Hi folks😊
The syren is coming a long now, the hull /copper plates are now looking old and used
may needs some repers soon on the slip,  LOL
I did also finish the conpanionway construction
left the dor out for now so I dont damige it. Everything is not glue to the dekk yet.
Svein.erik
Working my way in to .... dekk fittings
weel from syrenscompany. The pumpe is nerly finish etc,
but I did drill the hull for the Canon ball ,eeee it sems to look to small so I try with bigger 2.5mm
and tested it in to the 18 punds corronades from cadlecraft  (it fitts )
Maby I use this insted 😊
Your deck fittings look great! They always are a lot of fun. Where the cannon balls are concerned I also had the feeling that the kit provided ones are a bit on the small side and went with 'larger calibers'.
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Some more work has been dunn to the hull,
but am looking at the headrails constructing and there are no laser carving 😲
These are small and made in basswood, its going to be hell on eaght to carve without nothing to go on,
I took one out and make a pensel mark insted to see how it looks,  wel.... I do Not now....
maby I have to make these in boxvood?
Svein.erik
Thanks for the liks everyone 😄
working my way around,  did some more dekk fittings  (everything is made of boxvood )when dunn I put everything away for later. Then start with the corronades.
and I also started the constitution of the bowsprit (not boxvood this time)
Svein.erik
Once you get that Bowspirit set move slowly around the bow. Unintentionally hitting it can cause lots of damage to your  beautiful work.
Regards,
Jim Rogers
Damn the Torpedoes , Full speed ahead.   Adm David Farragut.
Thanks Jim , I was thinking about that 😲,
So I deside to wait as long as I can and make all the mast etc ,
Then maby yust maby .... it wil survive. LOL
Svein-erik
Looking great Svein,
There is one thing I want to mention. The copper hull looks great but the ageing process ssems to be going pretty quick. Don't forget it will keep going. I treated one sample pretty aggressively and the copper is peeling by now. So at the stage when you are happy the way it looks you may want to seal the hull to stabelise the way it looks. I hope that makes sense.
Cheers, Peter
Current Build:     USF Confederacy 1778 - Model Shipways - 1:64
Completed:         US Brig Syren - Model Shipways - 1:64
                        San Francisco Cross Section - Artesania Latina - 1:50
Future build:        HM Granado - Caldercraft - 1:64
                        LeRenard - Artesania Latina - 1:50
Thanks peter😊
And yes thats my nex questions , since it my first copper hull  plates
wat is the best way to seal and sealer to used ?
Svein.erik
Hi Svein, I can't remember. I think i read about it on Dubz's log. He'll be the one to ask.
Peter.
And something else !
I did say erlyer that my nex build is the cheerful, but thats on hold
wat am going to start is scratch build the M/S Rogaland
its a Coast ship and was buildt in 1929 in Stavanger so it a local ship .
I have a meeting nex week with the foundation about the drawings so I can start planing the prodjekt
for now I do Not have ide of scale and I my have many questions also😲
If some out there has seen the movie Dunkirk then you have seen the ship.
I wil not start a logg for now but I wil do wen I start on the prodjekt nex year.
Svein.erik
Thanks for the liks,
Finish the rudder and the Tiller (its not glued on yet )
but I did a horrible mistake on gluing the gudgeons to the hull and it cant be re dunn😲
Not without ripping of copper plates. ...
I used wrong glue CA , so am not doing that the nex time 🙈🙈🙈, and also do Not build when you have the man flu .😷I did try ,now you can see how that went 🙊
but a question , Wats the best way to glue the gudgeons to the hull ?
Svein.erik
Some more fittings has been dunn,
pin rails are in place  (not glued yet) I used some scrapp wood for this so it stas at the same hight,
the davits is in place, catheads are made (not install yet) and am making new belaying pins also,
for this I used some leftovers from chuck's gratings kit (boxvood ) and used dremel to turn them
4 made ,70-80 to go LOL😲 and it small to.... ( and I used some gum back of the scrapp wood so I got my hand free when drilling etc)
Svein.erik
