Hello Everyone,                     A small update.
I have just finished the lower transom support and glued it in place. I found it to be quite an awkward piece to make, nothing seemed to end up being a perfect fit, it turned out only ok but it will have to do. Next I'll be tackling the rudder,
Ken
199.thumb.jpg.40c4316396d449867d6b6fcd42fd0e6d.jpg200.thumb.jpg.26ea8e1273dbd6e20dfa33228ed74ef7.jpg201.thumb.jpg.237443cbe2da21498b389f37a8e6b921.jpg
Hello Everyone.        Another update.
I've now done the rudder and attached it.  Pete has revised and updated his notes recently showing much more detail having drawn from the experience of other builds. One area that more info is given is that of the rudder. I used the supplied hinges and aged them a little with a brass blackener. The shoulders of these hinges are quite thick and would have needed fairly deep cut outs in the rudder or big battens to avoid a large gap with the sternpost so I compromised and used both the cut outs and battens to achieve a reasonable if not authentic look. The moulded bolts on the hinges were too pronounced so I filed these back a little, I trimmed and bent them to shape, secured the pins and attached them to the hull using cyno. I normally nail them on but as the bolts were already embossed on and looked quite good I decided to glue them, if they hadn't felt secure I could  have nailed them but believe me they are solid. I had doubts at first but I'm pleased with the result.
I have also started on the gallery windows. Using a scalpel I gave the glazed area a final trim, primed glazed then painted them. I am going to keep to a simple colour scheme of black, white and gold, I think that these colours compliment each other and give a good clean contrast.
On my previous post I said that the gallery supports were only ok but would do, I think I was a bit harsh on myself because leaving them overnight and returning in the morning I now think that they are quite good and again I'm pleased with the result. I think that I was expecting to be able to shape the castings around complex curves and for it to stay flat against the surface like photo etch but it's a different beast, it's quality lies in its depth and rich detail but should not be viewed from too close up to see it at it's best. Just putting my opinion down here.
Ken
Hi Pete,    In answer to how I did the glazing, first I used  a Zap, Pacer product, Formula 560.  It's a clear canopy glue that's used for fixing glass cockpit canopies to model aircraft. A thin film is very strong and is crystal clear, it's also cheaper than the stuff from Micro, for less you get twice the amount. It can also be used as a gap filler and will take paint.
I first paint the white area of the window frames so that I get the depth then at the rear I smear the glue thinly over the surface until you get a film over the gap, just as you would when you were younger making bubbles from your mums washing liquid. Just leave to dry, even a thick layer becomes very clear.
Ken
593bea432387b_001(2).thumb.JPG.11f8630d752a1e40c9f9289c4b9e1d0d.JPG001.thumb.JPG.a080f8bb5b7b732fe2d5ecd28c3ce298.JPG
Hi Ken,
Very nice looking build you've got there.
I'd like to recommend an alternate material for the window glazing.  I've used Weldbond adhesive for glazing and the results look very similar to your results.  It goes on milky white and cures quite transparent.  Curing takes roughly 12 hours.  I apply it by taking a glob of the adhesive and twirling it around within the window pane cavity with a toothpick.  I purchased it at a local hardware store for $3.29 CDN for a 2 ounce tube.
Bill
Hello Everyone,      Here's todays update.
I have just finished the first set of windows of the transom. Those of you that have done this will know my feelings on this part of the build, I have sat down and opened a beer to try and relax again. It was like trying to pluck a chicken with boxing gloves on. The plans were of no help at all and yet again I resorted to others logs, especially Marks excellent, well documented interpretation. I had already painted the windows thinking that it would be easier to just touch them up after fitting than trying to paint them in place. I spent quite some time coaxing them into a shape that they would sit on the transom support and have some sort of relation to each other, had I not seen examples of it having been done I would have said that it was impossible and given up but perseverance and I think a bit of luck got me there. I used my canopy glue to attach them with some small dots of cyno to hold them in place whilst it set. I used this stuff because of its gap filling qualities, it is water soluble so any excess can be wiped away unlike epoxy which is pretty messy. For making the deck above Euromodel supplied some precut pieces, I found that these appeared to be the wrong shape and couldn't be made to fit so I used Marks idea and made up the deck from one piece of ply instead of the three supplied, I planked it and glued it into place, I also had some spare decorative strip which I glued around it's edge. I then touched up the whole area.
