look'in good Dave :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
2 hours ago, yvesvidal said:
: Hybrid = Plastic/Wood
That's what I call them too
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
I really do enjoy to view your „hybrid build“, as it gives a plenty of ideas to me what is possible to get the most out of both.
As I have got no knowledge what ACC is and never used - is it a kind of silikon to join wood and plastic?
I trink about using CA to join wood and plastic - am I wrong? Can you tell me please what product do you use?
Edited by Heinrich der Seefahrer
Added questions
"Let's add every day 1/2 hour of
modelship building to our
projects' progress..."
Take care!
Christian Heinrich
simple, true and inpretentious motto of ROYAL LOUIS, 1668
Sunking's mediter. flagship most decorated ocean-going ship
Ships on build:
SAINT PHILIPPE, 1693:
1st rang French 90-gun ship - Lavente flagship (based on Heller SR - 1/92 & scratch in 1/64)
TONNANT, 1693:
1st rang French 90-gun ship - sister of SAINT PHILIPPE (mock-up/test-object for S.P. - scratch in 1/64)
Projects in planing:
L'AURORE, 1766:
French Pleasure Corvette (after Ancre plans - scatch in 1/64)
Some Spantaneous Short Term Projects
Heinrich
    This type of adhesive is maybe better known as "super glue".  Technically it is cyanoacrylate or CA for short. It has a penetrating action that acts as a sealer on wood.  It will also bond metal, plastic, glass, jewelry, and by the way your skin if you are careless.
    It comes in three basic consistencies. First off there is thin, which flows into the tightest joints and will cure in 1-5 seconds.  Second is the mid-cure that is a bit thicker and can fill slight gaps, curing in 20 seconds. (Most commonly used.)  Then there is also the extra thick slow cure formula that will fill larger gaps and cures in 90 seconds.  This one is best for laminating sheet materials or other large surfaces, as it allows more time to position the pieces.
    There are two other products that are commonly used with CA.  There is an accelerator commonly referred to as zip-kicker that when sprayed on an AC glued joint will make it bond instantly.  The other one is a debonder that dissolves CA adhesives, removing cured residue from your tools, clothing, and most importantly your skin if you have a mishap.
     Some of us swear by it, while others won't use it unless absolutely necessary due to some of the side effects of prolonged exposure to the fumes, so it is generally advised to use in well ventilated spaces and to avoid inhaling the fumes.
     It is commonly available here in the US modeling shops and even in beauty supply outlets as it is often used for false nails.  There are numerous references to these products in MSW build logs.
    Hope this is of some help.
Dave
“You’ve just got to know your limitations”  Dirty Harry
Current Builds:  Modified MS 1/8” scale Phantom, and modified plastic/wood hybrid of Aurora 1:87 scale whaling bark Wanderer.
Past Builds: (Done & sold) 1/8” scale A.J. Fisher 2 mast schooner Challenge, 1/6” scale scratch built whaler Wanderer w/ plans & fittings from A.J. Fisher, and numerous plastic kits including 1/8” scale Revell U.S.S. Constitution (twice), Cutty Sark, and Mayflower.
                  (Done & in dry dock) Modified 1/8” scale Revell U.S.S. Constitution w/ wooden deck and masting [too close encounter w/conc. floor in move]
Hope to get to builds: MS 3/16” scale Pride of Baltimore II,  MS 1/2” scale pinky schooner Glad Tidings,  a scratch build 3/16” scale  Phantom, and a scratch build 3/16" scale Denis Sullivan.
    As I continue to replace the deck beams, I thought I should show how I remeasured and re cut them to fit.  I decided to make a small version of a measuring jig that my grandfather taught me a long time ago to make the inside measurements for the deck beams easier to make accurately.  Of course the jig that he showed me was quite a bit larger as he used it to make furniture.
     The first photo is the basic four pieces: the two longer pieces have one end cut square and the other end cut at an angle, the short two pieces are just slightly wider than the thickness of the longer ones.  The short ones are glued with CA to the edges of one of the long ones.  The remaining long piece is waxed to allow it to slide easier in the assembly as shown in the next photo with the short pieces to keep the measuring stick straight.
    All that is needed to complete the stick is a small clamp to hold it in place.
    The divider takes measurements off of the layout sheet from the reference point by the main hatch to one edge of a beam where it intersects with the ledger on both sides of the template.
    Then taking that setting on the dividers with one tip on the reference point on the hatch beam and the other on the both sides of the ledger where a tic mark is put on the ledger.
    Now the measuring stick is stretched out between the ledgers to get the length of the deck beam at that point.
