About 1/4 of the real size. :rolleyes::D Sorry I couldn't resist.
No really. I don't know what era or type of ship you are building but at least one research paper states that based on excavations at Pacific Wharf in Rotherhithe England that in the 16th and 17th century they were made in three sizes and seemed to be about 1" for every hundred feet.
Others here may have more precise information. Hope that helps.
Lou
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Lou, I think has it about right.  But there's also the variables of where the treenails are being used... deck?  upper hull?   Underwater hull?   Beams? etc...   And then there's which nation?   The French used a combination of wood and iron nails.
From the ASA 1885
Tree nails
outside planking
plank thickness     treenail inches
1                          7/8
2.5                        1
3-3.5                     1.125
4-4.5                     1.25
5-5.5                     1.375
6- <                       1.5
I 'll leave it to you to divide by 48 to get model scale
Since the physics did not change and at scale - any difference in scantlings over the 200 years hard to notice
this should be ballpark enough.   The largest is #68 gauge at scale - not easy to draw and easy to break.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
The treenail colour also matters a lot. Real treenails are basically invisible, you need go come very close to see them (except iron bolts). Model ones are mostly an aesthetics choice, where colour contrast affects visual size much more than the diameter.
It would be wise to make a large enough test piece, using the same wood and plank size as on a real model, and then experiment with various woods and sizes. Always put the finish on, since it changes the treenail colour a lot (absorbing into endgrain differently than into the plank).
if you add various finishes in the mix - the number of test boards might increase :)
Edited by Mike Y
Submarine Blue.
What is our name?
To make trennals down to 0.875 real world, which is 0.018 diameter, bamboo is about the only wood that can be used consistently.   Use a good quality draw plate such as from Jim Byrnes and you can make a couple hundred per hour.   Undyed garden bamboo stakes can be split with a knife into thin strips down to the largest hole in the draw plate then run through consecutively smaller holes until you reach the diameter you want.  Most hull planks are about 3 to 4 inches thick except for the wales and upper strakes, so 0.023 is an average trennal diameter at 1/4 scale.   You will need upwards of 10,000 for a good sized frigate, so it will take a while but definitely can be done.
Allan
Just as another data point....the 1/48th scale yacht America from Bluejacket supplies 3/64th inch basswood dowels to use as treenails  for the hull planking.  3/64th = 0.047, which would be 2 1/4th inches scaled up.  I did not do any research to verify, though I assumed that is larger than scale, but probably the smallest diameter basswood dowel that is practical to make and use.
I forgot to say that the 1" per 100' quote I used above was for hull tree nails not deck, based on archaeological excavations on the Thames. The paper does not state anything about deck tree nails.
I personally like Jaager's numbers best. But at this scale it will make almost no difference I think as you are looking at less than 1/32" or .79mm if you are using MM, between large and small.
Still an interesting question. I learned a couple of things from the answers as well.
Lou
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
The .75 range of size i used above as an example was just a figure off of the top of my head made rather late in the evening and I suppose i should not have done that. I apologize for my laziness. The real range at 1/48th scale between the largest and smallest tree nails in Jaagers formula is .3333 mm. Hardly a  significant amount when viewed with the normal human eye. The difference becomes even less when in all probability you are dealing with tree nails that are somewhere in the mid range anyway.
If 1.25 mm is what works for you then Jaager worked it out with his formula. Might give him a thanks.
Still don't know what ship/period you are building or are contemplating to build so really sorry i can't comment on your decision further than that.
Lou
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
I ve used many thousands of treenails in my current boat, mainly to hold the planking in place (no glue used). I also use 1 mm screws to temporarily hold things together and then remove them and fill the holes with tree nails. For a quick way of making them in bulk, at any size have a look at this
https://modelshipworld.com/index.php?/topic/13063-tree-nails-in-bulk/&tab=comments#comment-398038
