I'll tree nail the deck with 0,5 mm walnut (the planks are 4 mm wide).
right decision (in my opinion)
Robin,
Are you really sure about this grating??:o
I'm not sure of course, but these photo's (and others, but copyright) show the grating I made...
Is there a grating expert in da house? :unsure:
WIP: No ships atm...sorry!🙄
Completed: Greek bireme - Dusek - scale 1:72
 Louie da fly: "I think it requires a special kind of insanity to choose a galley to build a model of."
These are the gratings on the beakhead of the Batavia
Hans
Owner of Kolderstok Models - 17th century Dutch ships.
Please visit www.kolderstok.com for an overview of the model kits available
I checked Witsen
He describes grating as you made them:
the lower layer, measured about two inches high, two wide,
the upper layer nailed on top, battens half inch thick, about 3 inch wide,
I guess the lower layer is around two-three inches apart.
so you would be correct, as soon as you follow the advice of Hans: sand back until zero thickness :)
jan
Thanks gentlemen!
I already sand the top layer down to approx 0,5 mm...will sand it to half that thickness.
The Batavia grating is remarkably close to what the Duyfken builders did. Frugal Dutch not so fancy gratings. :D
Thanks again for your help!
Robin :)
I finished planking the centre part of the deck.
And I used this photo to make the mast foot...
Because the caulking between these planks is very wide, I used 0,4 mm thin walnut strips for this.
After all...the walnut tree nails I'll use on the deck are not tree nails, but is also caulking, so it does match.
The wider/heavier planks (Dutch: schaarstokken) next to the centre part shown here also...not in place...just to show them.
I painted the sides of the deck planks with dark smoke brown (Vallejo 70.939).
Tree nailing this part of the deck is next...I hope I can nail this (lol), it can make or break the look of the deck. Very scary job!
More soon,
Robin :)
Nice work Robin. You can try out the look of treenailing applying dots with a soft pencil - you'll set the positions for your nails at the same time ... if it is not to your liking you only have to remove the pencil marks ...
Carl
the mast foot looks very good.......as does your grating.   I thought you nailed it according to the picture you showed......don't understand what all the fuss was about ;)    if you plan to keep the decking a lighter color,  then you'll do well with the tree nailing......but if you plan a darker finish,  you may lose some of the appeal.  depending on the scale,  some elect not to......but with the width of planking your using,  you should do well with it  ;)    she's look'in great so far.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Very tidy  looking really nice.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Those tree nails will be a long and tedious venture but it looks like it will be well worth the effort. Looking good!!
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Robin, are you planning to place part S (schot) later? Because the deck has to be planked up to this part and I noticed you haven't placed it so far.
Hans
I do part 5 a bit later...I made the planks longer there, so I can cut them to match the cabin wall.
Minor update..
More soon,
Robin:)
Well Carl, the only way I could think of to make the tree nails....
It is tedious, but only making the tree nails...the rest goes reasonably quick and easy.
Marking the place with a pencil, the drilling, placing (with a drop of PVA on the tip), cutting and sanding...all no problem at all.
Just sharpening those 1x1 mm walnut strips takes most of the time. I do a batch of about 40 in 30 minutes....just the sticks.
Where I am now...
By trial and error I learned it's far more easy to use longer punji sticks.
The cutting off with a cutter or a pair of decal scissors, filing and sanding is done in minutes.
It's all fine, because I think it is worth the effort and because it's 1/50 scale the 0,5 mm tree nails don't look too oversized.
A lot of it will be hidden underneath the foreccastle and the quarter deck, but well...I do those also. :D
138 done!
More soon,
Robin :)
Edited by Robin Lous
On ‎13‎.‎11‎.‎2017 at 9:17 PM, amateur said:
I checked Witsen
jan
I' am probably a bit late to the Party, but here a Photo I took on the Batavia which shows the dimensions..
Cheers,
Udo
Current builds:
Le Coureur 1776 - CAFmodel 1/48
VOC Retourship Batavia
Boston Typhoon steam trawler 1/32
Research/Side Projects/On Hold:
H.M. Bark Endeavour
HMS Bounty 1787
Thanks guys,
I now finished the centre part of the deck planking...including the wider planks (schaarstokken) these wider planks don't have nails in them.
Different from the manual. After checking photo's these planks are wider, but not noticeable higher. The manual uses 2 regular planks glued on top of eachother.
I used wider planks...only a fraction thicker.
232 hecho a mano tree nails used so far.
I can now continue the planking, but near the sides (in between the frames) it has to wait until after the hull planking.
Frames 4 to 8 will be removed after planking the hull.
Slow, but steady...more soon.
Robin :)
Just to show I'm still working on the shipyard...a minor update.
Only very limited shipyard time until January, so things slow down, but I do something daily.
Most deck planks done, so more nailing trees soon.:P
I switched from painting the sides of the planks with a brush to dab the paint with a cotton bud.
This goes much faster and it doesn't destroy my paint brushes. I use undiluted acrylic paint, so the paint won't suck into the wood.
More soon(ish),
Robin :)
Thanks...the deck planking is abachi, the tree nails are walnut.
I picked walnut, because the tree nails are tiny (0,5 mm)
I'm not sure what I should do with the hull planking. The planking will be walnut, so no idea what I can use for the tree nails there.
I'm afraid lighter wood will look odd. Walnut on walnut might be subtle, but perhaps hardly visible ( a lot of work for no result?).
Robin,
Just found your log - I will also bring my chair. Nice project
Your deck and tree nails are so excellent.
Good start indeed.
Nice to have photos of a replica from which to assist (:-))))
Yes - Chuck at Syren has such excellent products -
I have been buying his ropes and blocks over the last two years - his rope quality/color are always consistently excellent. It doesn't matter
how many separate orders I place.
Cheers,
Under the table:
Woody Joe Higakikaisen
Completed:
Santa Maria-Mantua --
Vasa-Corel -
You could try to stain the tree nail lumber a heavier shade of walnut to make them a darker color. It would still be subtle but I think more noticeable than it they were the same shade.
-E.J.