I would normally have photographed each step but on this occasion I got so involved I didn't pause to do so, probably a good thing as I might have thrown my camera out of the window in frustration. I am now more impressed with other builders efforts in this area  knowing the difficulties.
Having said all that I am not disappointed with the result, in fact I am rather pleased with how it looks so yet again perhaps Euromodel got it right.
Ken
205.thumb.jpg.be14504117e6eef582aba44706cb70db.jpg206.thumb.jpg.3a5da23c8d31f7cad151486a2d9cd5e5.jpg207.thumb.jpg.a2288b9ccdd0aa665d64b8496b51776c.jpg
Wow! She's looking superb Ken and finally starting to fill that huge gap :)
Anton T
Current build
1/78 Sovereign of the Seas - Sergal - kit bashed
1/72 Arleigh Burke class DDG flight iia/iii - Sratch built RC - no log
Waiting for further inspiration
STS Leeuwin II 1/56 scratch built (90% completed)
Previous builds - completed
1/72 HMAS Brisbane, Airwarfare Destroyer 2014 -Scratch built RC - completed
1/64 HMS Diana 1796 - caldercraft kit - completed
1/75 Friesland 1668- mamoli kit - completed
1/96 HMAS Newcastle FFG 2011- scratch built RC - completed
1/75 Vasa - Billing Boats - completed
Looks great,Ken - you are moving at a much faster pace than I did. Those windows are the easier part - the next level gets a little more tricky. All the pieces at the next level need to sit just right for everything to fit together. Pay attention to the angle of the plywood side entry arches - they will determine the angle of the recessed windows. you may notice the recessed window panels are arched more than the deck they sit on,but when angled back at the top to rest against the ply arches they should sit with little or no gap across the bottom.
current build - HMS Vanguard - Model Shipways
Hello Everyone,      Thanks for all the thumbs up on my build so far.
Anton, thanks for your comments, at least I'm not having to make all my own decorative castings like you. I'm following your build and really enjoying the effort that your putting in, great work.
Mark, thanks for your encouragement, I appreciate your comments.
As I said, I found the first part of the gallery quite a challenge. I knew what I wanted to do but it was my first foray into working with cast parts and I was getting into difficulties trying to bend it in different planes, I would get one area right and it would then cause another area to not fit, a frustrating day but a learning curve.
I approached the next level which is more difficult with a different mindset, with the experience I'd gained I was more confident, more relaxed about it, no trying for quick results. I was also annoyed with myself for not photographing my efforts, so at least for the rest of the transom I will try and photograph everything that I do bit by bit, warts and all. I hope that there won't be too many boring pictures.
First I shaped the stern so that the facia would sit at the correct angle and have the right contact with the decks,   Photo.
I then had second thoughts, The way that I made and fitted the deck above the lower part worked very well so I decided to do the same for this deck. I cut off the original deck flush with the rear bulkhead. I'll cut my deck out in one piece and use the supplied deck side pieces as a guide for the edge curve.    Photo
I painted and glazed the inner windows and side doors, I only glazed the others, I'll paint them after shaping, ( lesson learned ). I've shown a photo of the parts needed for this section of gallery
After careful adjusting I set in place the inner windows and side doors, Again I used canopy glue with small dots of cyno to hold it together whilst drying.    Photo.
Next I cleaned up and bent to shape the side railings. The solution that I came up with for bending the cast parts was to use the shaft of a large soldering iron clamped in a vice, this gave enough heat without melting to easily bend these castings, (  another lesson learnt ).    Photo
Next was to make up the balustrades. Euromodel supplied a cast serrated strip which on first appearance looked a bit naff and I was disappointed,   Photo.  However not having anything else at hand to substitute it I continued, I cut the pieces to size, this was very fiddly, as they were to be glued in with cyno they needed to be filed to an exact fit. Once I started to fit them I changed my mind about how good they were and I was glad that I hadn't substituted them, at this scale I don't think that they could be improved on without a great effort or cost.   Photo
I painted the rails and the picture shows them just resting in place. A good session.
