On 8/2/2018 at 1:04 PM, svein erik said:
Thanks for kind Word and likes,
but the stamp in not my thing😲 it work at first, Then ......... Its making a mess,
so I looking around the  site and get a hint 😆
Making nails patten using derma rollor, so I order one and something else to go😉
It need to be rebuild a bit.
The problem is you have to much pin hanging out the bottom of your stamp and that allows movement when you hit it. Easy to fix. Straighten all your pins out then fill the voids between the pins with epoxy leaving about a 1/16th of an inch showing. Your problem will be solved
Regards,
Jim Rogers
Damn the Torpedoes , Full speed ahead.   Adm David Farragut.
Hi Svein, really nice work on your Syren. Enjoying your log. Your lanterns are a good addition.
I chose to copper plate my Syren without the nail heads. I rationalized that the nail heads were not obvious unless you were really
close to the ship. I admire all of you that have taken the time to stamp the plates.
There is one fault though my friend, your work area is entirely too clean and neat.😊 How would you find anything?👀
Regards, Harley
Cheers, Harley<p
Under Construction:    USS Yorktown CV-5 1/200 by Trumpeter
Completed:              USS Curtis Wilbur DDG-54 1/200 by ILoveKit
                                USS Atlanta CL-51 1/350 by Very Fire
                                Liberty Ship John W. Brown 1/350 by Trumpeter
                                HMS Spiraea K-08 1/350
                                 USS Arizona BB-39 1/200 by Trumpeter/Mk1 Design
                                 HMS Sir Gareth 1/350 by Starling Models
                                 USS Missouri BB-63 1945 1/350 by Joy-Yard, 9/11/21
                                 USS Indianapolis CA-35 1945 1/350 by Trumpeter
                                 USS Kidd DD-661, 1945, 1/350, on The Sullivans kit by Trumpeter
                                 USS Alaska CB-1, 1/350, Hobby Boss, Circa 2/1945
                                 US Brig Syren 1/64 Model Shipways, Wood
Started, On Hold:  Frigate Confederacy 1/64 Model Shipways, Wood
Hi again and thanks for the likes 😊
I did start the dekk planks. But the nibbing I started after 3 plank (4)
in the practicum its starts after 5 plank (same same but different 🙊
I use boxvood and its hard to nibb this if the margin plank is glue to the ship,
So the margin plank on both side is loose so I can do this off ship.
And I try also the ropewalk,  making rope for the first time
I havent nails it yet but its a good start 😊
Svein.erik
I finaly got the stamp to work, a little rebuild did the work.
so I made some sample to try on a boxvood sheet
but it Seems to me that wen I take of the copper plates from the teip
it kind of roll inn, so wen I put it on you can see its not Strait on the sheet,
Maby this like this or it wil be better wen tones down?
Svein. Erik
Thanks for the liks
I yust started making plates , 15 in one strip and I make 500 for the portside
and I got to say its inspitational to make this when it going so good😀
I think I used about 30 min to make ca 100 plates
I did also make a guillotine to cut the plates using a small hammer .
Svein.erik
Thanks for the likes, keeps me going😊
So what did I do this time?
The dekk planks is now finished and I started to sand the dekk,
I also aply one cote of oil yust so I can see where I need to sand more
after this I have to make more copper plates 🙈
Svein.erik
Great progress! Your deck looks really good! And I love your lantern idea!
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Thanks for the liks and comments
I yust finish the treenail on the dekk, I need some more later wen the hatches is in place
I used #77 drill bit for this and some wood filler  (darker one) and I used 2 hull in one plank
Soon I starts on the copper plates 😶 yeee. ....
Svein.erik
Your deck and copper strips look outstanding. Great job on re-working your stamp.
Regards,
Jim Rogers
Thanks for that Jim
The dekk needs more cleening, but  do that later wen the last nails are dunn
I wil drill some hulls on both ends of the hatches .
Svein.erik
Looks great Eric. The adhesive on the tape causes the lifting as it does not stick well. You did a fantastic job on the plating. Reworking that punch was the key.
Regards,
Jim Rogers
Eric
try going over the copper tiles with a wallpaper seam roller.  I used one and it set the tile very nicely.  See roller in picture below.  don't press down too hard
Sal
Current
Nordkap 476 - Billing Boats
Complete
USCG Harriet Lane - Model Shipways
U.S. Brig Syren - Model Shipways
New York Pilot Boat 'Phantom' 1868 - Model Shipways