    The length is marked on a scrap of paper and the center is found.  The beam is then marked so the same amount can be trimmed off of each end.  Once the maximum length is marked, the beam is trimmed down to include the angle of the ledger.  Slow trimming with a lot of rechecking the fit often is required here.  Nothing to it!  It just takes awhile.  :)
Dave
Thanks a lot for the CA-lession... there was my idea that wood wouldn't hold due to the structured surface. But with a filler in the grain it certainly will work. 💡
I'm very interested in your project as I like the WANDERER and read abaout her sad end, her rudder found miles away from the wreckside. She is the proud end of the rigg shiped whaling history and you do a great job on to her memory. Thanks for your work, impact into this awful kit and showing all these interesting solutions to us.
🏇 ...I think I just sayed what many of us think and don't write down, because it should be written down in any thread inhere but sometimes it is important to let A SINGLE ONE know what is right for anybody.
Take care!
Christian Heinrich
Ships on build:
TONNANT, 1693:
L'AURORE, 1766:
    I just ordered two 1.8 mm orange flickering LED’s from one of our sponsors: Evans Design LED.  I plan on installing them in the lower deck ceiling to give the appearance of oil lamps to give everyone a better chance of actually seeing what’s down there.  I was inspired to try this by going through the build logs by Doris.
    The ones that I ordered didn’t have long enough wire leads, so I ordered extra wire.  These LED's have a click switch and are powered by a 3V coin cell holder which I will hollow out an area in the bottom of my base board for with the wires passing through the keel and mounting stand.
    For less than $20, I thought that if it doesn’t work it won’t break the bank.  I’m still working on replacing the beams, but I’ll need to install the lights anyway before I tackle installing the deck.
    I plan to make a grating for the inner deck hatch with it set beside it and having some of the crew lowering an oil cask into the hold.  Four knees and a couple casks already in the hold will also be installed for a little more interest.  I'll have to look for some info on how they went about this task.
   Sorry, no pictures this time as not much has changed, more to come later as we are having our 6th of 6 Christmas celebrations here with the gals and their families from my wife's shop tonight.
Dave
   Now here is my knee production method.  First off, I took a billet of basswood of the desired thickness and cut triangular pieces with the grain running parallel to the long edge.  The remaining edges of these pieces were squared up with my sanding fixture as shown here.
    Then I drew a rough outline of the shape of the knee on all eight triangles to help keep track of their orientation, as one leg was longer than the other.
    These were grouped in sets of four that were glued up with a thin coating of rubber cement on all the facing surfaces and clamped in place overnight to dry.  The next day I drew the pattern on a stiff piece of manila folder and cut it to shape.  Holding the pattern in place on the face of the glued up blocks, the pattern was traced onto the top blocks.
    I clamped the blocks in my vise and using a small back saw trimmed off the majority of the waste.
    The blocks were then sanded close to the outline of the knees on my 2” belt sander being careful keep the block flat on the table.
    Now, using several grades of sand paper on sanding sticks the blocks were sanded to their final shape.
    Now the blocks were separated from each other with a chisel driven into the glue joint.  Even though I only used rubber cement to join them together, they were still held together surprisingly well.
    Now I had the eight knees duplicated to the same shape.
    Using a fine sanding stick, I eased the exposed edges of all the individual knees.
   Here are all the knees cut to final shape and given a coat of stain and two coats of polyurethane.  I still need to add two bolts to each knee, which will be included in my next posting.
Edited by BETAQDAVE
wrong word
Dave
     I set up this drilling jig with rubber cemented scraps and mounted it on my Proxxon X-Y table as shown.
    The knees were all placed in the jig as shown to place the bolts consistently.  I drilled the holes clean through for a .023” x 1/4” steel brad in each leg.
    I soaked the brads briefly in a full strength solution of Brass Black and let dry.  The brads were then pressed through the legs of the knees.
    The brads were slightly too long, but rather than trying to cut them shorter and risk having them disappear, I just put them in my vise to file off the excess.
    The knees were then glued in place with some medium CA.
    Now I came to realize that the beams had not been sized to scale, as they were originally not going to be visible, but now that this had changed, I thought they needed to be reduced in depth.  You will notice that a line was now drawn on the face of the beams here.
    With a good deal of trouble they were reduced in place with scalpels and chisels.  This also would allow a little more to be visible inside the hull, so I thought overall it was a good thing.  Also, in this view from above, you can see that the bottom of the hull would be visible.
    Taking another section of the pre-made decking, I marked the treenails and plank ends on this sheet.  This was finished the same as done previously.  To make this sheet of planking conform to the bottom of the hull, I made numerous shallow cuts in the backside of the sheet parallel to the deck boards.  This allowed the sheet to flex enough to match the curve of the hull bottom.  The sheet was slid in from the stern, and held in place by using a pencil eraser down through the hatch.  I then dribbled some thin CA down alongside the gap in the hull walls that secured it in place.
