Sweeeeeeeeeeeet Adriaan.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
thanks Piet and Mobbsie :)
I know I still have lots to clean up but I am really enjoying the build again :)
I started on the lower green strake now. I am not looking forward to fitting the curved bow part of it tough
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
Adrieke,
Knowing your resolve, I can't imagine you not managing that curved bow part ... You seem to thrive on challenges as with the King of Mississippi
Carl
thanks Carl for your confidence :)
making the curve will be easy , I am more concerned with the fact that the strake will need to be fixed to the hull at a corner and not one off the sides. so not much contact. my resolve is to flatten to corner in the middle of the curve to give a bigger area of contact. I am just not sure how it will look
A quick update from tonight.
2 parts of the lower strake are now attached. tomorrow ill attach the ones on the other side. then I will be able to get a rough idea on the shape of the curve.
I temporarily attached the albatross to make sure the strake fits snug against it
Looking good, Adriaan.  Getting those fiddly curves to look right can be frustrating - appears you have it setting in the right way.
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
really starting to move right along there,  Adriaan.   very nice progress indeed!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
thanks Wayne and Popeye :)
i am not sure yet on the curve. the instructions says to measure it 18 mm from the upper strake all the way round , but i had already found out that at the front. if i follow the instructions the strake will go up because of the shape off the hull. if i measured 18 mm straight down then it would stay even with the waterline, but not sure if it would look right
Hi Adriaan, I understand your dilemma.  It seems that the instructions are not quite clear or in error.  I would think that it should follow the sheer and if the strake is the sheer then run it parellel to it.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
hi Piet, thanks for the advice. and I agree with your reasoning and run it parallel with the sheer
but that's for the weekend.
today I worked on drilling the holes for the portholes. not an easy task when the instructions say to start at the middle of the ship, but where is the middle.
using some off the pictures in the instructions I calculated the middle and used some wood strips to mark the positions.
before drilling I checked again with the upper pre drilled holes and found out I was off by about 25 mm
even after this adjustment , they still do not correspond completely with the overall picture of the ship, so I assume there are errors in the measurements that where given.
after drilling I inserted the rivets to see the effect and it looks good I think
i still need to do the other side and will be looking through the instructions to find any other holes that need to be drilled before i start on cleaning up the paintwork
Hello Adriaan and you are so welcome.  Yeah, When looking at pics of ships that seems to be the norm, running that strake parellel to the sheer.  I also think that the portholes may not always follow the sheer line but rather parellel to the deck where the cabins are.  This will only be noticeable at the stern and bow ends of the ship.
Love the looks of the portholes!
Cheers,
                       VOC Ship Surabaya
do they supply trim parts for the portholes?   if the kit doesn't,  look in my Holiday Harbor build......I have a little thing in there about eyelets that you might find interesting.  I also show the panels for the Danmark kit.   they have a porthole arrangement is is somewhat similar to what your doing.   looking good my friend!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
hello adrieke  that build is looking really good so far keep up the great work that u are doing
thanks Piet. i didnt think about the portholes and followed the instructions on putting them 10 mm below the lower strake.
looking at some pictures you are right (ofcourse). since there is not much difference i wil lkeep them as they are now , but something to remember if i ever do a ship similar (already got one in mind :P )
thanks Popeye. they supply small rivets to simitate them, but i ll have a look at you rbuild too :)
thanks dragzz
did some work on my workspace and also finaly the replacement part for the black pearl build has arrived so i started on that build again
i did finish drilling al lthe holes for the portholes, several holes for some eyelets that need to be atached and ofcourse the 2 holes for the anchor . unfortunately i didnt take any pictures , but i ll try to get some tonight
looking great, always look forward to your updates
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
thanks Kevin :)
first a picture of my work area after the changes. on the right the 2 workbenches made from a 5 tier shelving unit.
no progress tonight
as I am trying to catch up with the Black Pearl build ( I am about 7 issues behind) this build might slow down a bit during the next weeks.
pictures show the holes I finished off during the weekend
Wow, nice work space Adriaan and so much space.  Looking forward to the Black Pearl work!
Th GF looks very spiffy and the portholes - - - they'll also look okay, the difference is too little to worry about  :)   Or notice.
Cheers,
                       VOC Ship Surabaya
Hello  Adriaan,Real nice looking model workshop,buillde are coming along to,I started to plank my Endeaver a little as time allows,hoping to speed things up, well done on your  return,Edwin
thanks Wayne.
no update as the little time i had for building was spend on the Black Pearl.
really looking forward to 2 weeks of hollidays. Besides celebrating and spending time with the family i ll have more time to build
I am  back
everyone have a good new year
all building has been on hold due to celebrating and then afterwards the discovery of some wood eating pests that most likely have gotten away with a few parts.
as my workbench is partially unusable it might be a bit for I start again. I first want to catch up with the pearl as I am 2 months behind on her
Welcome back Adriaan, I'm looking forward to updates and a plethora of pictures  ;)
Have a great and prosperous 2015.
Cheers,
                       VOC Ship Surabaya
Finally I am back to building on the GF
while I am slowly working on finishing the hull I have prepared a whole lot of the deck fittings
I have stored them in containers with the manual numbering on them so I can easily retrieve when needed
this weekend I spend mostly painting
Hi Adrieke,
Love your spray box, a tadd unhealthy, but who's complaining ... I'm glad your pictures are large, for you've got to show some small details! Looking forward to the GF's further growth and development.
Carl
about a month ago I received my display cabinet
this will be home for the KOM, the Virginia , my current and some of my future builds
That's one superb showcase mate! Looks really great. At the rate you are building you might need to extend it before long ...
Carl