Ken
208.thumb.jpg.03622e6d8079143a9ff97ff07d91cd86.jpg209.thumb.jpg.7768aa124e3bb0828d6da8c9d737f434.jpg210.thumb.jpg.704b2225dc31b7825295621f535db227.jpg211.thumb.jpg.0c7075f75023c0fae49925afb0f59034.jpg212.thumb.jpg.a9100682d4e404ab58ccdf0a4c23a1f0.jpg213.thumb.jpg.97fbc995f40ea15cc5395eaf878cc724.jpg214.thumb.jpg.50f44d6fd71295ba20f5d7c8b96e5f1d.jpg215.thumb.jpg.2eb44ea71daf773bb2f8d2ea82195a87.jpg216.thumb.jpg.9e8288d67c0186d8c9acbeac5c5f0417.jpg217.thumb.jpg.f35f665c2f869ed64532b6ebf0489201.jpg
Hi Pete, Thanks for that.  I was quite surprised with those stantions they were not what they first appeared to be. Initially I thought that they were just random serrations along their length but on closer inspection I saw that they had a front and rear and the pattern along the length was a regular repeat. The pieces also had notches at regular intervals which made it easy to break them off at the correct size leaving about .5mm each end to file the correct angle, when fitted the stanchion patterns lined up uniformly. I thought that what at first looked simple was really quite well thought out by Euromodel.
Ken
Hello Everyone,         Here is the latest update.
I've shown a photo of the next pieces of castings that need to be assembled and fitted into place, they were painted,shaped and ready to go. Mark did point out that this was a difficult part of the build and was tricky to get right, I now know what he meant. I had already built up the middle inner section of windows and the side doors, these were in their exact position, the next step was the windows that linked up with the outer cabin windows and the hand rail-balustrade. Each of these needed setting at an angle so that they would not only be in the correct position but that their edges perfectly aligned with each other at the same time. I found that no matter what I did even after bending to shape I could only get them either to align or set them looking ok in the correct position but not both together.
I decided rather than follow the accepted way I would make it easier for myself and fit the outer windows and balustrade in as correct position that I could according to the plan without regard to it aligning with the inner window, this after all is what will mostly be visible. I then fitted the inner cabin window, again without regard to it making contact with the outer windows, but in a position that looked ok, this left a gap of between 2mm-4mm. I made up a piece and glued it into the gap, when painted it looked as if it should be there. I'm pleased with the result and glad that I didn't let myself get frustrated trying to get it absolutely correct. Next I will be making the deck to fit above these cabins.
Ken
218.thumb.jpg.f213d4451d030c2bc57ad42763a12bdc.jpg219.thumb.jpg.07098fa507d0fe5bd8a294529125bd1f.jpg220.thumb.jpg.8fa3d9f2c4cfaefdf0821de0efb09869.jpg221.thumb.jpg.7782b1f5dfa597310927840a08e4ed11.jpg222.thumb.jpg.4c7c3c54745d04f0e546b890c42464bd.jpg
Hello Everyone.    Again thanks for your likes.   Here's the latest.
I have now made, planked and fitted the next transom deck. As I said I cut away the original deck so that I could fit a one piece version that would be much easier. This deck when fitted was about 3mm lower than the original at the front, but because of the upward slant of the galleries it fits perfectly in line at its rear with the transom facia's deck position. I now realise that The original deck would have been wrong as its incline was shallower than the gallery decks and would not have fitted at both the forward or rear part at the same time.
At Pete's suggestion I checked that the cast figures at the rear edge of the transom would fit as it would be easier to make any corrections at this stage. I hadn't given any thought to this but as luck would have it all is ok.
I have shown the pieces that make up the next level of the gallery. They are now glazed and shaped ready for painting.