    The next thing to do now is to set up for the LED lighting.
Dave
    I decided to install two orange flickering LEDs in the lower deck.  One to be placed one frame from the hatch toward the bow and the other one frame from the hatch toward the stern.  Here you can see that the beams at the hatch have been reduced in depth closer to scale.
     For the one at the bow frame, the wires had to be run between the inner and outer hull sides as shown here.
    The one toward the stern was offset slightly to avoid the main mast.  The LEDs were glued in place with some medium CA.
    I drilled a 3/32” hole (large enough to pass the four wires with the shrink wrap) in the bottom of the hull on the port side which will be the side of the ship against the wall when displayed and thus less visible. The excess wire was coiled and taped to the hull for now.
Dave
Very cool work Dave.  Love the enhancements and following all your creativity!
I saw you mentioned you build the Wanderer in wood.  Do you have a picture of that one?  I'm working on the Morgan at the moment, but have thought about scratch building another whaler like the Wanderer once I'm through the kits on my shelf.
    Sorry Mike, built many years ago, long before using PC's and before I ever even thought of taking pictures.  Can't remember who I built it for either.
Dave
On 12/3/2018 at 2:28 PM, BETAQDAVE said:
This did however bring up a question about the inner deck.  I assumed that the inside deck had a matching hatch opening going into the bottom of the hull to store the casks of oil.
    My question is: did this inner hatch have a combing with hatch covers, a grating, or was it just left open?
    After much searching I managed to find this sketch in my copy of Whale Ships and Whaling by Albert C. Church on detail # 158 that showed a combing for the lower hatch, although still no cover was evident.  If you look closely, the sketch also shows a bolted knee that I also incorporated into my lower deck.
    However, looking in numerous build logs since, I am at a loss as to what function this knee serves.  Every POF log with interior details that I came across show knees supporting the decks above rather than as shown in the sketch.  Does anyone know its function or have I included a detail that does not really apply to the Wanderer, since there was no cooling tank that that I know of below her decks?
Dave
    Still not sure about the knees, but on to something else for now.
    One reason that I decided to make a grating for the lower hatch was that my kit for the MS Phantom had precut grating strips that, @ 1:96 scale, were overlarge for that kit.  Since I was working now @ 1:87 scale, I thought they would be a little closer to scale size for this ship. (Maybe?  Maybe not?)
    At any rate, I wanted to try making some grating anyway.  These were intended to be assembled by overlapping, but I thought that the thickness would still look too much out of scale.   Cutting off some lengths close to the required finished size, I took them once again to my square sanding jig and sanded one end square. As the nubs were very fragile, I was careful to only sand toward the guide or risk snapping them off!
    Needing a surface that was both flat and that my carpenters glue would not adhere to, I found a framed picture with glass of our favorite neighborhood dog Chester. (He passed several years ago, but I didn’t think that he would object to helping me out.)  Anyway, the frame corner was square so it would also serve as an assembly jig.
    I took one strip at a time, and with a tooth pick applied just a small dab of the glue to each of the nubs. Then they were butted into the corner and against each other briefly to let the glue grab hold.
     This was repeated for each piece until the assembly was wide enough for the size of my grating.   I took a scrap of basswood with wax paper on the bottom, laid it on top of the grating blank with a size D battery on top to make sure it remained flat, and let it dry overnight.
    While this method allowed me to have enough material to make the grating and make the thickness more to scale, I was thinking that those minuscule dabs of glue wouldn’t be sufficient to hold it together.  As it turned out, I was right, the assembly was very weak and kept separating when sanded.  I applied some medium CA to the backside of the joints which helped some, but I decided to add a frame around the grating to add some more strength to it.  I ripped down some 1/32” strips of 1/32" maple for this frame.  The grating still needed some downsizing on the long dimension, so I cut the frame pieces so the ends would overlap and glued two pieces to one corner with more CA and put aside to set overnight.
    Next, I took the assembly to my disc sander and very carefully trimmed the long end of the grating down to match the length of the long frame piece.
    Here, the remaining frame pieces were glued on with AC and left to set.
    Once it was dry, I sanded the faces of the completed grating flat by hand, as I still had my doubts about its strength.
   I decided not to stain the grating frame, so just two coats of poly were applied for my finish to leave a little contrast between the grating and the frame.
    I plan to leave the grating off to the side of the hatch as the ship will be displayed in the act of loading a cask of oil down into the hold.  So, now to figure out what comes up next.
Dave
    While trying to determine what size to make my oil barrels for the Wanderer, I found that apparently among some historians, there was a lot of disagreement on what size the barrels were for oil on these ships.  I found that 31.5, 35, and 42 gallon sizes were most common, but some barrels were 750 gallons or more.
