pointers are thicker are blunter. So, either both these proportional dividers are poorly made/designed or I'm doing it wrong. Either way, I'm out a chunk of change as they are useless to me.
In lieu of this failure, I tried to use the tick strip method but that too had problems. The variations of the plank widths is 3/32" wide to 3/64" at the narrowest width. The pencil tick marks themselves are relatively thick in comparison to variation in plank widths and I better be damn accurate in the tick spacing on the bulkhead edges. I even tried painting the edges white so I could see the tick marks better.
I've seen demonstrations both live and on YouTube and they make seem so easy. That comes with practice, lots of practice and this is only my second planked model!
I opted for a third method, a variation of the tick strip. Instead of marking ticks on the bulkhead edges, I marked the planks with the bulkhead position lines and the corresponding width at those locations. Then I sanded down the widths and verified the width dimensions with a digital micrometer at each bulkhead location. Finally, the whole plank was smoothed to make a nice clean transitioned as the plank narrowed.
In order to determine the various plank widths, I initially tried laying a planking strip down on the bulkheads and letting it naturally curve up into the transom. To do this I tried using some plank clamps I bought from Model Expo many years ago when I was building the Rattlesnake to hold the plank in position. They were useless then and they were useless now. They are just too clumsy. So, I went to tape.
Tape was fragile because there isn’t much surface area on the bulkheads for it to stick to, so I marked the bulkhead where the bottom the lowest plank edge had to follow as indicated by the tape. The pictures above were taken before I painted the bulkhead edges so I could see the tick marks and had to lay out the tape a second time after I paint them. I measured the distance from the bottom of the lowest plank from the gun port band of planking to the tape at each bulkhead from bulkhead N aft and divide by seven, the number of planks that had to fit in that space. That became the individual plank width corresponding to that bulkhead. This took some time
Finally, I got all the wale planks installed. But I still have one more thing to do before the wale construction is completed. I must taper the wale to the stem rabbet as well as to the hull planking below the wale as indicated in the instruction booklet.
JS, a low progress is better than no progress, besides this ensures a better eye for details and perfection.
Good seeing you back at "Connie".
Respectfully
The wales were tapered with a sanding stick and lots of elbow grease, so it took a while. Now came the part I was not too sure of. As I mentioned earlier. I did not trim the lower transom because I was quite unsure where or what the cut was supposed to line up with. Well I found out. It was only after I trimmed the excess transom planking that I realized that the wale was supposed to bend around the stern and mate up with the transom. Mine didn’t. Had I trimmed the transom first, as instructed by the practicum, I might have realized what should have been done.
Luckily, this area of the model probably will not be seen very well by the casual observer. Following my sketch line, I continued to trim the transom and filed down the corner of the wale. Instead of ripping out chunks of the wale to make the repair (and probably my hair as well), I opted for a wooden filler patch. The whole thing will eventually be painted black and will be on the underside of the model in the shadows so hopefully it won’t attract any attention.
The patches were made by taking a piece of scrap basswood and cutting it into the basic triangle shapes to match the areas of repair. The through repeated trial and error, I carved the necessary contours on the bottom of the patch so they would snug. The patches were then glued into position and then filed to their final shape.
I don’t feel too bad as Mr. Hunt stated in his practicum that he had to use a bunch of wood filler as well. Once I finish the basic structure of the quarter galleries, I will fill in any remaining gaps with wood filler.
Within an hour of my last posting things changed. It had been almost a year since my left eye cataract surgery. I had seen the eye doctor for a scheduled appointment the previous week for the right and told him that I was feeling occasional pain. He said it was time we did the right since the right cataract had gotten bigger and was swelling the lens. The following week I got the required EKG and Covid-19 test. BTY, the Covid-19 test is the longest 15 seconds you will ever endure – painful. OK that brings it up to my last post. I get a pain like someone pokes me in the eye which lasts from Saturday evening to Monday morning and my right vision is completely fogged over. My left vision still hasn’t fully recovered. I still can’t read with it
The original planned 20-minute surgery took an hour and a half which the doctor described as the most difficult surgery he had performed in his 35-year career. So right now, my right eye is still fogged up with four stitches and my left eye has no close-up vision. Corrective lens are about two months away, awaiting stitches removal and healing. Model building will have to wait some more.