Ken
223.thumb.jpg.86952854dead0c0c57d5042940086e20.jpg224.thumb.jpg.466580d228e010d64bd50c108200c313.jpg226.thumb.jpg.4cc1b9c5a9b35ef837de4ae96cbcca2f.jpg225.thumb.JPG.766f9c2a99511f7006f2d036eb0b8887.JPG228.thumb.jpg.804677ba82a9aa443b03d2bec128fc1f.jpg
9001.doc
Ken, in the last photo showing the various metal parts forming the top window gallery, there are six 'oval' pieces with a marked relief. Their darker colour suggests you may have done some work on them ? If I am correct, what did you do and why ?
Pete
Hello Everyone,      My latest progress report reads almost the same as my last one except one deck higher on the gallery. I had the same issue with the fit and the solution of the extra piece of facia was employed again, at least it is consistent. I must have gone wrong somewhere early on as the error is running the same for the whole height of the galleries. Unless I run into serious fitting problems later I don't see this as an issue as it looks ok to me and unless you are very familiar with it or compare it closely with the plan it isn't going to be noticed.
Ken.
230.thumb.jpg.aa207bce30bddf146b151a4bd7efa41c.jpg231.thumb.jpg.d4cf10d86a4e896216eea4345b66485b.jpg232.thumb.jpg.80412cfb0f474f196f80fff743a843d0.jpg233.thumb.jpg.dc9a5b8a86681d6286b1059bfaeea456.jpg
Hello Everyone,    This post should be about progress that I'm making but alas I've taken another step backwards and am now recovering from my earlier errors,
You will recall that on my second and third transom deck levels I used fill in pieces to make up gaps between the inner and edge castings and that the sizing fault was uniform.  I said that as long as it looked ok I could live with it, well I'm afraid that I now can't. True to form the top tier was again too wide and this time there was no acceptable way of muddling through as this deck was open and in full view. To fit the top deck on the upper windows and not have there top edges showing it had to be so wide that the curve needed for it to line up with the rear transom facia looked  so obviously wrong that something had to be done. I left it for a bit and had a beer not wanting to face the only choice I had and that was to start pulling the transom apart and now knowing how it should look
re-build it correctly.
I've shown pictures of the top deck how it would end up if I didn't redo it, the red dots show the size and shape that it should be, the other picture shows my deck against the one supplied in the kit, you can see the difference.
So that I didn't chicken out I've just torn off the complete last level of the transom. Oh the joys of modelling.
Ken
234.thumb.jpg.06f8f9bffb42d3fa837c6d5406973d76.jpg235.thumb.jpg.f10e44ead56cd71ff42f56a7bbac3ce3.jpg
You have found what makes this part of the ship the most difficult:o. What I did was clamp the stern fascia to the rear of the ship,then "adjusted" the side windows & railings to fit - seemed the best way for me.
Hi Mark, Thanks, now why didn't I think of that !    I'm ok in my mind with this as I've discovered how I went wrong and can rectify it with needing to remove just one level of the gallery.
Ken
Hello Everyone,   As you may imagine work is now in progress so it may be a short while before there is anything interesting to report, so in the meantime here's another picture of a tall ship entering the Mersey. I'm sorry I don't know the name of this ship.
Ken
I think
Alexander Von Humboldt II
Glenn
Current Builds
Scottish Maid, V108 Torpedo boat
Future Builds
Snake (Caldercraft)
Previous builds
HMS Shark (Sergal), Sirene (Coral), Armed Pinnace (Panart), Etoile Schooner (Billings)
Hello again,     Here's my progress report.
The re-building of the galleries has now been completed as you will see in the photos.  I only needed to take apart one complete gallery level and deck to make the corrections needed to bring things back into line, so not too bad. The mistakes that I'd made were that I had made the deck with a slight overhang of the windows below and put the next level too near the edge of that deck thus leaving them too far out from the hull side. As I had done earlier I filled the gap to the middle windows,  it had worked well on the lower galleries and seemed an easy option and looked ok. I had not considered that whilst at this stage it looked ok as the build got higher and the galleries became smaller this extra width that I'd introduced made the curves at the top needing to be extreme to fit and you saw the result.