    For example, check out the size of this barrel in this old photo (shown in Google under the heading whale oil barrels by Spinner Publications #ST 00841) below that three dock workers in New Bedford were trying to move around. :o  It looks to be over 400 gallons or so as near as I can estimate.  It must have been a royal pain trying to muscle this thing around below decks, and this isn’t even one of the really big ones!
     Further searching through google revealed that apparently the barrels actually came in many different sizes as shown below in an illustration diagram included in an article that I came across written by Sara Kay Bierle in a posting of gazette665.com.  If you look closely, you can see at least six or seven different sizes and that in the area of the bow, the knocked down barrel components were stored until they were needed.
    Ship’s Layout
This diagram from an 1887 publication shows an example of the interior of a whale ship.
    Logically speaking, I guess that that does make some sense, since they were trying to get as much oil as possible below decks. In the complex shape of the inside of the hull some areas could accommodate the larger barrels, but then again, the tighter areas couldn’t be efficiently filled unless the barrels were smaller.  Many barrels had elongated shapes to fit into some of the tighter spaces, and in some cases the ships coopers were even known to have made custom sized barrels as needed.
    As whalers owners were paid by the number of barrels of oil she could hold, it leads to some confusion as to exactly how much oil this would have been.  I suppose that when the final tally was taken in port, the officials there would measure each barrel, calculate its volume and multiply by the number of similar barrels.
     In some of the articles that I came across, buyers would pay the ships owners by the number of 31.5 gallon barrels that this converted to.  Seems to me that just converting to the number of gallons and paying so much per gallon would have been simpler, but who knows for sure. So, I guess that as far as I’m concerned, I'll just make a few different sizes for my Wanderer.
    By the way, during my search for oil barrel sizes, I came across some photos taken below decks of the C.W. Morgan that did show my reinforcing knees between the inner deck and the inner hull.  However, in addition to those knees and right beside each one of them was an additional knee between the inner hull and the beams for the upper deck!
    So, now it looks like I need to make another set of knees.  Good thing I found this out prior to attaching the deck!  I think that I may have cast a few choice phrases about while trying to squeeze them into place somehow. :Whew:
    There were also quite a few more bolts in each one than the number that I put in, but trying to add them now to the ones that I have already installed might not be feasible.  I think that I may try to see just how hard they are to remove and put in more bolts, but otherwise I’ll just stick to two bolts in each one.
    So, for now it looks like I’ll just have to get back to making more knees for a while.
Dave
I always like to learn the history revealed from the research done on these kind of details.
Jesse
    I just spent several long hours engrossed in searching out as much of the history of this ship as I could get my hands on within the limits of the internet and my small maritime library.  What I found was quite interesting and I think that knowing the ships life story just makes me more determined to make an accurate replica of her.  While I’m sure this is hardly her whole story, it’s as complete as I could come up with in such a short time.  What follows is a short narration of what I discovered, from her launch to well after her tragic end.
    The Wanderer was built in 1877-78 in the shipyard of J. H. Holmes & Sons in Mattasoisett Ma. for the owners Gifford & Cummings of New Bedford, Ma. She had the distinction of being not only the last whaler, but also the last ship of any kind to be built there.
    The Wanderer had the last of her restraining blocks removed and she slipped off the ways on April 16, 1878.  She was then taken just a few miles to the shipyards in New Bedford for her final fitting out for sea rigged as a bark, also notably, the last ship to sail from there.  She measured 116’ stem to stern with another 50’ of bowsprit.  Her beam measured 27’-8” with a draft of 15’-8”.  From her decks the mainmast rose 125’.
    On June 4, 1878 she set sail from New Bedford on her first four year whaling voyage which took her to San Francisco Ca.  Changing her registry to that city, she then sailed from there on August 29, 1882 to hunt the whaling grounds in the North Pacific and Arctic oceans.
  In February of 1903 the Wanderer left San Francisco on another four year whaling voyage that saw her return to New Bedford.  In the following 20 years she would make 11 more whaling voyages. She also made a short side trip as a Hollywood stand-in for the Charles W. Morgan in the silent movie “Down to the Sea in Ships” filmed in 1921-22.
    For her part she was rigged to match the Morgan and was filmed in all the scenes shot at sea.  At the time the Morgan was deemed unseaworthy and was only used for the scenes in port, thus a star was sort of born.  The film never gained much acclaim as a film, but the Wanderer for her part gave a credible performance as a whaling ship.  While watching the film, I found the story and the acting to be rather poor, but the actual act of hunting the whales was true to form.