Typing this message was a pain even with the zoom in and spell check capabilities of a word processor. I keep hitting the wrong keys.
Me too.
Well, I’m back, sort of. After 9 months, my left eye can almost see 20/20 with my new glasses. My right eye is starting to heal after about 2 months, so it has a way to go. Reading and close-up are still hit or miss, but with my close-up head gear magnifier, I should be OK…. considering we have a pandemic going on.
While I was dealing with my eyes, I got a full-blown hacker attack who tried to steal my credit. It involved all my credit cards (email and postal address change attempts, additional cards in different names, attempts to add on accounts), my savings bank account, the financial institution accounts where my financial advisor is, attempted online purchases through Google and ebay and they even tried changing my US Mail address. All within a 5 day period. Luckily, I was able to thwart it in time by changing account numbers, login IDs and passwords, acquiring all new credit cards and numbers, professionally having my computer checked for viruses (there were none) and notifying the all three of the credit bureaus and the IRS. A real pain in the butt. I hope that’s the end of it
So, hopefully I won’t have any more interruptions and have started working on the model again. Looking forward to posting new stuff soon.
Continuing with the bottom quarter galley filler, I cut out the patterns from copies of the plans and rubber cement them onto the wood blocks. The plans show only the starboard side so of course you must make a mirror filler block for the port side. So far, so good. However, the starboard pattern also show the position of a hole that is supposed to be “under the officers’ head” in the quarter galley. I drilled an 1/8” hole in the starboard block as indicated by the plans. The question was, does the port side also have a head? According to the USS Constitution Museum’s documentation (January 18, 2014, Life at Sea Blog), “The captain had the cushiest arrangements. His private privy was located in one of the quarter galleries.” Since the captain had only one privy, I left the port side alone. No privy hole was drilled.
The blocks were initially carved to shape using a disk sander and custom fitted into position by dry fitting and adjusting the shape with sanding sticks and files. This took a while and I got as far as my skills would take me. They still needed filler to complete the job. Thankfully, all of this will be covered in black paint.
At this point I’m going to leave Robert Hunt’s practicum for a while leaving the hull planking unfinished. I need to install all the goodies in the gun deck before I close off the hull. If you may remember, I added hand ropes and stanchions to the ladders going below the gun deck. These have been effectively knocked off and must be repaired which requires access through the hull. And, before I can do that, I have to finish the gun deck. There is a lot of stuff to add, and most of it I don’t have any plans, I will be an adventure.
Ohhh, she's a beauty!! You wouldn't perhaps have a build log?
Unfortunately at this time my build log is on an R/C group site! When I have some down time from work and our 10month old I’ll see if I can get everything transferred to this site.
Those guns and carriages look great. I'm going to have to be creative on my gun deck armament. For some reason, if I use the carriages that came with the kit (I have extras as the kit does not provide any for the gun deck), they are a bit low in the gun ports. I know of someone else who had the same problem and remade their carriages a bit taller. I have a ways before I get there to figure out how I am going to do it. That really is a nice carriage jig. A word of caution, the kit cannonades for the spar deck are based on the 1926 renovation, which in turn are based on British cannonades, but they are the wrong period.  A couple of cannonades on the actual ship, are correct and they have a vertical screw for vertical barrel adjustment and a different design for the carriage than what the kit provides. Something to think about.
Gun Deck Mast Rings
The first things to install on the gun deck were the mast rings. The kit provides mast rings for the spar deck, obviously none for the gun deck. Because I could not find a US Navy plan that showed mast ring details, all I had to go on were the Navy’s deck plans and a few photos of the main mast ring. Because the bilge pumps were photographed a lot, a few captured the main mast which was next to them. As many photos as there were, very few included the main mast with a clear view of the ring. I could not find any photos of the mizzen or foremast rings.
Oops I meant to post this image
Using the thickness of the rings supplied by the kit and the plan view of the rings from the Navy, templates were made, and rubber cemented to a piece of 3/32” basswood stock. They were then drilled cut, carved, and sanded into shape. Finally, they were painted green.
OK now I use this image
It was at this point I realized something was wrong with the foremast ring. It didn’t fit completely over the hole on the gun deck. It seems I had made the grating next to the mast a bit too long. Knowing this error would be difficult to see, I chose to flatten on side of the ring. Unless you knew, you wouldn’t know.
