Hi All,
Thought I'd share my Bluenose II Build a few Years ago.
My second ever build with guidance from Mr Earl. (Definitely not deceased!! :))
So, some photos in the may provide some inspiration/guidance to others. Hope the photos are in some semblance of order.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
Sergal/Mantua Cutty Sark
A/L Pen Duick
A/L Fulgaro
Amati/Partworks 1/200 Bismarck
A/L Sanson
I seem to have issues with the "Edit" but wished to extend my regards to John Earle in putting me on the Modelling path that has kept my "Nose Clean" for many years.
If i can "Wax Lyrical" the Hobby has kept me well "Grounded" for many years and issues. (Meditation in my Ship Room, if you will.)
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
HOF - What wonderful pictures of your Bluenose ll !  She looks great and and some of the detail work is an inspiration to someone like myself trying to develop modeling skills. Compliments to the chef!!!
Robert O
Congratulations on completing your Bluenose.  You did an excellent job on building this model.  John Earle has a lot of valuable information on his website and I have seen his techniques used by other modelers.
Ryland
               - Nautical Research Guild
Thanks Robert/Ryland.
This Build was originally on "The Ship Modelling Forum'" Now sadly closed.
My second ever build.
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Very nicely done Hof.  I'm looking closely at your deck furniture for ideas as I'm just at that point now and am trying to decide on finishing and finishes.  The natural wood colours look good.  I wondered about planking the cabin tops - did you consider it?  Also the walls of my  cabin love k odd because of the tabs for assembling.  Yours look fine - how did you finish them?
All your rigging looks good - I can only hope mine will be half as well done!
Thanks for sharing.
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
Hi Chap,
Thanks for the reply and compliment.
The Cabin Tops are "Planked" with "Ramin?" (May be a little difficult to see from the photos.)
The Skylights also have a Walnut Veneer on them.
Deckhouse sides planked with Walnut also. (Tabs got covered up.)
Port Light/Holes are aftermarket from Hobby World, Montreal. (Glassed Brass, I had to have something better than the A/L offering)
Rigging was Simplified as per Mr Earl's instructions.
Anything that I can help with, I'll try my best to assist.
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Hard to tell from the pictures - thanks for the detail.  I'll go the planking route for sure.  I'll see what I can do with the skylights - fiddly little structures.
 Cheers
Doug
You made it to the finish. Rather nice work. A pity we have to do without all the hardships, and questions, and redo's. Still a great feat mate
Any ideas about the next build?
Cheers
Carl
Hi Carl,
Thanks for that.
BNII was my second attempt at building a Model Ship.
This was complete a few Years ago but the Model Ship Forum that it was initially on shut down.
Since there are several BNII Builds in flight at the mo. I thought it opportune to resurrect my BNII build log in the hope that it will assist.
(Still working on the Pen Duick.)
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Have to find that one again in the multitude of logs!
Cheers mate
Carl
nice looking model Hof.  a friend of mine had a Billing's Bluenose that he couldn't finish due to illness.  so I traded some hobby supplies for it.......it didn't fare too well in transit.  besides the damage,  I found a mistake with the instructions,  with the help of a fellow member here.   I ended up tearing it apart,  but from it,  I was able to clone two other hull frames.   so it has turned into a project,  that will be three schooners....the Bluenose,  the Bluenose II,  and the America {I had to cut out the cockpit for that hull}.  should be an interesting build,  once I can get it off the ground.
I'll be sure to add your to the list of logs to look in on ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Glad to see you didn't make the same mistake our provincial government made by changing the rudder for an all metal hydraulically operated expensive failure instead of the old tried and true wooden rudder with mechanical steerer in the box on deck. :)
Looks good.
Guest Riccardo1966
A very nice build, it came out very well.
Cheers Richard
Thanks Chap,
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Nice work! I'm building this right now. I  will definitely use some of your information for reference.
CK
Thanks CK,
Yup, looking at your progress also.
Brings back memories!! :)
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Hi CK,
I possibly do.
Could you elaborate a little? View from Deck or from the Hull?
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