   There was another film with the same title made in 1949 staring Lionel Barrymore, Richard Widmark, and Dean Stockwell.  This version bared little resemblance to the first, but the acting and story line were far superior.  However, both films showed a good view of life on a whaling ship and allowed me some glimpses of the ships’ details that should help me to improve on the model.
    Getting back to my ships history, after WWI the price of sperm whale oil had dropped drastically as crude oil drilling on land became a more economical source.  Although some nations still hunt whales for food, hunting them for oil became more and more of a poor investment.
    As somewhat of a last gasp however, the Wanderer was once again fitted out in the summer of 1924 for her last whaling voyage.  What followed was the end of a proud ship, and at the same time signaled the death of the American whale oil industry.
    The Wanderer was anchored just west of the Mishaum Ledge Bell Buoy on August 24, 1924 waiting for more favorable winds, when a large tropical storm system that was coming up the east coast came through Cape Cod.  The ship was hit from the NE with extremely heavy squalls and gale force winds.  Around 10 AM on the 25th, her main anchor chain broke, and despite dropping a second anchor, she was driven by the winds across the bay.  She was flung high up on the rocks of the Middle Ground Shoals off of Cuttyhunk Island.
    Seven members of her crew were picked up the same day by the Cuttyhunk Life Saving Station.  A second boat, with eight men aboard reached the Sow and Pigs lightship the following day and was rescued by the lifesaving crew there.
    So much for the crew, but the ship was considered a total loss at this point and salvagers began to work recovering what they could.  The remaining boats, sails, whaling gear, the figurehead and the mailbox were all removed, but a second storm blew in on September 30 and completed the destruction of the ship’s hull, washing her rudder ashore about a quarter mile down the beach.
    Eventually a few other components of the ship were recovered including her mizzenmast which would serve as a flag pole in Mattasoisett Shipyard Park until being struck by a bolt of lightning in 1964.  It now hangs in the Mattasoisett Historical Society building.
   Just recently on January 16, 2013, another component became noteworthy.  A 34’ section of the salvaged foremast from the Wanderer was donated to the museum from the New Bedford Whaling Museum after concerns over its preservation came up.  During a renovation in New Bedford of their museum back in 2010, it had been moved outdoors.
    Since the artifact was too long to fit in the small museum building in Mattasoisett however, the Historical Society built a shelter to display it and protect it from the weather.
    So ends my tale of the last American sailing whaler to set out on a whaling voyage, short as it was. Now the Charles W. Morgan has outlived its theatrical stand-in to become the last surviving American whaler, but no more famous than the Wanderer in my mind.
Dave
    Here is just a short update.  Try as I might, I was unable to come across any photos or sketches of the Wanderer below the main deck (including the 1921 film) so I find myself looking closer to the wealth of info available on the C.W. Morgan which was similar.
    Finally I was able to relocate this photo on the Mystic Seaport web site of the lower deck of the C.W. Morgan.
elbows-frames_tryworks-charles-morgan-aug2013.thumb.jpg.7b35797a507af327706f59a27fda47cb.jpg
    It clearly shows both the knees for the main deck support beams above and the ones on the lower deck floor.  You can also see that the knees have more than a dozen bolts each.  True, the C.W. Morgan and the Wanderer were different ships, but overall they shared many of the same features and I can’t see why they should differ greatly on this detail.
    Well, I did try to remove the lower knees to install more bolts, but apparently they were glued too solidly, as they didn’t want to budge. I was afraid if I tried too hard, I might ruin the lower deck assembly.
     So, I resigned myself to leave them in place as they were and made up the eight new knees for the main deck support beams pretty much the same as the knees previously put in.  They don't actually attach to the floor beams above, but that will not be readily visible even with the lights on when the deck above is installed.  This is about the best angle available to see them at all.
    The existing knees had been easier to install as there was still enough room to get access with just my fingers, but they were now reducing the clearance available for the new ones.  Since the new ones basically stand on their tips, the hull needed to be laid on its side so gravity would allow me to attach them on the inner hull walls and the other knees.  The photo below shows one side complete.
    The knees alongside the hatch were the most difficult as I needed one hand to set them in place and the other hand with a stick held at an odd angle to hold them against the wall and the other knee as shown below until the glue could take hold.  Using medium CA was definitely the way to go here, as just a couple small dabs were needed and I didn’t need to hold them in place for very long.
    This is the status of my ship right now.
    I’m thinking that installing the deck will be the next phase to tackle.  There are some things to take care of first, namely some things that have to pass thru the deck itself that won’t be accessible once the deck is fastened down.  The rudder shaft, the hawse pipes and the anchor chain for example.
Edited by BETAQDAVE
extra photo at end
Dave
That looks great - best wishes from my big grinner.
Take care!
Christian Heinrich
Ships on build:
TONNANT, 1693:
L'AURORE, 1766:
    Just a note here to say that my plans from A.J. Fisher that I have based most of my speculations about the details of the Wanderer were originally drawn by Captain E. Armitage that first appeared in three issues of  Popular Science magazine back in 1932.  He, himself, actually built a model of her based on those plans.  They are the most complete version of this ships’ construction and details that I have been able to find.  I felt fairly confident that, as he was able to actually go aboard the ship to take photos and measurements just before she started out on her last tragic whaling voyage, that the information was accurate.
    While many of the details of the Wanderer and the C.W. Morgan are similar, the sterns differed quite noticeably.  Once again referring back to a photo on the Mystic Seaport website you can see that the stern deck cabin on the Morgan continues right into the transom with the rudder shaft portion of the steering gear housed in a small enclosure (see below), but the Wanderer deck cabin stops short and has the stern portion of the deck exposed with the entire steering (commonly referred to as a shin knocker) mechanism exposed.
    What was provided in the Aurora kit is somewhat true to form in that it’s exposed, but it’s still a far cry from what was actually on the ship.  Anyway, I hardly think that this small pin (shown below) through the deck could handle turning that large rudder!
    So, I went back to my drawings from A.J. Fisher to determine how to show this detail.  The deck plan and the cross section shown on the blueprints below indicate that the rudder shaft continues through the hull and, although reduced somewhat in size, the actual rudder shaft is notched down, passed through the tiller and pinned with some type of through bolt.
    The drawing below included with the blueprints shows a good illustration of this detail.
    Since the shaft of the rudder supplied with the kit is way too short, I think that I will just make a new one.  So, the first order of business was to notch the last floor support beam to allow the shaft to pass through the deck and into the tiller.
    As I was making that notch with a drill and rasp, I decided that putting another LED light below the skylight would also be a nice touch.  For the light to show better, I needed to clear an opening for the light to show through better. The inside face of the skylight was measured and marked on the beams.  Rather than replacing the existing beams and re-framing the whole area, I just remodeled the opening a little.
    First cutting some reinforcing blocks that were lined up with the inside edge of the skylight; I glued them in place with CA, and let it set overnight (since they would be getting some rough treatment) before cutting back the beams.  Once that was done and the glue set up, I took the entire hull to my drill press to remove most of the material by drilling through the parts to be removed at the corners and then paring down the rest of the opening with a chisel.
    While I wait for my new order of LED lights to arrive, I will start working on the hawse pipes.
Edited by BETAQDAVE
photos out of order
Dave
    These are two shots of the blueprints at the bow showing the details of the hawse pipes.
    You can see that the anchor chain travels from the hawse pipe opening at the bow, then up through the deck, around the winch, and then back down through the deck.  The first step was to cut out some notches in the frames for the pipes as shown below.
    Through some rather poor planning on my part when spacing the beams, I put beam #2 right where the upper end of the hawse pipe turns up to go through the deck.   Taking some 1/8” brass tubing, I first beveled one end with a file by trial and error to match in with the hull at the hawse hole.  Then I cut that section of tubing off to end at the edge of beam #2.
    So far, it looked good so I cut the other one the same.
    In order for the chain to go up through the deck, I mitered the end of the tube to let the chain make that bend.  Tilting the hull bow up, the chain was passed through the pipe.
    I tried to pull the chain up across the edge of the miter, but found that it didn’t want to go.  Thinking that I would just shorten the pipe short of beam #2 to allow the chain to make its own way around the bend I tried pulling the chain again and found that it seemed to work a little better. So I did the same to the other pipe and coated both of them in brass black and let them dry. I then glued one in place with some thin CA to test it again.
    Apparently all the coating did was just increase the friction between the pipe and chain and it didn’t function as well as I would have liked.  It was time for me to rethink this whole detail.
    So now, looking a bit closer at the blueprints, I realized that the hawse pipe just needed to be larger.  The too small pipes were then pried out and I started over with two 7/8” long sections of 3/16” brass tubing.  Of course that required reworking the notches to allow the larger pipes to fit flush with the bottom of the false deck, but between the larger pipes and no coating applied, the chain now slid quite freely.  Both pipes were therefore glued in place.
     I guess that it was just a bit of overkill with the brass black as when the chain was in the pipe I wasn’t able to see the brass tubing anyways.   Now I was left trying to figure out how to make the end of the hawse pipe where it went through the deck.  Again taking the 3/16” brass tubing, a section just long enough to go through both the 1/16” false deck and the 1/32” finish deck with a little extra above for the lips and maybe a bit more below decks to give the illusion of a hawse pipe.  Therefore, the notches on beam #2 were also cut larger to accommodate those sections of tubing.
