I'd say use what you think will work for you.  My kit models were set up using the Billings' jig.  Others use a variety of devices or none at all.  The rotational ones just make it easier to turn the whole thing around for working on the bow, stern and each side.   I do believe some sort of holder/jig should be used to keep everything properly square until several rows (strakes) of planking are installed.
Thank you for the answers Mark and Jim.I want to place long ship in the holder, i know it is very important step of the ship building. I just made some holder, but it is hard to think where to place bolts to hold the ship and later remove them easy, with no harm to the ship frame.
Here it is what i have made already. Any ideas are welcome. thank you!
Edited by zappto
High Zappto I am using 2 jigs I have made One For The Vanguard the other for the Granado, they are constructed using box section aluminium
obtained from B & Q here in the uk, its sold in meter lengths, the finger grips are made from 1/4" steel strip with nylon facings, the units are very good at
keeping the keel straight during frame assemble and first planking, the Granado frame had a very slight curve after removal from the box, and due to the jig's alloy back bone this has now been corrected. the design enables you to complete the first planning nearly down to the keel before removal required. I have included a few
photos, hope this may be of help. Mike
G'day Zappto :). Have a look at THIS METHOD that I used on my Norfolk Sloop kit. You can use the screws to hold the ship to your building board and later on to mount to your permanent base or pedestals.
Instead of making your own "nuts" like I did you could simply use "normal" ones. I suggest you use Stainless Steel or brass ones to prevent any corrosion.
:cheers:  Danny
Cheers, Danny
Hi zappto
While you are designing and making your base board it would be a good time to consider a couple of things so that you can incorporate some features.
You will want to mount your bulkheads nice and square to the spine and the base so maybe think about features to locate a jig to held hold them square.
Also you might want to be attaching things to the model later in the build, so some feature to hook or attach clamps, elastic bands etc might be helpful, could just be a simple lip along the edges.
Nick
Edited by pompey2
You might want to try building your own holder if you do considerable model work.  The crux of the matter is square, square, square as we all know.  dgreen10
