This little kit is a wonderful build and I suspect for a great many people has been very much a gateway into the hobby as a whole. You've done some beautiful work here, I particularly appreciate how tidy so much of your paintwork is, and a lot of the small optional details that you have added just to make things really pop.
Under Construction
HMAV  Bounty, Artesania Latina, 1/48 Scale
Completed
18th Century Long Boat, Model Shipways, 1/48 Scale
Drift boat, scratch build, c. 1/12 Scale
Bluenose, Model Shipways, 1/64 Scale
Went with the claw method and started rigging the deadeyes. But there wasn't enough black rope provided in the kit so I raided my Charles Morgan kit. But now looking back, even though both kits are from Model Shipway and say they are the same diameter, they look completely different so I will be purchasing more Syren rope and re-rig this section. I also started on the backstay and made a jig to seize the blocks for it.
Does anyone have suggestions regarding display cases? I am nearing the end and should probably start thinking about where to get one.
Also any thoughts on how to get closer cuts on the ropes? My seizing looks like a hot mess since I don't own any cutting equipment that can get a close cut on the knots. I am just using an Xacto knife right now.
Edited by mahjong25
Eden
Completed Build: 18th Century Longboat - Model Shipways
I like to use a pair of flush cutting nippers for trimming rigging like that. They're not expensive and are widely useful. They let you get really close to the knot without danger of cutting into it. Nice work!
Amazing work, especially for the first wooden build! I chose this one for my first also. You did such a better job than I did! I butchered it...Looking back, this small scale was harder than the larger ones I've done! Well done!
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
  • 2 months later...
  • 5 months later...
I was finally able to finish up the rope coils on my model and got all those glued on. I didn't like the fuzziness of some of my rope so I used some wax to clean that up and it looks a lot better. The anchor is also ready to go. I just have to finish a couple oars then i'll be completely done! It has been quite a journey. Still need to figure out the display case situation though. :[
Eden
  • 11 months later...
I finally got around to working on displaying my Longboat. I had prepared for the base and drilled 2 holes in the keel during assembly. I cut a piece of walnut and drilled matching holes in them. I used a brass rod to connect the two objects, then slid a hollow brass tube for support. Turned out pretty nice. Also got a piece of curly maple for the acrylic display base. Still need to route some channels for the case. The end is near!
Eden
That is a good looking boat. Well done, I think the grain in that base-piece works perfectly.
STAY SAFE
current builds:
Congratulations on finishing your Longboat.  It is a fine model and I like the way it looks in your case.  Well done!
Ryland
               - Nautical Research Guild
  • 2 months later...
  • 1 year later...
Great Job, looks amazing the way you are displaying it.   I am having trouble (this being only my second build} with the rudder, just can't figure
out how to install.   Is it just glued to the transom and the metal bits are just for show or what am I missing.     HELP!
Ian