    Now I’ll have to contemplate just how to make those lips on the exposed portion of the pipes on deck.
Dave
    I drew up a couple of sketches of how to make the hawse pipe openings as shown below.
    Taking a length of 12 GA solid copper wire left over from wiring the shop I stripped off the insulation.  I thought that the diameter of the wire looked to be just the right size for making the lips to scale.  (This is similar to a commonly used method of making split rings.)  I clamped a 5/32” drill bit in my vise and bent one end of the wire alongside of it in the jaws of the vise.  With the free end of the wire held with a vise grip pliers, the wire was tightly wrapped around it about eight times to allow me to have extras in case of failed attempts.
    Once the drill bit was removed from the coil of wire, I used my soldering torch to heat the coil until it was a nice cherry red to make it more workable.  When the wire cooled off, a stick of 5/32” dowel was slid into the coil and they were clamped lengthwise in my vise to allow me to cut the rings of wire loose with a fine bladed stiff backed saw.
    Having six good rings cut loose, they first were flattened and then squeezed closed in my vise.  Since the lips needed to be formed with a half round profile, I laid them flat on a large metal file and with a short piece of soft wood for a handle they were filed flat on one face.  The piece on the bottom photo has been properly flattened.
   While the copper was a little softer when heated up, each ring still took me more than 100 strokes each to make them flat.  Perhaps I should have come up with a different method of flattening them with a power tool as it really took a toll on my shoulder!
    When all six rings were finally flattened, the joints were soldered closed and filed smooth.   Taking another look at the blueprints they showed that the upper end of the hawse pipe came through at a sharp angle and thus the opening needed to be oval shaped, contrary to the round openings formed on all four of them on the Aurora kits deck below, so I simply squeezed them in my vise until they looked right.
    Returning now to the pipes themselves, the two openings just aft of the windlass leading down to the anchor chain lockers would only need a short straight length of pipe, so that would be easy enough to do.  However, as I drew up the sketch (shown previously above) of the angled pipe situation, I figured that the oval shaped openings would require two pieces each.   One would just be a very short length of pipe filed down at a sharp angle on the top end where it meets the bottom side of the deck, while other one needed to match that oval shape and its length needed to match the thickness of the deck.  These two pieces will need to be soldered together as shown below temporarily held together with some rubber cement.
       Once the pipes are finished and blackened, the holes in the deck will be trimmed to match, the pipes glued in place, and the lips glued down with CA.  Then with the anchor chain threaded through all the holes the deck can be glued in place.
    I seem to be having a difficult time soldering the small pieces of the tubing together as I can’t keep the pieces from separating while using my torch.  I think I’ll try to get some suggestions from MSW or think up another solution myself.  I guess it’s a good time to take a break!
Dave
    After some time looking through MSW suggestions and build logs, I noticed that some members used wood to mount the parts in a jig.  I also have a lighted third hand with magnifier that I picked up from Micro-mark that others have mentioned.
     Although a bit clumsy to use as it came for this application, I just removed the magnifier and the light.  I also re-positioned the second hand as shown below it made it easier to use.
     I stuck the two parts on the ends of some 5/16” wood dowels.  Using the dowels as handles, I sanded the mating edges of the tubing, and lightly dipped the angled tube in some flux.  Then I clamped the pieces of doweling in the two helping hands and maneuvered the parts until they were properly mated as shown in the close up here.
    All I had to do then was heat up the metal parts with my torch on its lowest setting and touch a bit of solder on the joint.  I guess that I kind of surprised myself by finding that this method worked the very first time!  The only drawback that I noticed was that the dowels didn’t take kindly to being so close to a flame.  They charred so badly that they had to be replaced to do the other pair.
    Here are the two hawse pipe assemblies after a little clean up with some sandpaper.  I am a happy camper now!
    Taking one half of the finish decking to my vise, I clamped it between two scraps of wood to carefully refile the holes in the deck to match the top of the new hawse pipe fitting.  With much trial and error I made the opening angle toward the hole in the hull and accept the fitting with a tight push fit.  I aligned the matching false deck with the finish deck and scribed the outline of the opening onto the false deck.  The false deck hole was cut a bit larger to help when aligning the fitting with the decks when the two of them finally get glued down.
    Now the other half of the finish deck was aligned with the completed deck so I could match the size and orientation of the two openings.  I repeated the above procedure for the other false deck and decided that I should probably quit for the day and not push my good luck on my build too far for one day.  So anyway, here are the four pieces of the deck as they stand right now.
Dave
    As I said in an earlier post, the plastic rudder provided with the kit was too short to go through the deck to connect with the tiller so I wanted to make a replacement in wood.  Taking ½ of the plastic rudder supplied with the kit, I laid it on a strip of maple the thickness of the rudder and traced the outline onto the wood.
100_5286.thumb.JPG.0c343f4a0cbb6d9bc998be98ddf26b4b.JPG      The pintle locations were also carefully marked (as shown) to assure alignment with the corresponding gudgeons on the ship.
     A small square was used to mark a perpendicular line across the rudder to make sure their legs could be set square with the edge.  The rudder was carefully cut to the overall shape on my scroll saw and then filed and sanded to its final shape including a small square tenon at the top end to fit into a matching mortice in the tiller.
    Now I needed to make the straps for the pintles and gudgeons from some .016 brass.  The end of the brass was heated with my torch till cherry red and set aside to cool.  Since the straps needed to be cut to 1/16” wide they were set in my vice by projecting the brass strip through the jaws until they flushed out with a piece of 1/16” scrap and clamped.
The brass was then scribed with an exacto blade using the vice jaws as a guide.
    To set up for the cuts a strip of plywood with a straight edge for a saw support was clamped to the edge of my modeling table.  Now the brass strip was clamped into place with the scribed line just the thickness of my jewelers saw blade away from the edge of the plywood. (The clamp on the other end of the brass was set to keep it from twisting during the cut.)
    I shifted my wheelchair so that the arm holding the saw was parallel to the cut to be made.  A stick of wax was used on the blade every so often to lubricate it. Then using a smooth steady stroke with the saw at the angle shown, and using a finger of my other hand to control the chatter, the cut was made.
     After several cuts, it became an easier operation and I was able to cut each strip in quick succession.  When each cut was done, the edge of the remaining brass was squared up and filed smooth in the vice before proceeding onto the next piece.  Ten were cut in about an hour this way.
    Then, having found a photo of the Wanderers’ rudder washed up on shore after she ran aground, I noticed a couple more discrepancies.  Contrary to the shape of the rudder on both my plans and the kit, the trailing edge appeared to be a smooth curve rather than straight.  There was also no indication in that photo that it was sheathed in copper.  Following these discoveries, I have decided to remake the ships rudder as shown in that photo.
    So, while the rudder itself was to be tossed out, it wasn’t a total waste as the brass strips for the legs of the pintles and gudgeons could still be used since they haven’t been formed or cut to length yet.
Edited by BETAQDAVE
Dave
    Well, it was kind of a judgement call on my part as to the shape of the new rudder. I just tried to duplicate the new shape as best I could since the photo was at a difficult angle to make any measurements from.  I made the upper portion of the rudder the same including the tenon at the top.  I made the bottom just wide enough to still attach a pintle and made a smooth curve for the remainder with a slightly wider bulge toward the bottom.  The kit didn’t make a very accurate representation of the pintle and gudgeon joints either.  So, making a lot of extra work for myself, I decided to remove and replace all of the straps from both the rudder and the stern post.  Below is a comparison between the kit original, my first rejected wood duplicate, and my current version taken from the photo mentioned in the last post.
    I had also noticed that other ships about the same size as the Wanderer had fewer hinge points than shown on the plans and the kit, so going with just four seemed more suitable and left me with a little more room for longer legs on the bottom pintle, not to mention more space between the hinge points.
    Taking the new rudder to my vice, I did just that by dividing the edge into in four equally spaced notches and making a sketch (shown below) of how each one would be represented.
    I made eight cuts with my razor saw to the depth set by the vice jaws.  The spacing between the cuts was made twice the width of the strap and then cleaned out with a scalpel.
    The bottom edge of the notch was extended and cleaned up with a round file, leaving an overall space of three times the width of the straps.
     And finally the top of the notch was cleaned up with a square one.
    Here is the result to this point.
Edited by BETAQDAVE
typo
Dave
    The rudder is OK for now but that brings me back to making the pintles and gudgeons to match my sketch.  Of course, before I can do that the first step required is to remove the plastic straps on the stern of the hull.  The removal was done slowly with several different scalpels and was fairly straight forward, however the tricky part was to remove the straps without ruining the appearance of those copper plates on the hull and stern post.  Besides all that, the hull is rather awkward to handle right now, and I can see that it would have been easier if I had done it while the hull was still in two pieces.  Isn’t hind sight wonderful?
    Here is a photo of the offending gudgeons that need to be removed.
    And here is one side removed.
    It still needs a little touch up to restore the definition of the copper plates.  However, that is a job to handle tomorrow!
Dave
          Been off a few days with other projects, but did manage to clean up the definition of the stern copper plates and the transom as shown.
    I guess the next step will be to form the pintles and gudgeons and get them put into place.  That may take a while as I need eight sets of them soldered up.  That’s more even tinier parts than the hawse pipes.
Dave