I made decks that fitted exactly above the windows and started the next level of the tier about 4mm in from the edge, the curve of the balustrade needed was less which made things easier and resulted in the inner and outer windows coming together as they should, no need for inserts. Confirming this was the fact that when I got to it the top deck the kit pre-cut part for it fitted and was used. I fitted a small strip of wood as edge casting around the top of the windows to give them a finished look. Oh for hindsight, having made up these gallery parts once I think that I would find no problems if I were to do it again knowing that the parts DO fit with only small adjustments. The difficulty is understanding the relationship between all the different parts, next to, above and bellow.
Quite a bit of re touching of the area that I had worked on  needed to be done, that really was the only downside. I'm now ready to do the rear facia with all of its gorgeous castings.
ken
238.thumb.jpg.d9c4a32cb5e154f73f6dfc655ffa1090.jpg241.thumb.jpg.7841d666f6cd9b9c2ebb190eb1ae4fc9.jpg239.thumb.jpg.cc82107ebb38530395b3ca38bfe9d6ae.jpg240.thumb.jpg.1c1e9caf71b2b473c9be0fda49c89bd2.jpg
Hello Everyone,      The build continues, probably the headaches to.
I have found very little about building the stern transom, mainly just pictures of the end result so I feel a bit unsure of the approach. Some of the castings don't match up to what I'm seeing and I think that I need to cut away a substantial part of the supplied ply part. But here goes.
I have now turned my attention to the stern transom. First I copied the stern facia from the plan and transferred it to the ply part supplied, there was some adjustment needed there but not too much. I sorted out the cast parts needed and loosely tried them for fit, I saw that it would not be just a straightforward attachment but needed some thought.
I decided to recess the windows into the facia so my first task was to cut out the openings, the outlines for these openings matched perfectly with the castings and no further adjustment was needed. I hadn't intended to open the windows in these castings as the pane areas was so small I wouldn't be able to get a file into the space but thinking that with the other windows glazed they would look out of place just painted so I once again got stuck in. I drilled a pilot hole and using a narrow scalpel I picked out the panes bit by bit. I've shown a picture using my thumb for scale to show just how small these windows are.
Once all the windows were done and loosely placed I checked the position of the balustrades, as you can see the supplied middle one appears to be wrong. I have shown the line that I think it should fit in with, not sure how to adjust it and still keep the eight inserts supplied and shown on the plan.
At the moment I intend to recess the lower windows and balustrades so will need to cut away large areas of the facia to accommodate this, The shaded red area in the picture shows my intention.
I've realized that this facia with all the castings is going to be some weight and that attaching it with just glue isn't a safe option so I'm going to use four small brass screws that the castings will hide to fix it in place, I've epoxied the blocks into place underneath the deck, I don't think that they'll be noticed.
Ken
243.thumb.jpg.acf02edaf1a3de15e66c8c1e05b6685b.jpg244.thumb.jpg.2b21e21b5f0614692c58ce502058d198.jpg246.thumb.jpg.121714f37d82dbd2f8c84c5dbd46f16d.jpg248.thumb.jpg.ca2e43f950ab1cd43b9186fe64e8ea96.jpg249.thumb.jpg.b177bad22ecabc8a00a74af29fb40fe6.jpg250.thumb.jpg.56aa70de4e882eee026e01402dbc8c27.jpg251.thumb.jpg.d25883dd4357e723a58ba0ec772d4ea4.jpg
Hi,  I've just screwed the facia on and I'm having second thoughts about recessing all but the upper windows, so before I cut anything away have you any thoughts that might help me on this phase please.
Ken
Ken, those three narrow strips, particularly the upper two will be totally hidden by the ornamentation and need to remain to help support the metal pieces. It seems that the Iower one is exposed but the infill pieces that go under the lower balustrade will totally hide that as well. I agree with the consistency of preparing the window openings in the metal. Cutting out the plywood behind those windows could add to the realism ... but given that there would be very little light behind these windows, the effort involved may be of little benefit ?
Congrats on all the careful effort going into this project. Each and every one of your photos are full of information.
Pete
She is looking absolutely beautiful.
I bet there is a lot of weight on the stern at this point of the build. As just found out with my Friesland build.
Cutting out those individual window panes will be time consuming but worth it for looks.  Good neat and tidy work.
Regards, Scott
Completed builds:
Awaiting construction:
