I’m currently gathering information while finishing my build of the Victory.
This will be my first scratch build.
I’m going to build the Triton in plank on bulkhead fashion, because I am familiar with it.
I am looking forward to starting the Triton.
Edited by GrandpaPhil
Building:
  • 3 months later...
  • 4 months later...
I haven’t forgotten about the Triton.  I’m still getting caught up in my shipyard.
 I know what I’m making it out of now.  I’ll use plywood for the bulkheads and basswood for about everything else.
I’ll use a hardwood (possibly cherry or pear) for the carvings.
Masting will be locally procurable dowell rods.
Building:
  • 2 months later...
Welcome to the dark side.  It's really a fun place but it has it's moments. ;):P
I’ve had a lot of fun with the Prince de Neufchatel, so I’m looking forward to starting in on the Triton.
I need to pick up a sheet of 1/4” (6mm) plywood for the bulkheads, but I have plenty of basswood for the planking and the underdeck.  I’m sure that I’ll be buying more, but I have enough to get started.
 I just need to finish making the sails and installing the running rigging on the Prince de Neufchatel.  Hopefully that will be done by August.  Then I need to finish Victory, which will probably run me into next spring or summer, before I actually start cutting wood on Triton.
Building:
The Prince de Neufchatel is done now.  I have to finish Victory, then game on for Triton.
 I believe that I am going to alter the scale to 1/72.
That seems to be a good compromise scale between size and level of detail.  Plus it worked well for the Prince de Neufchatel, and I believe that I’d like Triton in the same scale.
Building:
Looking forward to it.
Hi Phil as usual I'm late again and the show has started.
Do you mind if I stand at the back and watch, because I think I may start this once I've got a decent start on my Triton cross section, and after seeing your Victory I think I can learn a lot.
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
  • 9 months later...
